LCR + LR Surround vs. 5 matching speakers - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 10-30-2009, 01:56 PM - Thread Starter
waltzonice's Avatar
Our house is prewired for in-wall 5.1 speakers -- 3 on the TV wall, and LR surrounds on the side walls.
I've been getting bids from custom installers and I'm getting conflicting opinions as to whether I should have all 5 speakers matching, or if I should get Front LCR's matching, but using dipole or some other type of side surround speakers.
I'm curious to get some opinions on this. Under what circumstances (room size, ceiling height, speaker placement, etc), would it be beneficial to choose one over the other?
waltzonice is offline
post #2 of 5 Old 10-30-2009, 02:18 PM
ifor's Avatar
Quoted: 65 Post(s)
Liked: 72
depends, where are the surround placemect in relation t othe sitting area? beside, in front, behind? how many feet behind or in front?
ifor is online now
post #3 of 5 Old 10-30-2009, 03:17 PM
osofast240sx's Avatar
take some pictures of your room and post them. go with the AV shop that will setup both in your house to show you the difference.
osofast240sx is offline
post #4 of 5 Old 11-01-2009, 11:10 AM - Thread Starter
waltzonice's Avatar
I'm more interested in what are the "rule of thumb" or opinions on when you would use one over the other. So far I don't feel like any of the installers explained why they chose one over the other... just that they they thought it was "better".
But for the record, I have a very large great room -- approx 20' x 30' that consist of the living room (TV area), then a large dining table, then the island and then the kitchen. It has vaulted high ceilings, with the highest point around 19'. The pre-wire for the surrounds are on the left side and right side of the walls, kind of in between the living area and the dining table -- around 11 feet up.
Thanks in advance!
post #5 of 5 Old 11-01-2009, 12:21 PM
sptrout's Avatar
I guess the "rule of thumb" is that all should be the same, or at least from the same manufacturer and speaker family. I would not recommend that you place the surrounds at 11' unless your whole 20x30' room is the "viewing area." Typically, you want the surrounds a little above ear level at the main listening location. The "Ear level" rule applies to all main speakers for that matter.
For your five (or seven) main speakers, concentrate on where they should be located in reference to your "viewing" area. The rest of the room(s) is of less concern except for the subwoofer(s).
sptrout is offline
Reply Speakers
