Decent (or shall I say cheap) 2.1 setup? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 18 Old 08-24-2009, 03:08 PM - Thread Starter
Fragster's Avatar
Quoted: 27 Post(s)
Hey Guys
Been a while since I posted (or browsed this section)....anyway, I'd like to set up a decent 2.1 system for my main living room. Because of the room layout, pulling a 5.1 would be tough so 2.1 would do. Right now, we are using the TV speakers so even a 2.1 setup would be a huge upgrade. My TV is a 57" Hitachi S500 RPTV (holy grail when it came out 1000 years ago).
I can't do floor-standing as we have a 'whole-wall' entertainment unit which houses the TV but it does support bookshelf speakers and possibly a smaller sub.
I will use my older Onkyo 504 receiver to power this setup. I'm not expecting theater sound as I already have my HT setup upstairs that is used for serious movie watching. Trying to keep the setup under $300.
Any suggestions? Any deals?
"There are 1 0 kinds of people in this world...one that can read binary while the other that can't!!"
My small HT setup:
http://www.flickr.com/photos/27565515@N04/
Fragster is offline
post #2 of 18 Old 08-24-2009, 04:33 PM
afrogt's Avatar
Quoted: 1059 Post(s)
Liked: 763
Originally Posted by Fragster View Post
Hey Guys
Don't know how small the bookshelf speakers need to be but perhaps some Polk Monitor 40's?
http://www.newegg.com/Product/Produc...82E16882290010
Energy C-200
http://www.amazon.com/gp/offer-listi...1152999&sr=8-1
http://www.energy-speakers.com/na-en...-200-overview/
or possibly some bookshelf speakers from The Speaker Company
http://www.thespeakercompany.com/TSB...ir-P46C27.aspx
Small 8" subwoofer
http://www.thespeakercompany.com/ASW...oofer-P61.aspx
Any of those combos will get you out the door under $300 shipped.
Afro GT
afrogt is offline
post #3 of 18 Old 08-24-2009, 05:44 PM
malovich's Avatar
Dimensions of the cabinet would help alot!
I'd start with http://www.parts-express.com/pe/show...number=300-390
leaving 200 for the mains.....
Athena ls-100's go for ~$100/pair here, you could get an mirage omni which is a MATCHING center for the ls speakers here
or
infinity beta 20 bookshelves
or
TSC TSBL
or
SVS SBS-01
or
Insignia NSB-2111
or
av123 elt525
XBL Krimzen Rage
malovich is offline
post #4 of 18 Old 08-24-2009, 05:48 PM
11427's Avatar
Ok,...
How about;
Yamaha NS-333
Dayton SUB-120 HT or SUB-100 HT
This combo just may surprise you considering the price. I know MSRP is about $50 over your budget,... but that is MSRP and there are deals to be found.
Mark
11427 is offline
post #5 of 18 Old 08-24-2009, 08:50 PM
Knucklehead90's Avatar
Quoted: 391 Post(s)
Liked: 335
Get either a front ported or sealed speaker design. Sticking a rear ported speaker up against that entertainment center would muffle the bass and cause it to resonate.
A pair of Infinity Primus P162s @ $69.99 each might work well, they are front ported and their cost leaves room for a sub.
EDIT: I forgot to add the sealed speakers in - a pair of Emotiva ERM-1s will eat up that budget but they do sound very good - and being a sealed design won't cause funny noises inside a bookcase setting if they are isolated with a small rubber pad or other means. At 149$ each on closeout they are a real steal. Add a sub later - they need one to fill out the sound.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #6 of 18 Old 08-24-2009, 11:14 PM - Thread Starter
Fragster's Avatar
Quoted: 27 Post(s)
Thanks Guys
I'm looking at the above options right now.....I can probably fit either one of the combos above....
Appreciated.
My small HT setup:
Fragster is offline
post #7 of 18 Old 08-24-2009, 11:15 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
For speakers check out Tweak City Audio's WAF-1's. They are $229.00/pair including shipping.
My journey to find the "perfect" speaker
No matter what measurements tell us, a loudspeaker isn’t good until it
sounds good. - Dr. Floyd Toole
Nuance is offline
post #8 of 18 Old 08-25-2009, 10:51 AM - Thread Starter
Fragster's Avatar
Quoted: 27 Post(s)
Okay...I've come to these....which one is better?
- 2 X Athena LS100+Mirage Omni center = $200 approx
OR
- Energy Take Classic 5 Pack 5.0 Home Theater Speaker (Close-out) $199
http://www.amazon.com/gp/product/B00...pf_rd_i=507846
I have the Inifinty P362 towers in my main HT room and I like them a lot so while I'm inclined to the P162's, I notice they don't go as low as the Athenas above. Am I reading this correctly that based on this , the Athenas would handle lows better than the P162's?
PS: I know the Amazon is 5 speaker setup and I only need 2.1 but I'm looking at the price range.
My small HT setup:
Fragster is offline
post #9 of 18 Old 08-25-2009, 10:58 AM
PioBeer's Avatar
Quoted: 14 Post(s)
Nuance, have you heard the WAF-1s yet? Do you think they are the best bookshelf for the money?
"Reckon I get me some fried po'taters mmm hmmm"
PioBeer is offline
post #10 of 18 Old 08-25-2009, 11:41 AM
afrogt's Avatar
Liked: 763
OR
For what you're doing I wouldn't get the Take Classic. Go with the Athena or Infinity for bigger and better sound. The Take Classic will be thin sounding for music.
I'm not sure where you getting your info but he P162's do go lower than the Athena LS-100.
LS-100
Frequency response: 55 Hz - 20 kHz
Sensitivity: 87 dB
Power handling: 120 WRMS
Dimensions: 12.8" tall, 7" wide, and 9.7" deep
Weight: 11 lbs.
P162
• 10 To 150-Watt Power Amplifier Range
• 8-Ohm Nominal Impedance
• 0.75" MMD Tweeter
• 6.50" MMD Woofer
• 3,000 Hz, 24 dB/Octave Crossover Frequency
49 Hz To 20 kHz Frequency Response (+/-3 dB)
• Magnetically Shielded
• 90 dB Sensitivity (2.83 V @ 1 m)
• Dimensions: 8.25" W x 14.75" H x 10.50" D
• Weight: 16.1 lbs
The P162 is taller, larger, heavier and has a bigger woofer. It does play deeper than the Athena! Plus a 3db higher sensitivity so it'll play louder at the same volume level.
You're also comparing two speakers and a center vs just two bookshelf speakers. Which do you prefer?
Afro GT
afrogt is offline
post #11 of 18 Old 08-25-2009, 01:04 PM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
I will be ordering a pair this week and will post my impressions a couple weeks later. I want to spend some quality time with these little bad boys. I have heard the yet to be produced Panache speakers (I heard the prototype, and they are expected to sell for less than the WAF-'s as they contain one full range 3" driver...that's if they are in fact brought to the market), and they bested the NHT Classic 2's I compared them to. Craig says the WAF-1's are better than the Panache's, so I expect good things from this speaker, especially for only $229. Do I think they will be giant killers? No. But do I expect great performance for a very low price? Absolutely.
Nuance is offline
post #12 of 18 Old 08-25-2009, 02:25 PM
afrogt's Avatar
Liked: 763
Are the WAF-1's really better than NHT Classic Two's? That would be impressive.
Afro GT
afrogt is offline
post #13 of 18 Old 08-26-2009, 12:23 AM
Nuance's Avatar
Quoted: 21 Post(s)
Liked: 77
Just to be clear, the WAF-1's were not the speakers I heard. I heard a speaker of lesser sound quality and cost. However, in that room, using those electronics and to my ears, yes, they bested the NHT's. But that's just my opinion; yours may differ. Give them a listen if you can and let your ears decide.
Nuance is offline
post #14 of 18 Old 08-26-2009, 03:18 PM
gye
gye's Avatar
I will be ordering a pair this week and will post my impressions a couple weeks later. ....
Can't wait to hear that review!
I'm really happy with my front speakers (Athena LS-300) for home theater but for 2-channel music they leave a lot to be desired. I've considered adding a pair of Emotiva ERM-1s but I would have to get a 2-channel amplifier to go along with them, bringing the total price tag to over $600. If the WAF-1s are as good as expected, it'd be a more cost-effective way to appease the upgraditis bug.
gye is offline
post #15 of 18 Old 08-26-2009, 04:17 PM
afrogt's Avatar
Liked: 763
What don't you like about your Athena LS-300s for music? I have the older AS-F1s but they have a larger woofer and completely different tweeter.
Afro GT
afrogt is offline
post #16 of 18 Old 08-26-2009, 04:27 PM
Slare's Avatar
Slare is offline
post #17 of 18 Old 08-26-2009, 09:31 PM
gye
gye's Avatar
Not detailed enough for music, even a bit muddy at times. I feel that I can get more details from my Bose In-Ear headphones (no flaming please; they were a gift ). Also at high volume levels (over 80db at listening position), I can sense a bit of distortion. And it doesn't help that I have a cheap subwoofer.
On the other hand, they do great with HT, and I love these speakers for what they are. Considering I only paid $88 shipped each, they were a great deal.
gye is offline
post #18 of 18 Old 08-26-2009, 10:08 PM
afrogt's Avatar
Liked: 763
They must be way different than my F1's then. No one would ever mistake the F1 for being muddy sounding. The F1's have always been called detailed or even bright sounding. Must be a complete sound change between the LS and old AS series.
We've always suspected the LS series used the same drivers as the Energy C-series such as the C-100, 200 and 300. Those speakers are more neutral and some have called the smaller bookshelf speakers a little muddy.
Afro GT
afrogt is offline
Reply Speakers
