In-ceiling speaker enclosure - AVS Forum | Home Theater Discussions And Reviews
post #1 of 28 Old 07-25-2009, 10:33 PM - Thread Starter
OKsoccer24's Avatar
How necessary are the in-ceiling enclosures?? I plan on getting speakercraft AIM8 three for front right and front left, AIM3 three LCR for center, and AIM7 three for rears. The only enclosures I could find were the ones from speakercraft for like 120 bucks each. Are there cheaper enclosures out there? Do I really need an inclosure?
OKsoccer24 is offline
post #2 of 28 Old 07-26-2009, 01:02 PM - Thread Starter
OKsoccer24's Avatar
Surely some people will have a response...
post #3 of 28 Old 07-27-2009, 11:25 AM
Yosef 615's Avatar
Perhaps a good starting point...
http://www.cepro.com/article/how_to_...peaker_systems
XBox Live Gamertag: Vash615
Boomer Sooner!!!
Yosef 615 is offline
post #4 of 28 Old 07-27-2009, 12:29 PM
ttowntony's Avatar
We specifically recommend the DynaBox http://dynamat.com/products_architectural_dynabox.html to our clients. I highly recommend the product, it's well worth the expense when not purchasing an enclosed back speaker to begin with.
Tony G. Cordova, President
Showplace Oklahoma - Showplace Theater & Sound
"We put the SHOW in your PLACE."
ttowntony is offline
post #5 of 28 Old 07-27-2009, 12:44 PM
ttowntony's Avatar
Specifically, for Speakercraft speakers. I believe the only enclosures they offer are for NEW construction installations......nothing for retrofit, correct? Not a Speakercraft dealer here obviously.
Here is an alternative to Speakercraft. Look into Triad Speakers Conextion line
http://www.triadspeakers.com/conextion/conextion.html#
post #6 of 28 Old 04-06-2012, 07:22 PM
BobPond's Avatar
This thread is worth reviving.
It seems that a lot of money is spent on in-ceiling and in-wall speakers yet there appears to be no strong consensus on whether it makes sense to build enclosures for them.
One of the above postings refers to the following technical article:
This article points that out that wall cavities are extremely leaky. This can be even more true of ceiling speakers. Yet, wouldn't in-wall / in-ceiling speakers be engineered with this in mind? It seems that whatever enclosure you build around such a speaker (even $100 dynamats!) would be too small for such a speaker.
Has anyone really demonstrated that it helps to build speaker enclosures around in-wall or in-ceiling speakers?
Note: My in-ceiling speakers will have an attic above them from where I can install any enclosure that I like. If an enclosure would really help, why not simply use a large styrofoam box with or without a plywood bottom and with or without insulation inside?
BobPond is offline
post #7 of 28 Old 04-06-2012, 07:56 PM
ap1
ap1's Avatar
Quoted: 22 Post(s)
To avoid most of the problems with in-ceiling/wall speakers, you can surround them with large amount of sound suppressing material (the same sort used in acoustic panels). If you use enough of it to almost completely absorb sound waves in surrounding cavity, the only thing you will have to worry is vibration.
ap1 is offline
post #8 of 28 Old 04-06-2012, 11:07 PM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Bob, I think the biggest challenge with open baffle is there is simply no way to engineer an open baffle for each and every room. There are too many unknowns with regards to the wall itself, such as, taller or shorter walls (did they build the open baffle to accommodate 7' ceilings, 8', 10', etc?) What about walls or ceilings that have ductwork, pipes, etc running through them? How much insulation is factored in for the open baffle design, and for what R value? As the article mentions you also have speaker bleedthrough to the tune of 20db. For some people this may be a concern if you have a room beside or above the area where the open baffle speaker is installed.
For me it makes commonsense to have an engineered enclosure as many of us simply do not know what is buried in our walls and how it may interact with our speakers. As the author of the article researched, gypsum board makes a poor speaker box.
Based on my own personal experience with in-wall and in-ceiling speakers, I have found that the best sounding speakers had engineered enclosures. With my favorites being from Triad, Atlantic Technology, and RBH. The engineered enclosures are designed to a specific volume based on the components and are usually made with the same material that they would build a cabinet speaker with.
This is not to say that open baffle speakers sound bad. I have heard many that sound quite good, but, to me, enclosed speakers are preferred. That said, they tend to cost more
ack_bk is offline
post #9 of 28 Old 04-07-2012, 12:42 AM
BobPond's Avatar
Thanks for these replies. For many if not most of those of us who buy in-wall or in- ceiling speakers (I myself bought two pairs of the popular Polk RC80i's - see http://www.amazon.com/Polk-Audio-RC8.../dp/B00006BMQT ) the question remains whether we can improve the performance of these open baffle speakers by building some sort of enclosure behind the wall or ceiling. Apparently, the Dynamat folks are persuading a number of people that it is worthwhile for them to spend $100 per speaker for such enclosures (presumably the vendors of these enclosures promise improved performance regardless of whether the speakers were engineered for enclosures of this size, etc...). If an enclosure will help even for "open baffle speakers" then why not use a cheap styrofoam cooler. I could order a 45 quart one from Lowes for $13 that fits in the space above my ceilings ( which I have access to). Will it be worthwhile for me to install such enclosures? Should I put any fiberglass insulation in? What does the theory suggest?
BobPond is offline
post #10 of 28 Old 04-07-2012, 06:21 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
Bob, I honestly do not know how styrofoam would sound, but I think you have to ask the question if you have ever seen a speaker cabinet built out of styrofoam before? If it was me, I would do this:
- Call or email Polk Audio and find out what volume the boxes should be built to support. If you build the box too big or small, it could negatively impact sound.
- I would personally build the box out of 3/4 MDF. It is relatively cheap and has been used for a very long time in the building of speaker boxes. If you buy the wood at Lowes or Home Depot they will usually cut the pieces for you to the exact dimensions in the store.
- I would use some acoustic caulk after the box has been built on all the outside edges to ensure a good seal and no air leakage. I would also polyfill instead of insulation inside the box and start with about half fill.
I also think you have to consider the application. If these are inceiling speakers that are open baffle and being used for surround sound music played at moderate to lows levels? I think building boxes is probably overkill. If this is for a dedicated media room where you might play fairly loud and want the best sound? It might make sense to build the boxes as suggested, or just save up for a speaker with an engineered enclosure designed by the manufacturer.
ack_bk is offline
post #11 of 28 Old 04-07-2012, 04:23 PM
BobPond's Avatar
Thanks again for the replies. Here is what I have gathered so far from these comments and from what has been posted elsewhere on the web. I hope that you and others can correct, elaborate on and add to any of these points:
1. Hi fidelity speaker drivers are engineered to perform well with speaker enclosures of specific size and other characteristics;
2. The majority of in-wall and in-ceiling speakers on the market are sold without enclosures;
3. This is not to say that these inexpensive in-wall and in-ceiling speakers (e.g. $120 for a pair of Polk RC80i's) are necessarily designed to be completely "open baffle". They might perform best without any enclosure at all (e.g. when placed in a ceiling that has an attic above without any insulation covering the speakers). Or they might be designed to perform best when placed in a compartment of a specific size (e.g. the space in an 8 foot tall wall cavity created by 2x4 studs 16 inches apart). Remarkably, the speaker manufacturer does not specify the type of space in which they perform best. I will, as you suggest, send them an email but I would be surprised if they have a definitive answer to this question;
4. Some manufacturers market in-wall or in-ceiling speaker enclosures (e.g. Dynamat). Remarkably, these manufacturers also do not seem to specify the types of speakers for which these enclosures perform well;
5. This muddled situation persists because most people are happy with what an audiophile would call medium to low audio quality;
6. It is probably overkill to build proper speaker cabinets for such mid-to-low quality speakers and the speaker cabinets may not even be the right size for such speakers;
7. There is still the possibility, however, that the performance of a typical, inexpensive in-wall or in-ceiling speaker might be optimized by using simple techniques such as a) "you can surround them with large amount of sound suppressing material (the same sort used in acoustic panels) [see above comment]"; or b) placing a sheet of plywood over the ceiling joists when the speakers are placed beneath an open attic; or (who knows?) c) creating a large enclosure for $13 by placing a styrofoam cooler over them. The goal of such modifications would be to optimize performance of affordable speakers at minimal cost and with minimal effort. The goal would not be to transform them into hi-fidelity speakers. Optimizing the performance of typical, non-hi-fi in-wall and in-ceiling speakers is still an important goal, however, given the very large numbers of such speakers that are sold including for expensive home theater and whole house audio systems.
Any thoughts on the above? Thanks.
BobPond is offline
post #12 of 28 Old 04-17-2012, 06:28 PM
Randomn8's Avatar
I too have been down this similar path with an unsatisfactory amount of information as a result. I'll probably end up giving the Axiom in walls a shot via a local listen and see if those suit my needs. I'd love to check out all the options over open backed from reputable companies but the logic behind a structured box resonates (pardon the pun) strongly with me, especially because my project will not be new construction. But yes, I'd love to hear more options and thought there would be a somewhat dedicated thread here, but if there is, I have yet to locate it.
Randomn8 is offline
post #13 of 28 Old 04-20-2012, 11:07 AM
billt1111's Avatar
Bob,
Ok you convinced me that I need to do something as well. I share your thoughts about this apparent gaping hole in the audio experience, i.e. baffles for in-ceiling and in-wall speakers.
I just bought and installed 4 RC80i's. Two are my surrounds and two are my front 'highs'. I had access to the ceiling above the room in which they are installed. I cut the holes between joists which are 10" apart. That left about an inch clearance between joists on each side of the speaker. I bought 4 Styrofoam coolers at Walmart, moved the blown in insulation carefully out of the way, and placed them over each speaker being careful to run the speaker wire. I then placed a 5lb weight on the light cooler to hold it down tight against the ceiling. I then re-ran MCACC calibration on my Pioneer VSX-1121 amp.
I think it sounds better, but an A/B comparison is rather hard to accomplish. In the long term the coolers keep the dust and insulation off the back of the speakers. That has to be a good thing. Overall, I cannot see any downside to doing this.
bill
billt1111 is offline
post #14 of 28 Old 04-20-2012, 11:23 AM
Scout's staff's Avatar
Originally Posted by billt1111 View Post
Bob,
Bob,
I'm unclear on where you installed your speakers - were they in the ceiling or walls? If walls, were they exterior walls? I'm worried that you no longer have insulation behind the speaker preventing heat and cooling loss. More importantly, did you repair/restructure the vapor barrier behind the speakers?
Scout's staff is offline
post #15 of 28 Old 04-20-2012, 11:42 AM
billt1111's Avatar
Originally Posted by Scout's staff View Post
Bob,
They are in the ceiling, hence the ease in adding coolers as a baffle. I never had the blown in insulation contacting the back of my Polk ceiling speaker cones. However once the coolers were in place over the back of the speaker I rearranged the blown in insulation around the cooler.
bill
post #16 of 28 Old 04-20-2012, 01:35 PM
Thanks - didn't want you to have structure issues later due to moisture. I too have in-walls and in-ceiling speakers. I went with Dynaboxes for the in-ceiling speakers to control exterior sound in the scuttle area and hopefully provide a more focused/fuller bass sound from the speakers. I'm happy with them, but I never listened to them without the Dynaboxes to see a difference.
post #17 of 28 Old 04-20-2012, 02:13 PM
billt1111's Avatar
I guess that is the point of this thread. The Dynaboxes I see on ebay are $122 each! I am positive that they are fine additions to the system. I spent $2.99 for a weighted down Styrofoam cooler on a ceiling speaker. The question is whether there is a difference discernible to a listener?
bill
post #18 of 28 Old 04-21-2012, 01:47 PM
ben_r_'s Avatar
There probably isnt, but I do like the idea of the speaker back being covered and more protected. I have been thinking about how I was going to do that myself as I have four pairs of these Polks to install in various ares of my house and am wondering how to keep the insulation off of them.
ben_r_ is offline
post #19 of 28 Old 04-21-2012, 02:06 PM
billt1111's Avatar
Don't forget lots of pink insulation in the cooler and a weight on top of the cooler to keep air leaks to a minimum. I did another mcacc speaker cal after finishing the 'project' and the DIY baffle changed the settings by about 2 db per speaker.
bill
post #20 of 28 Old 08-27-2012, 03:10 AM
henningdalgaard's Avatar
I could use some more bass in my ceiling speakers.
Did you get more bass with enclosures?
henningdalgaard is offline
post #21 of 28 Old 05-30-2014, 12:02 PM
smileradio's Avatar
How did it work out with the AIM8 Threes in the front and the AIM7 Threes in the two surrounds??? I am looking into doing JUST that. Did you notice a big difference between the AIM8s and the AIM7s?
smileradio is offline
post #22 of 28 Old 02-15-2016, 09:38 AM
pghflyer's Avatar
I am going to go the DIY myself as well with some RC80is. I like the idea of the Styrofoam coolers. I have white fiberglass blown insulation so was just planning to put that over the weighed down Styrofoam container with nothing else in the container that is over the speaker. Any other tips or feedback on this topic recently?
pghflyer is offline
post #23 of 28 Old 02-15-2016, 10:12 AM
Quoted: 154 Post(s)
Liked: 63
You realize that by adding a back to those you are going to be cutting their balls off, essentially neutering the bass response? It will sound the same only with less bass. Most manufacturers do NOT recommend boxing their open backed speakers for full range performance for music. Movies, it doesn't really matter as the freq response will be cut off down to 80hz anyway.
That's not to say that enclosed speaker manufacturers like Triad and James (We're a dealer of both, among a lot of others) are incorrect in doing so. But they engineer their product for that and for a specific purpose. Same thing with most open back models. Those speakers are typically engineered to play without a box for best performance.
A great example is Triad's in-ceiling speakers. Their open backed R series rounds perform outstanding for music listening. Much better for music than their closed, and more expensive, counter parts. The enclosed models specs are hammered in the bass department. It's the same deal with Monitor Audio's in-ceilings that are open and then the same speaker is available in an enclosure - only with horrible bass in comparison - and on and on down the line.
If you have sound bleeding between floors or between walls it can sometimes help. But, in general (there are always a few exceptions) enclosing something like your $140/PAIR of Polk in-ceiling speakers will not make it perform better. 99/100 times it's the opposite.
PrestigeAudio is offline
post #24 of 28 Old 02-15-2016, 10:20 AM
ack_bk's Avatar
Quoted: 548 Post(s)
Liked: 631
You need to understand what volume to build the boxes, and I am not sure styrofoam is a good idea. Contact Polk customer service to see if they can recommend a volume size, and I would use something like MDF and standard wood glue to build the boxes. You may want some loose insulation inside.
To the point above I would just try them in the ceiling first before you build boxes as they may sound just fine as long as you don't mind sound bleeding through. Expecting much bass from these speakers is very unrealistic you will want a dedicated sub (or two) and cut them off around 80hz.
ack_bk is offline
post #25 of 28 Old 02-15-2016, 10:54 AM
pghflyer's Avatar
Thanks for the feedback both of you, very helpful. I will reconsider and also send a note to Polk. In my previous house (recently moved) I had in-ceiling without any additional boxing/ sealing and thought they sounded great but this thread was making me second guess.....
pghflyer is offline
post #26 of 28 Old 04-19-2016, 09:58 AM
Liked: 0
Hi,
new poster - wouldn't want to restart a thread, so piggy backing on this one.
Renovating the main floor (Dining room, Kitchen.)
The wife doesn.t allow any visible speakers, and I won.t spend on floorstanding until my kids are much much older (18 months, 4yo.)
I do not expect a realistically high quality sound, just some passable background music; as I'm aware in-ceiling speakers aren.t really the best when it comes to sound reproduction.
(Also, I.ll be powering them with Pionner car radios... since it.s inexpensive, small, have bluetooth, line-in, and what not, and I already run 12V for led lighthing.)
With all that in mind, my main concern is thus not sound quality but rather sound dissipation in the upstairs rooms. My home is poorly insulated, there is absolutely no way I will be able to achieve a proper isolation between main floor & second (foremost when installing in celing spks in between...) but I'd like to do as much as I can to reduce:
- music heard upstairs
- vibrations accross the house
I do not intend to purchase Dynaboxes (good concept, but prohibitive prices, foremost here in Canada)
I'd be tempted to go a proper DIY way , or a reasonably priced commercial solution.
Any suggestions will be very seriously considered & analyzed
Right now my biggest grief is not to be able to audition said speaker in their final setup. I've tested Monitor Audios 6.5 in a store yesterday, they sounded 'ok' - but since I want to put in 6 or 8 of them (and ideally a few 8') I might have to go a cheaper route... like the Yamaha's which would fit in my price point.
All in all, with back enclosures, wiring and amps; I.m hoping the sound won;t suck too much ... as I could easily get two self powered non-inspiring Denon Heos 7 for less money. But I'm truly against those selfpowered,selfdriven,self-satifying wifi consumer speaker boxes
thanks!
djbono2 is offline
post #27 of 28 Old 05-12-2016, 02:22 AM
mp3truck's Avatar
Quoted: 29 Post(s)
A little anecdotal evidence and info to bring this topic back to the forefront...
I have a pair of Monoprice 4929 8" in-ceiling speakers installed out on my covered patio connected to zone 2 of an Onkyo TX-NR626. These ones: http://www.monoprice.com/Product?p_id=4929
After installing, they sounded good but were definitely lacking lower frequencies that, for an 8" driver, I felt they should have been able to reproduce well. I noticed that Monoprice sells an enclosure for them here: http://www.monoprice.com/product?p_id=11942 with a description stating: "Using an enclosure improves bass response and the overall sound quality will be tighter and more focused."
Rather than buy the enclosures, I figured I'd do a bit of experimenting on my own since I had plenty of space above the speakers in a huge attic. I started by simply finding a couple Amazon cardboard boxes that were around the size of the drivers. I think they were like 10"x12". I placed the cardboard boxes over the drivers and weighted them down. Listened to the speakers and they had a significantly better sound to my ears. Much more low end and the midrange actually sounded better, too.
Having proven the theory, I simply screwed a piece of plywood to the ceiling joists above the drivers and two pieces of plywood on each end perpendicular to the joists to enclose the driver. Caulked things together and for approximately $10 I had enclosures that work great.
I'm guessing YMMV depending on the type of driver and the amount of space behind the speakers. For instance, in my living room I have a set of Sonance 624 in-walls and they reproduce low frequencies very well with no backing. I suspect it's a combination of the design of the speaker and the fact that they're installed into a wall that has maybe 4" of depth and the wall is filled with insulation being an exterior facing wall.
Not sure that gives any definitive information other than "Try it, it may work." but figured I'd put it here for the next guy searching this topic who stumbles onto this thread.
mp3truck is offline
post #28 of 28 Old 05-12-2016, 12:17 PM
microwiz's Avatar
Quoted: 103 Post(s)
Liked: 49
I'm still trying to figure out how any of these in ceiling speakers meet their frequency range without a box. Every ceiling speaker I have heard without a speaker box has very little bass and the sound changes depending on the structure they are mounted to.
Pioneer SC-95, Axiom M80, VP180 Dual EP500 all V4. RS400 + Stewart Cima Neve 133
microwiz is offline
Reply Speakers
