Need Help - looking for in ceiling "blanks" - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 11-22-2009, 02:41 PM - Thread Starter
sp1dey's Avatar
In the process of relocating and about the list the house. I have B&W in ceiling speakers that I DO NOT want to leave for the next owner. Choice number one is to buy cheapo replacements, choice number two is to buy blanks to fill the voids left when i remove my speakers. Can someone point me to a website or store where I can find "blanks"... I've been trying to find something online without much luck. Thanks in advance!
sp1dey is offline
post #2 of 7 Old 11-22-2009, 10:16 PM
robbom's Avatar
Maybe you could just use a dummy grill cover. Line the inside with some black paper if any light comes through.
http://www.parts-express.com/wizards...TOKEN=76796913
robbom is offline
post #3 of 7 Old 11-23-2009, 08:50 AM - Thread Starter
sp1dey's Avatar
Yeah I thought about that, but it's code I have either a replacement speaker or a solid plate covering the opening (depending on the home inspector, it could be an issue). Going to call a local installer to see what they may have, otherwise I'll grab some cheapo's from monoprice or the shack.
sp1dey is offline
post #4 of 7 Old 11-23-2009, 01:09 PM
DocCarbon's Avatar
Air registrar duct grills ? What size are the openings ?.
Stuff insulation and cover with the above units .
DocCarbon is offline
post #5 of 7 Old 11-23-2009, 01:12 PM
bullitt_60's Avatar
If I'm a buyer, I want you to replace them not just do a cover up.
bullitt_60 is offline
post #6 of 7 Old 11-23-2009, 03:58 PM
kwkshift's Avatar
Have a drywall/ painter come in and just patch the holes.
kwkshift is offline
post #7 of 7 Old 11-23-2009, 05:50 PM - Thread Starter
sp1dey's Avatar
I decided to just go the monoprice route, they are an exact fit... hoping to get away cheap on it, but ultimately I want the house to sell and a few hundred bucks to replace the in ceilings throughout the house is worth it. Still cheaper then leaving even one set of the B&W's.
sp1dey is offline
Reply Speakers
