best 5.1 speaker set-up for a $450-500 budget - AVS Forum | Home Theater Discussions And Reviews
Old 08-18-2009, 05:07 PM - Thread Starter
mp2281's Avatar
Hi All,
Just looking for some recommendations on a good speaker setup for my budget. I already purchased the HK AVR 254 7.1 Home Theater Receiver. I'm open to any brand speaker. Just shoot me your recommendations from your experinces.
Thanks all!
mp2281 is offline
Old 08-18-2009, 05:10 PM
cougar99's Avatar
Cant go wrong with the Def Tech pro-cinema 600
cougar99 is offline
Old 08-18-2009, 05:14 PM - Thread Starter
mp2281's Avatar
Do you have a Link?
mp2281 is offline
Old 08-18-2009, 05:18 PM - Thread Starter
mp2281's Avatar
Originally Posted by mp2281 View Post
Do you have a Link?
Found them, the cheapest they go for is 699 a little out of my budget
mp2281 is offline
Old 08-18-2009, 06:11 PM
cougar99's Avatar
Then you might want to try the Energy Take Classics.....at Crutchfield
http://www.crutchfield.com/p_732TAKE...-0.html?tp=184
They should have an adequate subwoofer that will keep you in your price range.
http://www.crutchfield.com/p_732ESWC...C8.html?tp=187
cougar99 is offline
Old 08-18-2009, 06:18 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
afrogt is online now
batpig's Avatar
Quoted: 3569 Post(s)
Liked: 3415
Energy C-50/C-C50 package for $250 shipped:
http://www.wwstereo.com/default.aspx..._84__0_0_0_-1/
then add on the best subwoofer you can afford with the rest of your budget.
but it's hard to say exactly since you haven't specified what your needs are (e.g. towers, satellites, wall-mounted or floorstanding, etc.)
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Old 08-18-2009, 06:20 PM - Thread Starter
mp2281's Avatar
Hi all thanks for the replies. Room size is 15x18. Asteically pleasing speakers would be a plus. I was going to go with inwalls, but i've been reading you loose a lot of quality for the price.
mp2281 is offline
Old 08-18-2009, 06:24 PM - Thread Starter
mp2281's Avatar
I've been looking at this package:
4. Mirage Omni 550 5 speaker package $499. Get a sub later!
http://www.vanns.com/shop/servlet/it..._c=site_search
What can you tell me about this setup, how do you think it will sound in a 15x18 room with wood floors. =)
mp2281 is offline
Old 08-18-2009, 06:37 PM
afrogt's Avatar
Liked: 755
I can tell you there's a lot of chatter about it in the Mirage thread. Its probably the best bang for the buck too!
Several reviews of the black 550's on the Vanns website. Black is no longer available. In case you were not aware, there is a 2nd 6.5" woofer in front. You can't see it on the cherry model because the grille is in place.
http://www.vanns.com/shop/servlet/it...irage-omni-550
Comes with speaker spikes so the wood floor shouldn't matter.
Afro GT
Old 08-18-2009, 06:37 PM - Thread Starter
mp2281's Avatar
mp2281 is offline
Old 08-18-2009, 06:42 PM
afrogt's Avatar
Liked: 755
Not a bad little system. You can probably go to your local Best Buy and check out nanosat speakers if they have a Magnolia Home Theater inside.
Probably no warranty on that Mirage nanosat ebay system since they're not an authorized dealer.
I'd rather have the 550 setup myself, especially for a 15 x 18 room. Vanns is an authorized Mirage dealer so you get the 5 year mfrs warranty.
Afro GT
Old 08-18-2009, 06:55 PM - Thread Starter
mp2281's Avatar
I showed my fiance the color of the 550's she said absolutely not she hates the color =(
mp2281 is offline
Old 08-18-2009, 08:44 PM
afrogt's Avatar
Liked: 755
Such is life, then look at one of the other options. or get a set of 150s which are all black. You can get two pair of those and the black center for under $300. Still have enough money for a sub.
Or how about some Energy C-100s, they have a nice pretty gloss black front baffle that she may like.
http://www.audioadvisor.com/prodinfo.asp?number=ENC100
or the C-300 towers I linked earlier if she's okay with tower speakers.
How bout this package or will she complain about the size of the subwoofer
[http://cgi.ebay.com/Energy-Take-Clas...d=p3286.c0.m14
Or just get the Mirage Nanosat package your found on ebay.
Or this Polk Audio Speaker set with the Energy ESW-V8 I linked earlier
http://www.newegg.com/Product/Produc...82E16882290093
http://www.energy-speakers.com/na-en...w-v8-overview/
Afro GT
Old 08-19-2009, 12:14 AM
xr4tic's Avatar
I'm looking for the same thing, a 5.1 setup for ~$500, for my basement (aka, Man Cave), aprox 14' x 20'
I haven't purchased a receiver yet, but it will probably be the Pioneer VSX-1019AH-K
I was checking out the Polk speakers on Crutchfield, if you get one of the 5 speaker setups, you can get a polk sub for $100 off, and if you buy $499+ worth of Polk speakers, you get a free pair of Polk OWM3 speakers, so you could do a 7.1 setup for $550.
I'm just not sure which way to go, cheaper surrounds and the better sub, or better surrounds and a cheaper sub, or go in-between
The following combos would give you 7 speakers and a sub for $550
Polk RM75 ($300) + PSW125 sub ($350) + Polk OWM3 (free) - $100 = $550
Polk RM85 ($400) + PSW110 ($250) + Polk OWM3 (free) - $100 = $550
Polk RM95 ($500) + PSW10 ($150) + Polk OWM3 (free) - $100 = $550
Or would I be better off with some of the other options already mentioned?
xr4tic is offline
Old 08-19-2009, 12:51 AM
batpig's Avatar
Liked: 3415
yuck, Polk subs are very mediocre and you don't want some tiny satellites in a "man cave"! the whole reason that crap was invented was to appease wives who didn't want big speakers everywhere.
in summary, be a man and get some big ass towers... those Jamo packages seem to be a great deal.
Setup Guide and FAQ
batpig is offline
Old 08-19-2009, 08:57 AM
xr4tic's Avatar
Those Jamo speakers look interesting, but I'm wondering if having 2 tower speakers is overkill for rear fill?
I also noticed they are 6 ohm impedance, which would place a heavier load on the receiver amp since most are rated at 8 ohms
xr4tic is offline
Old 08-19-2009, 09:49 AM
SoundChex's Avatar
Quoted: 350 Post(s)
Liked: 295
Found [the Def Tech pro-cinema 600], the cheapest they go for is 699 a little out of my budget
The Definitive Technology ProCinema 60.6 is a better fit "budget wise". [But someone else will have to comment on their performance...]
[Home Office system schematic]
"My AV systems were created by man. They evolved. They rebelled. There are many speakers. And they have . . . A PLAN."
SoundChex is online now
Old 08-19-2009, 05:35 PM - Thread Starter
mp2281's Avatar
Bump. Any more recommendations. Picking out speakers is harder the purchasing a home haha
mp2281 is offline
Old 08-19-2009, 05:54 PM
piturra's Avatar
Look into these ... JBL CS6100BG Complete 6-Piece Home Theater Speaker System (Black Gloss) for $414.89 w/FREE Prime SH
Read over the 17 customer reviews for more INFO & consumer level opinions about the JBL's.
piturra is offline
Old 08-19-2009, 06:04 PM
afrogt's Avatar
Liked: 755
Its not overkill for that price!
I've got E680 towers up front and E660 towers as surrounds. I think its awesome. It'll be better than any of the satellites listed.
Any decent receiver should have no problem with the 6 ohm Jamos. I've used them with Onkyo, Denon, HK and Newcastle receivers. No problems with any of them.
Afro GT
Old 08-19-2009, 06:46 PM
MattSibley's Avatar
I have been using these:
http://www.klipsch.com/na-en/product...-5-1-overview/
for almost a year now. They do well on movies and come with wall mount brackets or small stands to place them on a desk or bookshelf. The 8'' subs get down relatively well too. I paid about 450 for this setup and its hard to beat for that price. I have the bookshelfs all running off of my onkyo SR606 receiver and the sound quality improved dramatically over the built in amp. I picked mine up on ebay for about 400 but I've seen some on there recently for 2-300. Might be worth looking into. I'm keeping mine to use in another room in the house.
MattSibley is offline
Old 08-19-2009, 08:06 PM
sluiced's Avatar
What are your opinions on these: http://cgi.ebay.com/NEW-Mirage-Nanos...d=p3286.c0.m14
I spent about 2 hours in Magnolia last night - the Nanosats were rather disappointing in the showroom, though their room is much larger than the space you are considering. Even the larger Mirage OS3-SATs were not as good as I was hoping for.
I'm in the same boat as you - 5.1 system, ~$500 budget, visually and audibly appealing. And unfortunately, I'm finding that something has to give, and it's probably going to be the budget (by a long shot).
sluiced is offline
Old 08-20-2009, 06:31 AM - Thread Starter
mp2281's Avatar
Sluiced, let me know what you decide on =) I'm very curious.
mp2281 is offline
Old 08-20-2009, 11:57 AM
slippery44's Avatar
Quoted: 25 Post(s)
Liked: 24
My advice if you're on a sub $500 dollar budget is just get the best front three you can for that, L/R/C. Then add a sub as your budget allows (I think a good budget sub would be around $200 by itself). Then add the rears on down the road as they are the least important part of the system. If you're anything like me, if you start out with a budget 5.1 system you'll get the upgrade bug pretty quickly and wind up spending more.
I'll throw in my recommendation for a good L/R/C that I use at home. Really good speakers and the dual 6 1/2 on the towers give out a nice amount of bass until you add a sub.
2 infinity primus p362 towers, and a c350 center, $450 not including shipping. (shipping on this site is high though, so would come out to $530 with shipping for me)
http://www.theaudiovideosource.com/InfinityPrimus.html
I've also heard good things about the jamo E680 towers and matching center, I think they'll run you a little less at www.wwstereo.com if they're still available.
I'm sure others may have better 3.0 or even 3.1 recommendation that may make more sense for you budget.
slippery44 is offline
Old 08-20-2009, 12:24 PM
afrogt's Avatar
Liked: 755
Two Jamo E680's and the S60 center will run your $350 shipped but you'll have to call wwstereo.com as it is no longer on their website. And I believe they only have dark apple color now.
Afro GT
Old 08-20-2009, 12:47 PM
afrogt's Avatar
Liked: 755
Old 08-20-2009, 05:36 PM
samsurd2's Avatar
I'm running this set-up. It's about $50 over your budget but worth the stretch IMO.
4 x Polk Audio R150 (http://www.amazon.com/gp/product/B000MGNDHE) $200
1 X Polk Audio CSR (http://www.amazon.com/gp/product/B00...QMP31H0XVW3CJ1) $100
1 x BIC Acoustech H-100 (http://www.shop.com/BIC_Acoustech_H_...l?sourceid=298) $249
samsurd2 is offline
Old 08-20-2009, 06:10 PM
afrogt's Avatar
Liked: 755
If you're gonna do Polk bookshelf speakers, go with these. Better tweeters than the R series.
Monitor 40
http://www.newegg.com/Product/Produc...82E16882290010
CS1 center
http://www.newegg.com/Product/Produc...82E16882290022
Monitor 30 surrounds
http://www.newegg.com/Product/Produc...82E16882290094
Total is $329
You can still get this Bic sub and be close to your $500 total.
http://www.audio-discounters.com/f12.html
Afro GT
Old 08-21-2009, 02:13 PM
samsurd2's Avatar
^^ Definitely a good alternative if the OP has room for the Monitor 40. I mention this because I didn't and, having listened to the similarly sized Monitor 30s and R150s side by side, decided on the R series.
samsurd2 is offline
