Polk CSi3 and RTi A5 together - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 11-13-2009, 11:01 AM - Thread Starter
overwilhelmed's Avatar
Hi all -
Just a quick question. I have found the CSi3 for a reasonable price all over the wonderful internet and it seems to be the "prior" version of the CSi A4. I picked up the RTi A5 (sound great btw) and I want to make sure everything sounds good on the front end.
Would the CSi3 be a suitable supplement for the CSi A4, or should I hold out until I find the A4 on sale or something?
Thanks for the help!!!
PS3 Gamer Tag: WastedSauce
360 Gamer Tag: Thrillhelm
overwilhelmed is offline
post #2 of 9 Old 11-13-2009, 11:08 AM
chrisfromalbany's Avatar
Originally Posted by overwilhelmed View Post
Hi all -
in the same family.. looks good to me..
chrisfromalbany is offline
post #3 of 9 Old 11-13-2009, 11:20 AM
Stephen Hopkins's Avatar
Looks like the only changes are aesthetic, and in the center that's pretty much limited to the baffle. I doubt there would be any sonic difference.
Stephen Hopkins is offline
post #4 of 9 Old 11-13-2009, 11:32 AM
Erik Tracy's Avatar
Hi all -
I have a CSi3. It was originally paired with my RTi4s in my small and modest HT setup.
I since upgraded to the RTiA3s and still use the CSi3. The pairing is still very good.
The CSi3 and CSiA4 are very comparable in sound - I would not worry about any drastic differences.
But in your case since you are running RTiA5s - I'd seriously consider you look for a deal on the CSi5 or CSiA6 since the bigger brother series would be a better match driver-wise with your RTiA5s.
Polk's eBay direct source has had some very good deals on CSi5s - not sure if there are any still, but they do show up from time to time.
Just my small 2cents worth....
Erik Tracy is offline
post #5 of 9 Old 11-13-2009, 11:40 AM
cornhulio's Avatar
If you listen to any music you will need to upgrade the tweeter to get rid of the brightness like I've done: http://www.avsforum.com/avs-vb/attac...hmentid=152794
Polk SL2000WC $3 DIY mod. Smaller the uf, the less harsh your SL2000 is.
1. SRS: .47 uf/250v mylar cap top SL2000, 1.0 2nd, 1.0 3rd, .47 bottom
2. 2.3: 1.0 middle
3. 1C: 1.0 top
4. 2B: 1.0
cornhulio is offline
post #6 of 9 Old 11-13-2009, 12:07 PM - Thread Starter
Welp, thats all I need. I have had enough of the HTIB center channel being pwned by the RTi's. Order is being processed :-)
post #7 of 9 Old 11-13-2009, 12:10 PM
cvpartridge's Avatar
Quoted: 13 Post(s)
I really would do the CSI5 or CSI a6, much improved from the Cs2 I owned before.
Denon AVR-X4000W
LCR - Elusive 1099
Surround - Volt-10 LX
2x Dayton UM-15 Sealed (INuke 6000DSP)
2x MBM-12 (DIYSoundgroup - Inuke 3000DSP)
cvpartridge is offline
post #8 of 9 Old 11-13-2009, 12:12 PM - Thread Starter
I have a "cozy" set up. Since the CSi3's are from the same family. They will work for my set up. If I expand my entertainment space, I will then consider upgrading to a more adequate center channel. But for my space I think the CSi3 will be more than enough.
post #9 of 9 Old 11-15-2009, 07:49 AM
leroyjr1's Avatar
That sl2000 tweeter is just as bright as the original.
leroyjr1 is offline
Reply Speakers
