best 2.1 sound quality computer speakers for music under $150 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 01-04-2010, 11:15 PM - Thread Starter
ashbrown's Avatar
looking for best 2.1 sound system for computer speakers for listening to music only. i want the best clarity and sound quality in this price range. i was looking at klipesch prpmedia 2.1 and because they have a tweeter have better sound quality than logitech z-2300. the swan m10 look appealing but they are nowhere to be found. what do you suggest i get in this price range for highest clarity of music period.
ashbrown is offline
post #2 of 29 Old 01-04-2010, 11:25 PM
Danielson99's Avatar
Quoted: 82 Post(s)
Liked: 63
Razer Mako THX 2.1 System (over-budget)
Edifier S330D 2.1 Digital System
Check these and other sets out HERE
Danielson99 is offline
post #3 of 29 Old 01-04-2010, 11:37 PM
CT_Wiebe's Avatar
ashbrown -- The Klipsch Promedia 2.1 system is the best you can buy, IMHO. I have an older 4.1 channel version of the Promedia's and they just cannot be beat for sound quality (and the subwoofer really improves the low end).
- Claus {non-Santa model}
CT_Wiebe is offline
post #4 of 29 Old 01-04-2010, 11:37 PM
koven's Avatar
swan m10, great 2.1 for the price.. i think they sound better than the promedia to be honest, ive owned both
http://www.theaudioinsider.com/produ...products_id/89
koven is offline
post #5 of 29 Old 01-04-2010, 11:39 PM
Quoted: 82 Post(s)
Liked: 63
Originally Posted by CT_Wiebe View Post
ashbrown -- The Klipsch Promedia 2.1 system is the best you can buy. I have an older 4.1 channel version of the Promedia's and they just cannot be beat for sound quality, IMHO (and the subwoofer really improves the low end).
You definitely haven't heard many of the new brands out in the past few years. The Klipsch Promedia are good but there are other equally good or better sounding speakers available. Of course it's all subjective...but if you go by popular opinion there are better speakers around.
post #6 of 29 Old 01-05-2010, 04:27 AM - Thread Starter
ashbrown's Avatar
well i actually really want the swan m10 but i cant find them anywhere. how would you say swan m12 compares to promedia or others in this range? i have heard that m12 isint as clear as m10 and is more for gaming and movies.audioinsider is out of stock of m10. i like klipesch but i am worried about them failing as i have read happens quite a bit(sometimes after years of use). i am not going to use the speakers for anything but music and listen to primarily rock. i am very passionate about music and want the best for $150.
ashbrown is offline
post #7 of 29 Old 01-05-2010, 04:34 AM - Thread Starter
ashbrown's Avatar
also for clear crisp music and especially for rock music should i be looking at something with a tweeter? the edifier looks cool but no tweeter?
ashbrown is offline
post #8 of 29 Old 01-05-2010, 05:38 AM
DogEarz's Avatar
It looks like the Swans are only "temporarily" out of stock. If you really want them, pre-order them and just be patient for a month or so, they will be shipping again in Feb.
DogEarz is offline
post #9 of 29 Old 01-05-2010, 07:48 AM
tagaiz's Avatar
M-Audio AV 40. 147 bucks from amazon.
edit: Sorry, forgot you wanted 2.1
tagaiz is offline
post #10 of 29 Old 01-05-2010, 12:22 PM - Thread Starter
ashbrown's Avatar
i like the edifier setup but i have heard they have bad build quality. if i get the swan m10 i would have to put the sub and speakers on the higher shelf on my desk and the sub would be directly behind the screen of my laptop...is this a problem?
ashbrown is offline
post #11 of 29 Old 01-05-2010, 12:38 PM
the_phew's Avatar
A vote against the Klipsch Promedias: I've owned the 2.1, 4.1, and 5.1 sets, and the crossovers on all three broke.
Now I just use home theatre audio equipment for my computer speakers.
the_phew is offline
post #12 of 29 Old 01-05-2010, 12:45 PM
Kyuu's Avatar
This is what I'm thinking of doing for my computer setup. Just get a pair of passive speakers, a cheap refurb receiver or digital T-amp, and whatever powered subwoofer I want.
It just seems to me like all these powered desktop speaker solutions are more about looks and convenience than performance.
Kyuu is offline
post #13 of 29 Old 01-05-2010, 12:48 PM - Thread Starter
ashbrown's Avatar
this is getting difficult for me....kilpesch has great reviews but i keep hearing of things going wrong in the long run or defective sets. some defective talk about edifier as well. the swan m10 i would have to wait a month to order and the sub would be behind my laptop so i am guessing that would compromise soound quality
gosh i hope i can decide on something...help!
ashbrown is offline
post #14 of 29 Old 01-05-2010, 01:00 PM - Thread Starter
ashbrown's Avatar
would i be able to change the wire and put the sub of the swan m10 on the floor or is it not designed for that and as result would not sound good? if i can do that how difficult is the process?
ashbrown is offline
post #15 of 29 Old 01-05-2010, 01:21 PM
MooseMuffin's Avatar
Just as another data point, my Klipsch 2.1s have survived for 7 years so far, following me through 6 addresses.
MooseMuffin is online now
post #16 of 29 Old 01-05-2010, 03:40 PM
Volcan's Avatar
ashbrown - Speaker systems for computer audio are an interesting audio "problem" and how you solve it depends on many things. You have to make some compromises to find the best speakers for your needs. There is no "one computer speaker best for all" solution.
Will the speakers be placed on a desktop with a laptop or monitor? Do you have much room for speakers and therefore will speaker size be an important consideration? Will you be listening mainly at the desk with your laptop or "in the room". For desktop listening you will probably be better off with a 2.0 rather than 2.1 system. The smaller the enclosure the more difficult to get solid bottom end, in general, which is why you were probably asking about 2.1 so you could add a sub. Just don't mistake noticable booming bass for quality. For smallish desktop speakers I like the audioengine A2 (a bit high for your budget) and Behringer ??40 at about $130 because they are front ported products from respectable manufacturers. The m-audio AV40 is nice too, especially if you have a little more space and give them some room behind. The small Swans are great if you can find them - they have a 1080?? a little below your budget and a MKII? a little above. If you want to save some $for later look at the funky little Swan S3W - about $60 from Parts Express. All of these are great for desktop listening. A separate tweeter will not necessarily give you better sound than a well made single driver.
If you want to optimize the "in room listening" at the expense of desktop listening then 2.1 can make some sense. Again putting the $$$ into better quality 2.0 would be my preference, if you have room for larger speakers on the desk. Maybe you find two good desktop speakers for now and add a sub later if you feel you need it.
Will you only be playing files on the computer or will you want to be able to connect an ipod or other mp3 or portable music player? Is it important for you to have a real simple "clean" wiring and component arrangement or can you tolerate a little more mess if there is a gain in quality. For your budget it is hard to beat a used receiver and a couple of passive monitors, but you need to have room and may need to set the receiver where it is not on the desk.
Volcan is offline
post #17 of 29 Old 01-05-2010, 08:33 PM - Thread Starter
ashbrown's Avatar
this setup will be for a bedroom and i will have the speakers on my desk and will be listening there most of the time. i will connect them to my laptop on the desk. i do want a sub just so i can have decent hitting bass which i am assuming 2.0 will not give me? i will only be listening to mp3s on my computer and thats it. i need a smaller setup because my desk is pretty small. i have room for a sub on the bottom shelf of the desk. i just want super clean sound quality and reliability.
any more suggestions? thanks for the help so far
ashbrown is offline
post #18 of 29 Old 01-06-2010, 12:42 AM
ChrisWiggles's Avatar
Totally disagree. They're junk compared to Swans M200s.
ChrisWiggles is offline
post #19 of 29 Old 01-06-2010, 10:33 AM - Thread Starter
ashbrown's Avatar
yea but these m200 are $250...cant afford them
anyone know how the swan m12 stacks up to klipesch promedia?
ashbrown is offline
post #20 of 29 Old 01-06-2010, 12:28 PM
Pete's Avatar
Quoted: 219 Post(s)
Liked: 79
If you want to save space and still get great sound, check out ZVOX
Pete is offline
post #21 of 29 Old 01-06-2010, 03:02 PM
msvara's Avatar
I second this motion. My amp in the sub blew on the 5.1.
msvara is offline
post #22 of 29 Old 01-09-2010, 09:35 PM
naschbac's Avatar
I am actually looking to go from 2.1 to 2.0, because of where I'm moving my workstation (home to new office). I currently have the M10's, and they're great little speakers, and would be willing to sell mine.
I just PM'd you.
naschbac is offline
post #23 of 29 Old 01-30-2010, 03:18 PM
King Titus's Avatar
If I have an old Yamaha receiver, how exactly would I hook it up to my computer??
Output computer, to input on the old Yamaha. What type of cable?
Honest Graft.
"I saw my opportunities, and took them"!
King Titus is offline
post #24 of 29 Old 01-30-2010, 05:20 PM
MStrickland1988's Avatar
Mini-jack to rca. Unless both your computer and receiver have optical.
MStrickland1988 is offline
post #25 of 29 Old 02-11-2010, 08:29 AM
defdog99's Avatar
Quoted: 81 Post(s)
Liked: 53
Since it's a bedroom, I'd assume you also have a TV.
So I would go with "home theater in a box".
If you have a desktop PC, you can get a motherboard or sound card with optical out, digital out, hdmi out, etc.
If you have a laptop, well, you shouldnt be expecting much so a 2.0 system should be fine... ;-)
I recently upgraded to a Razor Mako 2.1 system for an office.
defdog99 is offline
post #26 of 29 Old 06-23-2011, 08:13 PM
icegnu's Avatar
Thanks to ChrisWiggles, and koven for recommending swan. i purchased the swan m50w from theaudioinsider they are best speakers for quality and sound i have ever seen in my life, for a computer. I really appreciate the posts so much i registered on this forum just to let you know how much i appreciate your knowledge on the subject. You are both true audiophiles.
icegnu is offline
post #27 of 29 Old 06-23-2011, 09:12 PM
Louis Bartay's Avatar
Quoted: 213 Post(s)
Liked: 578
My vote is Klipsch Pro Media 2.1. There was a hearing test on line. I have my db meter and when the tones for higher Hz then my old ears could hear the meter moved. Great sound and bass for a small system.
Klipsch Cornwall I,C7,RS3-II
Klipsch Heresy II, KSB 1.1
Klipsch Sub 12" X3 Hafler P3000,P1000, DH330 DH110
Yamaha RX-V1900, SVS PB 13 Ultra
ReVox A-77 Mk IV Dolby, Nakamichi BX-100 PL-518X DL103R
Louis Bartay is offline
post #28 of 29 Old 07-01-2012, 06:24 PM
WSZsr's Avatar
Received my Swan M10s (black) today and I am blown away by the musicality of them. Admittedly I am not an audiophile but they sure sound better than my Klipsch Promedia 2.1s!
$119 from Audioinsider.com.
Update: Sadly, the M10s developed a hum in the left channel and were returned for credit.
450Received my Swan M10s (black) today and I am blown away by the musicality of them. Admittedly I am not an audiophile but they sure send better than my Klipsch Promedia 2.1s!
Samsung UN65ES6500
Onkyo TX-NR809
Sony Blu-Ray BDP-S590
Boston Acoustic VR 30 Fronts
Boston Acoustic VR 20 Surrounds
Boston Acoustic VR10 Center
Energy ESW-310 Subwoofer
WSZsr is offline
post #29 of 29 Old 07-01-2012, 07:07 PM
Quoted: 213 Post(s)
Liked: 578
They look nice and a good deal. I have never heard of them. My Pro Media 2.1 is over two years old now and still sounds great. I use to worry about how warm the amp in the sub gets as I have mine at my feet under the desk. Time will tell for both of us.
Reply Speakers
