Cannon TLS passive radiators - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-08-2009, 06:47 PM - Thread Starter
halo71's Avatar
I have a pair of these, the tower version. The flat radiator has long since bit the dust. Rather than find replacements. I just stuck some cheap 12" woofers in them to fill the holes. Is this sufficient or will actual radiators sound better? If so, where can I find them?
Also the stock (active) woofers surround rotted away years ago. I bought some Eminence woofers to replace them with. And have recently wanted to upgrade them. Any ideas about a good replacement driver? I know, I should have bought a surrounds replacement kit but I didn't. And somehow the original speaker cones/baskets got tossed out at some point.
halo71 is offline
post #2 of 7 Old 11-13-2009, 02:18 PM - Thread Starter
halo71's Avatar
Anyone....anyone?
halo71 is offline
post #3 of 7 Old 11-16-2009, 04:50 AM - Thread Starter
halo71's Avatar
Am I asking the wrong question or something? Or does nobody know? I have found radiators online, ones that look like a regular driver. The ones I want are the flat faced ones like came in these speakers. Like ones that came in the old Polk's.
Anyone?
halo71 is offline
post #4 of 7 Old 11-15-2012, 11:28 AM
cannon tls 1020's Avatar
I just saw your post today.
It has not been until recently that I have seen replacement parts available. I love my Cannon TLS 1020
speakers that I bought new in 1978 and can now replace the surrounds and passive radiators.
Check out
http://www.simplyspeakers.com/search.asp?keyword=cannon&search.x=16&search.y=9
cannon tls 1020 is offline
post #5 of 7 Old 11-15-2012, 02:50 PM
JerryLove's Avatar
Liked: 79
The mass won't match the designer's spec and the voice-coils will introduce resistance. It will signifigantly alter the sound.
If you don't match impedance and sensativity, then the crossovers will not be correct. If you don't match needed volume (in ft^3), or adjust the volume of the chamber accordingly, then the drivers will not be damped properly. In both cases, sound will be adversely affected.
JerryLove is offline
post #6 of 7 Old 06-25-2015, 02:35 PM
dbf909's Avatar
I have a set of Cannon TLS 1032s that I also purchased new in 1979. Many years ago (20?) the passives gave up and disintegrated. There were no replacement parts available (no internet either ???) so the best I could do was pick up a set of relatively cheap 10" drivers, knock the magnets off, and install them. Interestingly, this did not change the tone of the speakers much at all. I was not expecting them to sound anywhere as good as they had with factory passives but the new ones I crafted were a pretty decent match.
They are still holding up very well - no visible degradation of the foam surrounds at all and still sound great.
Now, it appears that replacement parts are available everywhere so I plan to pick up some from either Simply Speakers or Orange County and put them back closer to factory spec. It will be interesting to see if I can detect a tonal change this time...
dbf909 is offline
post #7 of 7 Old 06-25-2015, 06:10 PM
Red99's Avatar
Quoted: 772 Post(s)
Liked: 415
Red99 is offline
Reply Speakers
