Official BIC Venturi Thread - Page 17 - AVS Forum
post #481 of 498 Old 06-27-2014, 04:10 PM
charvel74's Avatar
How about the dv84s
charvel74 is offline
post #482 of 498 Old 06-27-2014, 09:42 PM
Liked: 0
Originally Posted by charvel74 View Post
How about the dv84s
I personally haven't heard them. They use the same tweeter as mine, so that might be some indication of the top end performance. Listen to them if you can.... or get them from someone with a "no hassle" return policy. Parts-Express?
Kenny99 is offline
post #483 of 498 Old 06-28-2014, 02:49 AM
charvel74's Avatar
I have them I think sound really good. Im no expert I just like what I hear. For the money I heard other speakers in the stores that cost a lot more and weren't the same quality.
post #484 of 498 Old 07-11-2014, 10:28 AM
Liked: 0
Anybody got a quick recommendation for me? I'm on the verge of buying the DV62sis for my small HT room mains to replace a pair of 7" tall Boston Acoustics that came in my 5.1 set, but are sounding very tired to me. (No, I don't *think* it's the fact that I just turned 50.) I would also swap out the center channel for the DV62CLRS, but I would keep the BA surrounds and sub.
I'm not really interested in going to the trouble of modding the DV62sis, but I'm a bit shy of the high end that I saw in Dave1027's graph. The other speakers I'm considering are the Infiniti Primus P153s, along with a complementary center channel.
Other specs - Denon EV-300 amp
Suggestions for BIC or Infinity? Or something else?
Also interested to hear recommendations for wall mounts for these new speakers. Thanks!
SonicSC is offline
post #485 of 498 Old 07-12-2014, 02:20 PM
butie120's Avatar
Quoted: 59 Post(s)
Liked: 49
I didn't own the bookshelves you are describing, but I did own the towers. I thought they sounded very good especially considering the cost. The center channel even more so just blew me away. There are times during movies where it sounds like the voices are in the room for movies. Crystal clear! I haven't heard the jnfinities, but I've heard nothing but positive things for the 62si. The mounts I would get are the Btech 77. A lot of praise on amazon and they just flat out work.
butie120 is offline
post #486 of 498 Old 07-13-2014, 04:30 AM
Liked: 0
Thanks, man. That Center channel endorsement may have just finalized my choice!
SonicSC is offline
post #487 of 498 Old 07-13-2014, 01:32 PM
butie120's Avatar
Quoted: 59 Post(s)
Liked: 49
Yeah, I don't think you can really go wrong. The other speakers that compete and probably beat these out are the Pioneer Andrew Jones. These speakers are crazy good for their price point. Cheaper than the Bics.
But if your sold on the Bics, I think you will be plenty happy.
butie120 is offline
post #488 of 498 Old 07-23-2014, 08:53 PM
Liked: 0
I have to say that the last mod I did completely fixed any sound issues that I personally had...... I installed HiVi RT1C-A planar tweeters along with a .4mh coil and a 4.0uf cap. Even with the factory x-overs they were absolutely transformed. The new tweets did not need near as much equalization to sound unbelievable. I would recommend the exact same mod for the Pioneers with some added attenuation. Just smooth, stunning detail and clarity with wider dispersion. Wow.
Kenny99 is offline
post #489 of 498 Old 07-24-2014, 08:31 AM
Liked: 0
Ohm my goodness...
Well it turned out that my amp isn't rated for 4 ohms (the BICs are 4 ohms), so I decided to go with the 6 ohm Pioneers. I went with the most recent center channel, and the older cheaper BS21 LRs. At first I was disappointed, but then I ran my Audyssey config and man, am I happy now! Next year, I'm going to get the Pioneer BS22s and use them for my LRs and move the 21s to the rear.
SonicSC is offline
post #490 of 498 Old 07-24-2014, 10:21 AM
Liked: 0
It is awesome that you are happy with your purchase. They should serve you well. Just for the sake of others that may be making a similar decision, the BIC's are 8 ohm.
Kenny99 is offline
post #491 of 498 Old 07-24-2014, 11:10 AM
Liked: 0
Ack! You are absolutely right - sorry about that! I looked at so many darn speakers that I forgot which ones were my 2nd-to-last choice. It's the Micca's that are 4 ohms, and they were the ones I had circled around to and nearly bought before I discovered the issue with my amp. Thanks for the good wishes and the correction!
SonicSC is offline
post #492 of 498 Old 08-31-2014, 09:40 PM
sickboy013's Avatar
Quoted: 31 Post(s)
I was going back and forth between BIC speakers or the Andrew Jones Pioneer bookshelves and center speaker, but ended up deciding on the BICs.
I ordered 5 of the DV62CLRS for my home theater. I was looking for a good step up, within my budget of course, from the Dayton B652s I have been running. I am excited to get them and try them out, too bad I have to wait for shipping. I will be running them with my Elemental Designs A5-350 paired up with a Premier Acoustics PA-120.
sickboy013 is offline
post #493 of 498 Old 09-12-2014, 12:13 AM
Liked: 0
Hi everyone,
I recently pulled out of storage my old mint condition BIC V62 bookshelf's, circa 1992. They still sound quite excellent, how do these compare to the newer model DV62si ? I don't care about things like shielding, I'm only asking about build quality and of course sound quality.
Currently I'm building a S-5 K12G 8w per channel tube amp kit & will be auditioning my Bic V62 against my Polk S4 bookshelf speakers. We'll see which of them wins out with the tube amp.
Rob43
Rob43 is offline
post #494 of 498 Old 11-30-2014, 07:14 PM
psychobrew's Avatar
Liked: 29
Is there a big difference between the DV62si book shelf speakers and the Adatto 52si for surrounds? I am space challenged and these speakers would be put on stands with a slight risk of being knocked over but very slight. They would be in addition to the DV62 CLRS and DV64s for a 5.0 system.
Samsung PN50C7000
Yamaha RX-V775WA
BIC Venturi DV64 Towers
BIC Venturi DV62 CLRs Center
Still building but sounds amazing so far
psychobrew is offline
post #495 of 498 Old 12-01-2014, 12:04 AM
Dom Di Stroia's Avatar
Quoted: 24 Post(s)
The Venturi DV52si would be a compromise between the Venturi DV62si and the Adatto DV52si.
http://www.bicamerica.com/showpage.p...pe=7&spkrID=37
It features the same drivers as the Adatto, but they are mounted in a larger cabinet (~12" H x ~7" W x ~7" D), and it weighs almost twice as much as the Adatto.
Receiver/amplifier: Sony STR-DE598
Front speakers: BIC Venturi DV62si
Subwoofer: BIC RtR RtR-12S
Rear speakers: Klipsch Synergy B-20
Display: Samsung UN-46EH6000
Dom Di Stroia is offline
post #496 of 498 Old 12-01-2014, 12:28 PM
psychobrew's Avatar
Liked: 29
I don't think the DV52si book shelf speakers are still being sold. I think BIC has stopped producing speakers with 5 inch drivers in their Venturi line. Otherwise, it would certainly be worth looking in to.
Samsung PN50C7000
Yamaha RX-V775WA
post #497 of 498 Old 12-01-2014, 12:51 PM
Quoted: 24 Post(s)
If the DV52si is out of production, then I have to dust off my retired V52's, and auction them off to the highest bidder!
psychobrew likes this.
post #498 of 498 Old 12-01-2014, 09:30 PM
Quoted: 24 Post(s)
If that is the case, then I would try to squeeze a pair of the Klipsch Synergy B-20's into your space-limited environment. With the grilles on, they measure ~13" H x ~7" W x ~9" D, but, nominally, they are ~30% lighter than the DV62si's.
http://www.klipsch.com/b-20-bookshel...s-pair/details
If they are guilty of having an overly-high bias, I haven't detected it (and neither has my microphone).
Review:
http://bookshelf-speakers-review.top...rs-review.html
Offers/reviews:
http://www.amazon.com/Klipsch-Synerg.../dp/B003XRD9UA
Reply Speakers
Bic Venturi , Bic Venturi Subwoofer V1020 , Bic Venturi Subwoofer V1220 , Bic Venturi Dv32 Speaker , Awm Bic Venturi Bookshelf Speakers
Gear in this thread - V1220 by PriceGrabber.com
