JBL Pro Cenima Which model??? - Page 16 - AVS Forum | Home Theater Discussions And Reviews
 6Likes
post #451 of 458 Old 10-17-2010, 10:31 AM
Wilber's Avatar
Quoted: 14 Post(s)
just curious,
how come no one compares with 8330a?
Wilber is offline
post #452 of 458 Old 10-19-2010, 03:36 PM
billqs's Avatar
Quoted: 291 Post(s)
Liked: 171
Originally Posted by Wilber View Post
just curious,
I have the 8330 jbls and they sound great to me. I don't have room for actual pro fronts, but I get great sound using the 8330's for this purpose. I am looking at trying out the 8340a's as a possible successor to the 8330's as I am thinking that the 8340a's use of a horn tweeter would better recreate the sound of a cinema auditorium, but I have nothing against the 8330's at all.
I am curious how the old 8330 mdf speakers compare with the 8330a's molded plastic enclosure. Do you know if it is sufficiently damped?
JVC RS500, Denon 7200WA, 7.2.4 Atmos/DTSX dedicated Theater. 133" Dalite 1.3 screen. M&K S150 + K7 ear level, 4 Tannoy DC overheads.
billqs is offline
post #453 of 458 Old 10-19-2010, 04:43 PM - Thread Starter
cdy2179's Avatar
Quoted: 737 Post(s)
Liked: 427
I wasn't a huge fan of the 8340a (a little harsh) but many like it as a surround...but having the 3677s and hearing how long the CD takes to break in....it's very possible I didn't give them enough time to break in although I did put about 80 hrs or more on them.
cdy2179 is online now
post #454 of 458 Old 06-09-2013, 07:49 PM
pdxrealtor's Avatar
Quoted: 141 Post(s)
Liked: 151
Old thread I know.... so... cdy- you did end up with the 3677s? I see you're name around but right now I can't recall what you're currently using.
pdxrealtor is offline
post #455 of 458 Old 03-29-2014, 09:11 AM
Skylinestar's Avatar
Quoted: 1056 Post(s)
Liked: 184
What's the advantage of 4722N over the 3622N other than higher power handling? Is there any audible sonic difference?
If these were to be installed in a typical room, I doubt the extra power capacity is required.
Skylinestar is offline
post #456 of 458 Old 04-01-2014, 12:10 PM
Reddig's Avatar
Quoted: 161 Post(s)
Liked: 306
The 4722 has a larger CD, upgraded woofers, and a lower crossover point
JBL Pro Cinema/PSA&HSU subs/Crown power/Sony SXRD
MANCHESTER UNITED!!
Reddig is offline
post #457 of 458 Old 05-01-2014, 12:14 AM
Liked: 184
Lot's of discussions about 8340A. I have a question:
My living room is 15'x25'x9'. Screen to seat distance is 11'. That means my setup is on the front half of the room. I only have a single row of seating.
Will 2 units of 8340A (as in 5.1 setup) be sufficient for my space? Or do I need to use 4 units (as in 7.1 setup)?
post #458 of 458 Old 05-31-2015, 08:34 AM
wse
wse's Avatar
Quoted: 1991 Post(s)
Liked: 741
Big, ugly. and unfinished cabinets
Right and less marketing with inflated prices! Veneer any one?
csnow likes this.
wse is online now
Reply Speakers
