Official JTR speaker thread - Page 847 - AVS Forum | Home Theater Discussions And Reviews
 8691Likes
post #25381 of 37925 Old 11-11-2014, 03:11 AM
rcohen's Avatar
Quoted: 1401 Post(s)
Liked: 630
Originally Posted by carp View Post
Lance, here is what I was talking about. This is the message I get every time I open up the Dirac Calibration Tool:
Looks like it could be something funky with your Creative driver. You might try uninstalling the driver, and using the Microsoft driver.
rcohen is offline
post #25382 of 37925 Old 11-11-2014, 03:16 AM
rcohen's Avatar
Liked: 630
Originally Posted by Gooddoc View Post
I created a couple different filters no problem. It's just that they're not applied to any audio passing through my computer. I've selected DiDirac as my default soundcard and nothing happens to the audio. I've selected every output in the Dirac processor but no go.
Just in case it helps, I was able to select my video card's HDMI output, which worked great. You might try updating your video driver.
rcohen is offline
post #25383 of 37925 Old 11-11-2014, 03:19 AM
rcohen's Avatar
Liked: 630
Originally Posted by lbrown105 View Post
That's the great part. Once you get the room measured adding different target curves is soooo fast. Then you can load up to four different target curves in the DIracc control box and instantly switch back and forth between them or Dirac off. Makes for great quick change comparisons.
Just make sure you run through the full measurement procedure a couple of times and save the projects separately. I go better impulse response improvements with a larger volume of measurement space (nine is the total number). Side to side, forward and back slightly and up and down slightly too.
My two week trial is over and this sucks. I would purchase it today but my pre pro is supposed to be implemented with it in Dec so I need to wait. This sucks!!!
Good luck and let us know how it goes. Oh yeah, also depending on how much boost you may add with a given target curve (I think Dirac maxes at +10dB) you need to make sure the clip light isn't coming on during music playback. It is an input clip indicator so MV does not factor in but filter boosting does. In default (-8dB) I have never seen the clip light come on though.
That's sort of what happened to me. I tried the trial 6 months ago. I was debating whether to wait for the XMC-1, which was due out any day, but I couldn't live without Dirac when the trial ran out. A little different when you already have the XMC-1, though.
rcohen is offline
post #25384 of 37925 Old 11-11-2014, 03:43 AM
Gooddoc's Avatar
Quoted: 3108 Post(s)
Liked: 2413
Yea, I might try the update thing. But to be honest, I think I'm just going to uninstall and forget about anything windows coming anywhere near my HT unless it is absolutely bulletproof. This is the reason that firmware is best for HT, not software. But that's my own personal take, YMMV.
Gooddoc is offline
post #25385 of 37925 Old 11-11-2014, 03:56 AM
rcohen's Avatar
Liked: 630
If you're annoyed by fighting PC flakiness and quirks, you'll probably be annoyed by Dirac Live. Their driver does cause some issues from time to time. I'd rather have it in a pre-pro, but I'm waiting for a reasonably priced one with Atmos. The Dirac Live trial might still be worth experimenting with to get a taste of what Dirac can do.
JRiver is the main thing that keeps me tied to a PC. No going back for me.
BTW, when using a PC for audio out, make sure to set all the speakers to large/full range on all audio outputs, in order to disable Windows bass management, which defaults on.
rcohen is offline
post #25386 of 37925 Old 11-11-2014, 04:50 AM
coolgeek's Avatar
Quoted: 636 Post(s)
Liked: 287
Originally Posted by Nabs17 View Post
Lot of guys here refer to "S8"....which "S8" are you referring to? The HT, LP or Slanted or are they essentially identical in performance? My plan is to purchase 4 "Slanted 8" real soon because I think they fit my room perfectly with the 30 degree angle but if one is better than the other.....well maybe I'll have to think about it more.
Nabs, I guess they are basically the same. I asked Jeff this before I made my purchase and he basically said that.
As surrounds, these are little gems.
coolgeek is offline
post #25387 of 37925 Old 11-11-2014, 08:36 AM
desertdome's Avatar
Quoted: 1333 Post(s)
Liked: 1524
That only applies when using a Direct Sound audio driver. When using a hardware direct method like ASIO or WASAPI, the settings in the Control Panel are completely bypassed. I can't remember the last time I saw anyone using Direct Sound.
desertdome is online now
post #25388 of 37925 Old 11-11-2014, 08:44 AM
Gooddoc's Avatar
Liked: 2413
Just curious, what is it you use JRiver for?
Gooddoc is offline
post #25389 of 37925 Old 11-11-2014, 09:44 AM
Deep Sea Sound
dgage's Avatar
Quoted: 1669 Post(s)
Liked: 1491
Good...DD and rochen are present. Any comments or experience comparing Dirac Live to Audiolense? I was at one point thinking of setting up Jriver with Aidiolense but may upgrade my NanoAVR to the Dirac version.
dgage is online now
post #25390 of 37925 Old 11-11-2014, 10:39 AM
beastaudio's Avatar
Quoted: 4148 Post(s)
Liked: 3504
Originally Posted by raynist View Post
Where are you located? I think we may have talked about this before when I was considering this a while back.
I am in western NC.
beastaudio is online now
post #25391 of 37925 Old 11-11-2014, 11:53 AM
jlpowell84's Avatar
Quoted: 1941 Post(s)
Liked: 915
I finally got around to watching a 3D movie on this BenQ W7000. I can see why guys who are serious videophiles stack PJ's and use this one for 3D viewing. Simply amazing. Grabbed Life of Pi in 3D. If the black levels were better I could not ask for more for me personally from a picture. With the Oppo Darbee it puts out a great picture. But I can't complain for the deal I got Since calibrating I watched that movie on -8 to -10 MV. The JTR's just cruise the soundtrack like it's a pro in a HS football game. With ease! I just love distortion free life!
JLPowell84's Room
FTW21 Ported Build
Spoiler!
jlpowell84 is offline
post #25392 of 37925 Old 11-11-2014, 12:00 PM
jlpowell84's Avatar
Liked: 915
I havn't been following like I used to so I have missed much of the Dirac mini dsp discussion. Do any of you think I could make some good improvements with getting one of these units? I currently run just an Open DRC for my two Submersives in partnership with XT32. I know several of you have gone away from Audyssey with your personal opinions but I like what it does in partnership with my mini dsp. I am just wondering if the surround sound "team effort" and overall SQ would really be that much better. I mean for what I have I think I have it dialed in pretty dang good. I am running the bass trims where XT 32 sets them and just go to PGM 2 on the Submersives (+3db bump from like 45hz on down) and a mild low shelf filter via mini dsp. I think with a 4-5db gain. I have thought about turning the low shelf down to 3db gain. EOT beginning was just plain stupid. I seriously couldn't go past -40 MV!!! Not sure why so hot? So I have thought about leaving shelf filter off and just giving a 3db sub trim bump.
JLPowell84's Room
FTW21 Ported Build
Spoiler!
post #25393 of 37925 Old 11-11-2014, 12:21 PM
N8DOGG's Avatar
Quoted: 1113 Post(s)
Liked: 1218
I've got a friend who has stacked W7000's. I've seen a few movies in his theater and it's pretty awesome. It's a great projector.
N8DOGG is online now
post #25394 of 37925 Old 11-11-2014, 12:25 PM
N8DOGG's Avatar
Liked: 1218
I just traded a guy one for a custom mechanical keyboard I had made that I'm not using. Should be here early next week, I'm gonna try it out! I've also found out a guy at my work has a XMC-1, so we'll give that a try is Dirac ever actually comes out for it lol.
jlpowell84 likes this.
post #25395 of 37925 Old 11-11-2014, 12:38 PM
countryWV's Avatar
Quoted: 413 Post(s)
Liked: 593
Here is the info
http://jtrspeakers.websitetoolbox.co...ed-8ht-4955475
Chris
Chris
countryWV is offline
post #25396 of 37925 Old 11-11-2014, 12:54 PM
Frohlich's Avatar
Quoted: 1291 Post(s)
Liked: 1233
Originally Posted by countryWV View Post
Ok..fess up..I see all these classifieds in your signature and me thinks you are on the verge of some new toys?????
countryWV likes this.
Frohlich is online now
post #25397 of 37925 Old 11-11-2014, 01:02 PM
countryWV's Avatar
Quoted: 413 Post(s)
Liked: 593
Owning speakers are like boats, Two best days in an owners life are the day you buy them and the day you sell.
Frohlich likes this.
Chris
post #25398 of 37925 Old 11-11-2014, 01:05 PM
Frohlich's Avatar
Liked: 1233
I see Chris, you either
1)don't know yet
or
2)aren't ready for the grand reveal
Either way, sounds like exciting times in the boating world
post #25399 of 37925 Old 11-11-2014, 01:22 PM
desertdome's Avatar
Liked: 1524
I have used Audiolense for a couple years now. I used the Dirac demo at RMAF on the 215HT's. However, the filters wouldn't load correctly and I didn't hear back from customer service until after the weekend. So, I haven't been able to actually compare filters for sound quality.
Installation: Both are easy to install. Dirac is easier to license and get the license code installed.
Basic Setup: Dirac is easier to get up and running and is fairly intuitive. For a basic setup, Audiolense is almost as easy. Dirac can only handle 8 channels.
Advanced Setup: Dirac has no advanced setup and no routing options. With Audiolense, your options are limited by your imagination.
Crossovers and Bass Management: Dirac has no crossovers or bass management. This is an important element of room correction since the speaker/subwoofer integration is so crucial to getting good sound. Audiolense has extremely flexible crossovers and bass management with phase correction.
Measurement filtering: Dirac uses a fixed impulse response window. Audiolense lets you change the response window to exclude most reflected sound and only make corrections primarily to the direct sound.
Target Creation: Both let you easily create targets. Dirac's are for the entire system - all speakers get the same target. Audiolense gives you the option of speaker dependent targets. For example, you might need a different target for surrounds vs mains.
Ability to route all computer audio through filters: Dirac has its own "soundcard" that lets you route all PC audio through the filters for playback. JRiver also has its own "soundcard" that routes everything through JRiver's DSP. If you load the Audiolense filters in JRiver, you can use them for gaming, etc. However, you need to create low latency filters for PC audio so that the lip sync isn't off.
dgage likes this.
post #25400 of 37925 Old 11-11-2014, 01:33 PM
countryWV's Avatar
Quoted: 413 Post(s)
Liked: 593
1)don't know yet
or
212HTs up front and move my T12's to surrounds.
carp and Frohlich like this.
Chris
post #25401 of 37925 Old 11-11-2014, 01:51 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
Thanks DesertDome! Great comparison. Have you heard any feedback on dlbeck's Solid State Alpha system and is it good enough compared to your Lynx Aurora?
dgage is online now
post #25402 of 37925 Old 11-11-2014, 03:10 PM
Reefdvr27's Avatar
Quoted: 1579 Post(s)
Liked: 1064
Boat stands for> Bust Out Another Thousand
Reefdvr27 is offline
post #25403 of 37925 Old 11-11-2014, 03:27 PM
uopdrmark's Avatar
Quoted: 96 Post(s)
I've been getting a good amount of hiss with my 212HT's and an inuke 6000dsp and I'm wondering what other amps people are using without said hiss. I had an emotiva XPR-5 running them with no hiss, but I was hoping for more headroom and dsp if possible to try and boost mid bass or even add MBM's which would be significantly easier with the inuke dsp. Does anyone know if the 3000dsp has a hiss?
uopdrmark is offline
post #25404 of 37925 Old 11-11-2014, 03:35 PM
Reefdvr27's Avatar
Liked: 1064
I just wrote this in another thread of yours, but try shutting off the PEQ on the Inuke and see if that helps. Make sure it is on bypass. I had horrible hiss on my 215's with the my 6000dsp and I found it was the PEQ doing it. I shut it off and the hiss was gone.
post #25405 of 37925 Old 11-11-2014, 03:48 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
Hmm... I have hiss. But I hear if I put my ear up to the CD about 8" away. And I'm using PEQ and DEQ. 12000dsp for 215RT. And 6000dsp for the 215RM. But then again, I don't know if it's because each of those amps are on their own curcuit that's making it silent.
rhed is offline
post #25406 of 37925 Old 11-11-2014, 03:55 PM
uopdrmark's Avatar
Quoted: 96 Post(s)
Yea, I have tried bypassing the PEQ on the dsp and so far no luck. I get the hiss even without an inputs in so I'm pretty sure it is the amp itself. I pm'd Carp and he said his 3000dsp was not as bad but still had a little hiss.
post #25407 of 37925 Old 11-11-2014, 04:28 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
And then again, the 212's are sensitive speakers.. They can hit reference with just a avr. Now that's sweet.
rhed is offline
post #25408 of 37925 Old 11-11-2014, 05:12 PM
Deep Sea Sound
dgage's Avatar
Liked: 1491
Not to mention the 212 is better than the 215RM.
dgage is online now
post #25409 of 37925 Old 11-11-2014, 05:22 PM
rhed's Avatar
Quoted: 645 Post(s)
Liked: 486
Haha,, nice dgage..
rhed is offline
post #25410 of 37925 Old 11-11-2014, 07:10 PM
lbrown105's Avatar
Quoted: 522 Post(s)
Liked: 324
Lab Gruppen 10k runs dead silent on the 212HT's even when set as high as 35dB gain. This is on a dedicated 30 amp line
lbrown105 is offline
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp , noesis
