Need help connecting Z-2300 to Vizio - AVS Forum | Home Theater Discussions And Reviews
post #1 of 11 Old 07-28-2009, 06:39 PM - Thread Starter
ShoelessinSC's Avatar
I apologize first off if I am posting this is the wrong place or if this has been answered before. I've spent the past 3 hours looking for the answer to this on this forum and others and haven't found my answer.
So, I have a Sony Vizio LCD HDTV. I have the Logitech Z-2300 speakers with the headphone style output. I lost the adapter that came with the speakers that connect the pale green output to an all female-Y cable.
I need a cable that will connect this single speaker cable to my HDTV audio out. I suppose I need a 1Female/2Male Y Cable, but I bought one from radio shack and it doesn't work.
What cable do I need?
I think my cable connector needs to look something like this one (except mine would need two red/white male ends)
http://i32.tinypic.com/dqnjir.jpg
Thanks for the help!
ShoelessinSC is offline
post #2 of 11 Old 09-02-2009, 09:39 AM - Thread Starter
No ideas?
post #3 of 11 Old 09-02-2009, 10:30 AM
raistline's Avatar
Quoted: 53 Post(s)
Liked: 31
You need a 3.5mm female connector to RCA Red and White male connector. You will then connect the RCA Red and White male to the TV's Red White female audio out connection.
raistline is offline
post #4 of 11 Old 09-02-2009, 10:34 AM
Pete7874's Avatar
http://www.radioshack.com/product/in...ductId=3449316
"The problem with quotes on the Internet is that you never know if they're real." - Abraham Lincoln
Pete7874 is offline
post #5 of 11 Old 09-02-2009, 10:47 AM
raistline's Avatar
Quoted: 53 Post(s)
Liked: 31
This is the wrong one. He needs the Headphone end to be a female end and not a male end.
This is the one he needs. http://www.mycablemart.com/store/car...t_detail&p=602
post #6 of 11 Old 09-02-2009, 11:02 AM
Knucklehead90's Avatar
Quoted: 493 Post(s)
Liked: 423
Third to last picture shows exactly what is needed.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 amps - Salk Song Towers - Oppo 103
Vinyl Room: Emotiva PT-100 - ST-120 amp - Acoustic Research AR-2ax - Marantz TT42 - Oppo 103
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is offline
post #7 of 11 Old 09-02-2009, 11:06 AM
raistline's Avatar
Quoted: 53 Post(s)
Liked: 31
Yes, but the option above your post means he won't need an extra RCA cable and can plug the adapter directly into the TV.
post #8 of 11 Old 09-02-2009, 11:44 AM
Quoted: 493 Post(s)
Liked: 423
The Logitech takes a 1/8" male for audio signal input. The pale green he referred to in the OP is a standard for computer connections - it refers to a 1/8" male stereo plug - the one thats been mis-placed. I have the same pale green male stereo 1/8" plug on a JBL Creature I use in the shop for connecting a Sony Walkman to for radio and playing tapes. For that I use a double ended male 1/8" stereo adapter. It plugs into the pale green port on the JBL Creature.
Maybe this would work?
post #9 of 11 Old 09-02-2009, 12:20 PM
Pete7874's Avatar
This is the one he needs. http://www.mycablemart.com/store/cart.php?m=product_detail&p=602
What you linked above has a female RCA on one end.
He needs a female mini-jack there, so maybe this one:
http://www.techcables.com/6-inch-3-5...able-p-42.html
Pete7874 is offline
post #10 of 11 Old 09-02-2009, 12:30 PM
Quoted: 493 Post(s)
Liked: 423
From the OP:
Perhaps you missed that. If he still had that little connector your solution would work. If he gets the double male 1/8" stereo adapter your suggestion would work
post #11 of 11 Old 09-02-2009, 12:34 PM
raistline's Avatar
Quoted: 53 Post(s)
Liked: 31
Now I could have sworn I updated that link. I think when I did an edit, I accidentally pasted the wrong link again. oops.
But yes, the one you linked to was the one I meant to link to.
I will edit mine again, this time correctly.
Ok It works now.
Reply Speakers
