Help with surround speakers...OPTIONS! - AVS Forum | Home Theater Discussions And Reviews
Old 10-19-2009, 11:29 PM - Thread Starter
radelow's Avatar
Hi everyone. Need some assistance in picking our my surround sound channel. Fronts are Magnepan for sides and center. As you can see from the photo below I have two options. Either put speakers in the ceiling or mount them on a small wall area facing the TV (albeit farther back). The speakers, if mounted on the wall area would have clear space between them and the couch (the drawing isn't clear about that). The scale is on the bottom right.
What do you guys recommend for location and, based on that location, what speaker would you recommend? I want to be all in for the TWO surround speakers at no more $650.
radelow is offline
Old 10-20-2009, 05:46 PM - Thread Starter
radelow's Avatar
48 people look at this and not a single person has a recommendation??? WOW!!!!
radelow is offline
Old 10-20-2009, 07:38 PM
Kal Rubinson's Avatar
Quoted: 685 Post(s)
Liked: 468
Difficult to understand diagram.
Difficult to understand some of your sentences.
Someone will chime in.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
Old 10-20-2009, 08:23 PM - Thread Starter
radelow's Avatar
Ok...
- TV on right wall facing to the left
- Couch Facing TV
- Should I put in mounted speakers at point A which are significantly behind the couch or In-Ceiling speakers at point B closer to the couch.
radelow is offline
