Suspended speaker - AVS Forum | Home Theater Discussions And Reviews
post #1 of 17 Old 11-22-2009, 11:08 PM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
I get some "different" ideas in my head sometimes. I was wondering if suspending the speakers (bookshelfe size) from the cieling would improve their sound at all. Figure nothing around them for many feet. I think the idea sounds kind of cool!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
karlsaudio is offline
post #2 of 17 Old 11-23-2009, 12:18 AM
win200's Avatar
I can think of few things that would reduce the sound quality of speakers so efficiently.
TV: LG OLED65B6P
Processor: Classe Sigma
Amp: Classe CAV-500
Player: OPPO UDP-203
Speakers: B&W 804s, B&W HTM3s
Sub: JL Audio F110
win200 is offline
post #3 of 17 Old 11-23-2009, 10:52 AM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Just a thought. So speakers do need some kind of a soundboard behind them? I thought it was quite the opposite with people spending thousands on baffels and deadoning.
I don't plan on doing it but, I just wanted to see what people thought.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #4 of 17 Old 11-23-2009, 02:08 PM
halo71's Avatar
While I have never thought of doing it, nor had a reason. I know speakers sounds better sitting on the floor or on spikes. But I have always wondered how/why suspended speakers, subwoofers in general, sound so nice at concerts....well some concerts that is.
halo71 is offline
post #5 of 17 Old 11-23-2009, 06:13 PM
Montekay's Avatar
Quoted: 28 Post(s)
Liked: 31
Being close to a surface like the floor reinforces low frequency but otherwise there is no advantage. Being moved out away from walls, floor etc is actually a good thing. Normally for critical listening from a single sweet spot having the tweeter about ear level or slightly higher is best. Many speakers sitting on the floor place the tweeters too low. Suspending them may put them too high but to me too high is better than too low. Personally I have found it to work well to suspend them from the ceiling. Compared with sitting on the floor they may seem to have less bass but overall they will likely sound better suspended.
mk
Montekay is offline
post #6 of 17 Old 11-23-2009, 06:20 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
I used to suspend my JBL booshelf speakers from the ceiling because I really didn't have room to put them anywhere else. Didn't want to drill holes in the wall since it was an apartment.
They worked fine! I used some netting with metal rings at each end that I found at an army surplus store. I got some ceiling plant hooks and it was a very inexpensive setup.
Afro GT
afrogt is offline
post #7 of 17 Old 11-23-2009, 11:34 PM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
I might actually try that. I was thinking of some kind of plate the speaker would sit on and have four wires run up to the ceiling. Being carefull not to "dump" them. You could make it look kind of cool. Have very thin wire and they would look like they are floating with the lights dimmed!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #8 of 17 Old 11-23-2009, 11:51 PM
video_bit_bucket's Avatar
Confession; I have been using a pair of Paradigm Studio 100's inverted to get the tweeter at ear level while keeping the entire speaker behind my AT screen. This was the only way they would fit with the tweeter at the right level and none of the woofers behind the screen frame. These speakers are a 43 inch, 70+ pound floor standing design. The distance to side and rear boundaries is critical but hanging upside down (chains to floor joists, have a lay in ceiling) they have done fine.
I have a room correction system in my pre pro and it was very happy working with the inverted speakers.
video_bit_bucket is offline
post #9 of 17 Old 11-24-2009, 12:17 AM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Awesome! I think we are on to something here!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #10 of 17 Old 11-24-2009, 12:46 AM
boulderdashcci's Avatar
I'd be very interested in seeing pictures of that.
boulderdashcci is offline
post #11 of 17 Old 11-24-2009, 08:14 AM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Me too!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #12 of 17 Old 11-30-2009, 01:06 AM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
I have looked at Lowes for all the parts I need. I will be using large "plant" hooks that have the anchor on the other side of the sheetrock. I found pre finished wood shelving to place the speakers on. This will be suspended with fine wire at each corner. I will have to test for proper accoustic spacing first before I screw the hooks in. I have all the heights figured out but, I will have to see how the speakers react with the walls. It will be cool!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #13 of 17 Old 11-30-2009, 03:12 AM
craig john's Avatar
Quoted: 513 Post(s)
Liked: 718
How are you going to deal with the speaker wire?
Lombardi said it:
Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #14 of 17 Old 11-30-2009, 07:34 AM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
It will have to go down one of the suspension wires. Before I do this, I also have to consider the two cats I have that might think I built them a trapize!
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #15 of 17 Old 12-01-2009, 07:55 AM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
OK, my idea had a very low WAF factor. Oh well.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
post #16 of 17 Old 12-02-2009, 11:36 PM
win200's Avatar
WAF factor
Redundant
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #17 of 17 Old 12-03-2009, 02:47 PM - Thread Starter
karlsaudio's Avatar
Quoted: 138 Post(s)
Liked: 54
Redundant, I know. Sorry. Well, I will be putting them on stands in the front and shelves in the rear.
Sounds good!
AVR: Denon 1913
L/R: Polk RTiA1
Center: Polk CSi3
Sub: Polk PSW505
Reply Speakers
