Adding C-50s to Take Classic 5.0? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 2 Old 12-20-2009, 08:24 AM - Thread Starter
vcip72's Avatar
I just got the Take Classic 5.0 and they sound great. I was planning on adding two more classics for 7.1, but just saw the C-50s for <$100.
Would putting the two C-50s up front and using the classics as surrounds cause any balance issues? I don't see why it would, but figured I should check with the experts.
vcip72 is offline
post #2 of 2 Old 12-20-2009, 08:56 AM
Kyuu's Avatar
It would be fine as long as you use a third C-50 as your center channel. The C-50s are pretty small speakers so it should be quite doable to fit it above or below your TV. Your fronts should all match. Also, your AVR should be able to set different crossovers for different speakers since the C-50s can be crossed over lower (at 80 or 90Hz) than the Take Classics (which need to be crossed over to the sub at 110 or 120 Hz).
Kyuu is offline
Reply Speakers
