Official JTR speaker thread - Page 941 - AVS | Home Theater Discussions And Reviews
post #28201 of 28208 Unread Today, 01:34 PM
Nabs17's Avatar
Quoted: 226 Post(s)
Liked: 83
Originally Posted by coolgeek View Post
Added the Bamboo Wall Lights. They provide a rustic, candle-lit ambient to the whole atmosphere. Each LED bulb is only 2 Watts, believe it or not... So, total power in the room, > 10,000 watts for Sound, and < 100 watts for lights.
CG....what surrounds do you have? I love to woodwork and it appears by looking at the picture you have it angled and I'm assuming that's where your surrounds are. Really love to woodwork.
Nabs17
Nabs17 is online now
post #28202 of 28208 Unread Today, 01:41 PM
Reefdvr27's Avatar
Quoted: 990 Post(s)
Liked: 642
Very nice CoolGeek. Are you using single 8's? Also did you do Atmos speakers?
Reefdvr27 is offline
post #28203 of 28208 Unread Today, 01:47 PM
raynist's Avatar
Quoted: 391 Post(s)
Liked: 415
I am about to setup an Elite Screens AT screen this week and have a few questions about placement of my 212HT's.
The area the screen will be in is about 112 inches wide from a wall on the right to a door on the left. I will have 2 of my 4 Power Sound Audio Triax's behind the screen also. Each Triax is about 31 inches wide. Accounting for the Triax's, I have about 50 inches for my speakers. The speakers being 16.5 inches leaves me with less than an inch left over. It seems I may have a hard time towing in my speakers. I had planned on building 21 inch stands to put the 212HT's CD at about 41 inches which is my ear height when sitting up straight on my couch. Another thought I had is to put all of the 212's above the Triax's which are 23 inches tall. This will put the CD about 2-3 inches above my ear height but I could toe in as much as I would like. Will this matter at all? I will be sitting at least 15 feet away from the front of the screen.
I had planned on having it setup as 212-Triax-212-Triax-212. I could push both Triax's together in the middle of the screen and have the center sitting on top. In this scenario the center channels CD would be around 43-44 inches high. I would then have enough room to put my 212's on 20 inch stands as planned and can toe in as much as I would like.
Ray
3 - JTR 228's LCR (game room)
4 - DIY Sound Group V-8 Coaxials in slanted boxes (game room)
4 - PSA Triax's (game room)
3 - DIY Sound Group V-8 Coaxials in Ported Boxes for LCR's
2 - SVS SB13+'s (living room)
1 - SVS SB12-NSD (bedroom)
raynist is online now
post #28204 of 28208 Unread Today, 01:51 PM
Tha Hz Curve
beastaudio's Avatar
Quoted: 1254 Post(s)
Liked: 1100
Ray
Ray,
Having the CD's a couple inches above ear height will not be a problem at all. I would opt to have all three speakers at the same exact height before I would worry about anything else. Putting the 212's on top of the triaxes and gives you a little more flexibility anyways. You may find that the response is better with the combo a little ways in from the side wall, or perhaps better right up against the side wall. Doing this configuration will allow the ability to experiment a little with what sounds best to you.
(European models do not accept banana plugs.)
"If you done it, it ain't bragging." ~ Walt Whitman
AE TD12x SEOS12 Build
Beast's DIY Master Measurement Thread
DIY Emminence Coaxial Surround Thread
beastaudio is online now
post #28205 of 28208 Unread Today, 02:08 PM
kronin's Avatar
Liked: 4
That is a lot of speaker power to be paired with a PB12-NSD!!
I say go for a captivated 2400 instead of the additional surrounds. I have only reall noticed a difference between 5.1 and 7.1 movies on a few occasions.
Funny you mention that. I hadn't looked at the 2400, but was strongly considering starting with one S2 with the option of adding a 2nd if needed. I know my SVS sub is outmatched, but it still sounds pretty darn good
What's your opinion on the 2400 vs. S2? I thought most of the owners in this thread were running sealed subs.
kronin is online now
post #28206 of 28208 Unread Today, 02:12 PM
Tha Hz Curve
beastaudio's Avatar
Liked: 1100
Depends on if you want extension below 20hz or so. With just a single s2, you still won't get it, but if you get a pair of s2's, it will be quite visceral. For half that or so, a pair of caps will get you the same output above tune, but you sacrifice the <20hz material. Arguments are valid on both sides really on whether or not this is important or not....
post #28207 of 28208 Unread Today, 02:15 PM
raynist's Avatar
Quoted: 391 Post(s)
Liked: 415
If I were just starting out with getting high powered subs I would go DIY. But if you can afford 2 S2's that might be the best bet.
post #28208 of 28208 Unread Today, 02:42 PM
asoofi1's Avatar
Quoted: 549 Post(s)
Liked: 207
Current equipment:
3 x JTR triple 12
2 x JTR single 8
SVS PB12-NSD
a 10-year old Sony receiver
Soon to add:
2 x JTR slant 8
I'm considering the following:
Denon X5200W
Marantz SR7009
Marantz AV7702 with an Emotiva XPA-7
Usage is 60/40 movies/music. I originally was just going to get the Denon and leave it at that. Someone pointed me at Marantz so started researching, and then was intrigued with the idea of separates. Room size is roughly 30' x 14'.
Any advice is greatly appreciated. The reason I'm asking here and not in the Denon/Marantz threads is that I've already read all of those comparisons. I want to get some feedback from JTR owners. Thanks!
If you're not running Atmos, then an avr like 7009 is all you need for your 7.1 setup.
If atmos 5.1.4, then everything can just run off the avr.
If you're going to 7.1.4 atmos then just add a 2 or 3 channel amp to the 7009 to run a pair or all of the front channels and the surrounds off the avr.
Avr by itself is all you need to go louder than you can stand.
gear: 3x JTR 212HT ~ 4x JTR 8LP ~ 2x JTR Orbit Shifter LFU ~ 11x Elemental Designs eD6c ~ Marantz SR7008 ~ Panasonic PT-AE8000U ~ Elite 176" 2.35 ATS
asoofi1 is online now
Reply Speakers
215RT , 228ht , captivator , Jtr , Jtr Noesis 212ht 212ht Lp
Gear in this thread - 215RT by PriceGrabber.com
