sound-proofing and in-wall/ceiling speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 09-27-2009, 09:04 PM - Thread Starter
reddog11's Avatar
Hey everyone,
I recently joined the forum because I needed some help with the tentative AV system in my new house (under construction, so this is the perfect time to work this stuff out).
My newest question is this: for those of you who have used in-wall/in-ceiling speakers, have you found that the sound leaks through to the next room more so than with floor-standing or bookshelf models? Soundproofing is a consideration in this home and we are double drywalling the whole thing, with green glue sandwiched in between the two layers for dampening. In-wall/ceiling speakers are the best option for us aesthetically, but I obviously don't want to waste all the $$ we're spending to block sound, either.
I searched through the forum and found a bunch of threads on in-wall and insulation, but couldn't locate anything that dealt specifically with sound-proofing. Any insight is much appreciated!
reddog11 is offline
post #2 of 3 Old 09-27-2009, 09:52 PM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
Just be sure the in-walls/ceilings have dedicated enclosures. They'll sound better and reduce sound transmission at the same time.
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #3 of 3 Old 09-29-2009, 06:32 AM
Ted White's Avatar
Quoted: 12 Post(s)
Liked: 44
This is a big compromise to your sound isolation. You lose the air cavity space in the wall, and any backer box will likely be very lacking in terms of mass and damping.
__________________
Ted
The Soundproofing Company
Ted White is offline
Reply Speakers
