Mythos Seven a good choice? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 10-10-2009, 07:31 PM - Thread Starter
EricU's Avatar
Is the Definitive Technology Mythos Seven a good choice for a center channel speaker in my master bedroom?
I will be using a pair of MB Quart QLS 1030 floor speakers for the front. A pair of in-ceilings mounted in a vaulted ceiling for the rear.
I dont have the sub, Blu Ray player or the reciever yet. I will probably go with a mid-range Onkyo or Pioneer for the reciever.
The system will be mostly used for general tv, sports and movies.
Thanks for any help, Eric.
EricU is offline
post #2 of 7 Old 10-10-2009, 08:33 PM
mbyrnes's Avatar
Quoted: 98 Post(s)
Liked: 199
Why not use the MB Quart QLS 330 center instead? It would be voice matched to your fronts. The Def Tech or any other line for that matter would not be the same. It is always ideal to go with the same series for the fronts.
Xbox Live: TheRealMaxPower --- PSN: BeyondMaxPower---- Vizio P75-C1    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S, PS4 Pro, Astro Mixamp 2013, Soundblaster X7 (Sparkos Op Amps), Schiit Modi Multibit/Magni, LTA MicroZOTL2 headphone amp, Hifiman HE-X V2, AKG K702 65th Anniversary, Fostex TH-X00 Ebony, Monoprice Monolith M1060 (Vegan pads), DT990 Pro 250 ohm, Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #3 of 7 Old 10-10-2009, 09:13 PM - Thread Starter
EricU's Avatar
It is already being used in another room with another system.
Eric.
EricU is offline
post #4 of 7 Old 10-10-2009, 09:40 PM
ickysmits's Avatar
Do you have another pair of MB Quart QLS 1030 floor speakers in the other room?
ickysmits is offline
post #5 of 7 Old 10-11-2009, 04:59 AM
Mantis10's Avatar
I feel the same way, The Mythos center is not a good match.
Mantis10 is offline
post #6 of 7 Old 10-11-2009, 05:49 PM - Thread Starter
EricU's Avatar
Is there a reason that the Mythos Seven would not be a good match for this set up? Why?
What would you consider a good match?
Eric.
EricU is offline
post #7 of 7 Old 10-11-2009, 08:51 PM
mbyrnes's Avatar
Quoted: 98 Post(s)
Liked: 199
Voice matching. Fronts and centers from the same line usually have the exact same tweeter and woofers. They are designed so a panning effect is seamless. This is almost impossible to do with different brands. Even in the same company, lines can sound very different with voice matching.
Try to find a used matching center if no longer made. audiogon is a good source.
mbyrnes is offline
Reply Speakers
