Thiel CS2.4 + Rotel RMB 1095 - AVS Forum
post #1 of 2 Old 08-08-2009, 02:46 PM - Thread Starter
pack_tor's Avatar
Hi,
It looks like I can get a reasonable price on a used pair of Thiel CS2.4 speakers. I currently have Rotel RMB 1095 driving my Paradigms - Do you guys think I can use the Rotel to comfortably drive the Thiels?
Has anyone used or listened to the above combo? Would I be able to extract the most out of the speakers using the Rotel?
pack_tor is offline
post #2 of 2 Old 08-08-2009, 04:11 PM
CLS
CLS's Avatar
Originally Posted by pack_tor View Post
Hi,
IMO the Thiels are more difficult to drive than the Paradigns but the Rotel is more than capable to handle that load.
This is a hard question to answer and will stir a lot of different views and opinions from different crowds. I think it would, but I would suggest you get a loaner from your local dealer an amp say a Musical Fidelity, Plinius or a Pass Lab and directly compare it with your Rotel. Only trust your ears.
Vin
CLS is offline
Reply Speakers
User Tag List
