Such thing as high-end on-walls? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 11-22-2009, 11:13 PM - Thread Starter
win200's Avatar
So, I've got a 50" plasma coming my way to replace my CRT behemoth, and I'm strongly thinking of installing on-wall speakers across the front in order to reduce clutter. However, I'm concerned about sacrificing sound quality.
My electronics are relatively high-end: I use a Krell Showcase pre-pro, a Primare five-channel amp, and a Cambridge Audio CD player. I currently have three Monitor Audio RS1s across the front, and would like a definite step up in terms of sound quality.
I'm just having the damndest time trying to find a relatively small solution with top-notch sound quality. The budget for the L/C/R is about $3k. I was looking at the Artison Masterpieces.
Any suggestions? I have zero familiarity with on-wall speakers...
TV: LG OLED65B6P
Processor: Classe Sigma
Amp: Classe CAV-500
Player: OPPO UDP-203
Speakers: B&W 804s, B&W HTM3s
Sub: JL Audio F110
win200 is offline
post #2 of 20 Old 11-22-2009, 11:27 PM
nixonrsx's Avatar
Check out the Paradigm Cinema 330's and then Atlantic Technology FS-3200LR.
nixonrsx is offline
post #3 of 20 Old 11-23-2009, 01:55 AM
gchanjam's Avatar
Take a look at Triad On Wall Gold Minimonitors and ERA PL 24s.
gchanjam is offline
post #4 of 20 Old 11-23-2009, 06:04 AM
Paul Scarpelli's Avatar
Liked: 56
Because the Triad OnWall Gold MiniMonitor is $2,150 each, they may kill your budget. The OnWall Bronze LCR is $900 each, more sensitive, and made for use with a subwoofer.
There are quite a few decent onwall fronts, including Artison. The smaller onwalls tend to not have much response under 200 Hz, though, regardless of their claimed spec.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #5 of 20 Old 11-23-2009, 07:48 AM
kwkshift's Avatar
Vienna Acoustics Waltz Grand and the Webern's are very nice and they will fit your budget. You could also look at Leon Speakers and the Artisons.
kwkshift is offline
post #6 of 20 Old 11-23-2009, 11:33 AM
Liked: 56
I agree with Vienna Acoustics, but I am not familiar with Webern. Dali is very good, too.
Paul Scarpelli
aka TRIAD DUDE
post #7 of 20 Old 11-23-2009, 11:55 AM
osiris13's Avatar
Paradigm Studio Esprit
osiris13 is offline
post #8 of 20 Old 11-23-2009, 11:56 AM
markwriter's Avatar
Revel has on-walls. M10, C10, etc.
markwriter is offline
post #9 of 20 Old 11-23-2009, 02:28 PM
Ben_Tech's Avatar
Ben_Tech is offline
post #10 of 20 Old 11-23-2009, 02:30 PM
swgiust's Avatar
Quoted: 26 Post(s)
Ditto on the Paradigm Studio's
swgiust is offline
post #11 of 20 Old 11-23-2009, 02:51 PM
atisvt99's Avatar
check out www.sunfire.com and their Cinema Ribbon series of speakers... the 2's will come in well under your budget and the 3's should be right there at it. I've installed a couple of the CRM-2's and they are an amazing speaker for the size... I'm looking to do a system here soon with the CRS-3's...
While I don't currently have a room worthy of these speakers (IMHO) I have been using Sunfire subs for years now... I love the sound, quality of build, etc of their products...
atisvt99 is offline
post #12 of 20 Old 11-23-2009, 03:01 PM
Liked: 56
All great suggestions...Paradigm, Revel, and Totem.
Paul Scarpelli
aka TRIAD DUDE
post #13 of 20 Old 11-23-2009, 03:08 PM
Monty Williams's Avatar
M&K or MKSound S-150 THX Ultra's or MPS Professional Series, Klipsch THX Ultra.
Monty Williams is offline
post #14 of 20 Old 11-23-2009, 04:14 PM - Thread Starter
win200's Avatar
Thanks for all the feedback; I frankly wasn't aware that brands as prestigious as Revel, Totem, etc. made on-walls.
A final question... the other option I was consider was to go B&W across the front, with a pair of 805s's and an HTM4s. Would that setup simply blow any of the on-walls out of the water?
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #15 of 20 Old 11-23-2009, 04:48 PM
craig john's Avatar
Quoted: 569 Post(s)
Liked: 808
Include in that list Triad and Atlantic Technology, and you have a better list.
IMO, that depends more on setup than anything else. Will you be using a subwoofer? If so, will you use Bass Management? Will you have acoustic treatments in the room? Where will you mount the CC?
All of these factors, and others, will affect the final sound quality. A less expensive system, set up properly, can sound better than a more expensive system set up badly. I have no doubt that any of the on-walls from the above named makers can sound every bit as good as the floorstanders from B&W... if they are SET UP PROPERLY. That would entail using a subwoofer, using proper Bass Management, installing proper acoustic treatments and mounting the (identical) CC at the same level as the L/R's, and not in some "entertainment center" 8" off the floor.
Craig
Lombardi said it:
"Perfection is not attainable, but if we chase perfection we can catch excellence."
My System
craig john is offline
post #16 of 20 Old 11-23-2009, 04:58 PM - Thread Starter
win200's Avatar
I do have a subwoofer, but a fairly mediocre 8" one made by Acoustic Energy. I've never thought much of it.
I've never really known what is meant by "bass management"; I use the multi-channel analog outputs from my blu-ray player, and I've configured the speakers to "small" in the player. My Krell pre-pro just passes through the signal to my Primare amp.
If I went with on-walls, the speakers would be mounted directly next to/below the TV. If I went the B&W route, the speakers would sit on a console directly below the television, a couple of feet off the floor.
There will be no treatment panels, for wife-related reasons.
TV: LG OLED65B6P
Amp: Classe CAV-500
Sub: JL Audio F110
win200 is offline
post #17 of 20 Old 11-23-2009, 05:54 PM
craig john's Avatar
Quoted: 569 Post(s)
Liked: 808
A subwoofer upgrade should be considered before a speaker upgrade, IMO.
Bass Management means re-directing all the bass below the crossover point from all the speakers set to "small" to the subwoofer. All that re-directed bass is combined with the bass in the LFE channel, (the ".1" channel), and sent to the subwoofer output. Get a good subwoofer and Bass Management makes a *lot* of sense.
You didn't list a BluRay player in your OP, just a Cambridge CD player. Does your BD player have more than one crossover point? If the player can do adequate BM, you don't need it in your pre/pro. However, most BD players don't have extensive BM capabilities.
Those B&W speakers are designed to be stand mounted with space around them. Putting them on a "console", will affect their sound. How much I can't predict.
Check out this High WAF Acoutic Treatments thread:
http://www.avsforum.com/avs-vb/showthread.php?t=1047573
If you want *real* audiophile sound, acoustic treatments are MANDATORY IMO. Of course, some "audiophiles" spend mega-$$$ on speaker cables, interconnects, power cords and other "snake oil" when what they really need to do is fix the acoustics of their rooms.
Craig
Lombardi said it:
My System
post #18 of 20 Old 11-24-2009, 09:27 AM
DigitalGriffin's Avatar
That depends a lot on your personal taste.
For example you could get a Martin Logan "Passage" wall speaker $800 x 3. It would be more techinically accurate, but not as warm. (cones + esl tweeter)
The B&W's have a slightly bumped mid range with a wider soundstage than any flat panel. You do get an increased bass bump because you are placing it close to the wall.
No matter how you cut it, I would go with a seperate subwoofer. These products really don't cut it below ~100->160 Hz
I'm not familiar how forward, or laid back your primare amps are. So this is really up to you.
Speaker design is rather an art. There is no such thing as the perfect painting. Likewise there is no such thing as a perfect speaker. It's part science and part personal preference.
DigitalGriffin is offline
post #19 of 20 Old 11-24-2009, 04:41 PM
jrs91's Avatar
Paradigm has in-wall speakers in their high-end Signature line.
jrs91 is offline
post #20 of 20 Old 11-24-2009, 08:39 PM
rnrn's Avatar
Definitive Mythos 10s are easy on your budget.
rnrn is offline
Reply Speakers
