GoldenEar Technologies Anticipation Thread - Page 114 - AVS Forum | Home Theater Discussions And Reviews
 236Likes
post #3391 of 3415 Unread 07-30-2015, 11:03 AM
mbroadus's Avatar
Quoted: 408 Post(s)
Liked: 116
Originally Posted by dhodges View Post
I have the 3D array. And to mount it I used metal strapping and hung it from the TV mount. I covered the bottom portion of the strapping with black duct tape.That ways it was right under the TV looked great. it was way easier that trying to get two pivoting mounts at the same height.
The pivoting mounts are only going to be used on the L/R, the center will be mounted using the keyhole.
Panasonic P60VT60 Calibrated by Chad B / Marantz NR-1504 / SVS PC-2000 / GoldenEar SuperSat 50s / AppleTV 3 / Sony PS4
mbroadus is offline
post #3392 of 3415 Unread 07-30-2015, 11:18 AM
goldenear tech's Avatar
Quoted: 63 Post(s)
Liked: 73
What SuperCenter with Triton Sevens
Originally Posted by ktoolsie View Post
A question for Sandy:
I recently purchased a pair of Triton 7s and am loving them. They're in a dedicated movie room as part of a 7.1 set-up. They're used almost exclusively for home theater with a mix of movies, sports, convert videos etc. They're extremely musical, but with plenty of muscle for a bombastic movie soundtrack and I've been very happy with my purchase. While listening to concert videos on Comcast, I noticed that some sounded a step up from others quality-wise. With the difference in how an individual concert can be mastered these days, it's hard to know whether the difference was due to the source material, but I did notice that the ones that sounded better were not utilizing the center channel (4.1 vs 5.1). Now, my existing channel speaker is the highly regarded Aerial Acoustics CC3 unit, which went for $1500 when I purchased it a little over 10 years ago. However, it just doesn't seem to do as good a job with music as the Tritons. I didn't expect a good blend with the Triton 7s, with the difference in technology with the tweeters between the CC3 and the 7s, and had always planned to follow up with the purchase of a matching GE center channel speaker.
So my question is which of the GE center channel speakers provides the best level of performance with the Triton 7s? Would a SuperCenter XXL be overkill or would it be a step-up from the XL IN MY SET_UP? I fall in the school that believes the center channel is the most important speaker in a home-theater set-up and would be prepared the spend the extra over the XL IF IT PROVIDES AN IMPROVED OVERALL EXPERIENCE. I'm not considering the lowest level (SuperCenter X) at this time.
Many Thanks.
Hi, Honestly, I think that you have answered your own question. Although normally listeners would go with the SuperCenter X or SuperCenter XL, certainly the XXL would be great with the Sevens, and not overkill. As you say, you, and many others, feel that the center is extremely critical. The XXL would outperform the others, and be worthwhile, even with the Sevens. Besides being capable of greater dynamic range, it is also more transparent. Whether it is specifically worth the difference in cost to you, is something you would have to answer for yourself. I think many here have already made that decision, and are very happy. All the Best, Sandy
goldenear tech is offline
post #3393 of 3415 Unread 07-30-2015, 11:25 AM
Quoted: 63 Post(s)
Liked: 73
Ceiling Mounted Atmos Height Speakers
Originally Posted by rah50 View Post
Question for Sandy:
I'm building a room (17 x 24 x 10) to house a 7.1.4 type system, don't know yet whether it will be Atmos or DTS:X.
It will definitely be a pair of Triton 1's and a SuperCenter XXL on the 17' wall.
Due to flat roof construction here in the desert, the only in-wall/in-ceiling speakers will be the sides. The ceiling speakers need to be mounted. The only location that will be a compromise is that the rears will be ceiling mounted.
Since cost is an issue I am thinking Invisa 650 for the sides and SuperSat 3's for the other 6 speakers.
My question is, if I can find more $$, which speakers would be the best to upgrade and what would you upgrade to, and in what order?
BTW, great timing on the new pivoting brackets!
Hi, Realistically, If you have to ceiling mount the height speakers (are you saying that you can't use in-walls, like the 650s or MPXs in the rear?), I think that the SuperSat 3s are really your best bet. You will cross them in a little higher than 650s (100 or 120, vs 80), but they will work very well. We regularly use SuperSat 3s as rear surrounds. You might consider MPXs, mounted vertically and at ear height, for the side surrounds. All the Best, Sandy
post #3394 of 3415 Unread 07-30-2015, 12:06 PM
Quoted: 63 Post(s)
Liked: 73
Mounting SuperSat 50s
Originally Posted by mbroadus View Post
Bought a pair of SuperSat 50s (L/R) and a 50C and I am trying to get an idea of the vertical and horizontal dispersion at a listening distance of 12 ft? My head location at 12 ft listening distance is 40 inches. The L/R 50s bottom begins at 37 inches and top is 64 with the tweeter at 51-52 inches and I'm trying to determine is this height is too high? Haven't decided whether to mount the 50C underneath or on top of the display. If I mount on top of the display angled downward, height will be 67 inches and if I mount below the display, height will be 32 inches. I'm leaning toward underneath but I have an AV cabinet 12 inches below the 50C that sticks out 19 inches so there's some concern of having audio reflections. Thoughts? Thanks
Hi, I think at 12 ft. distance, the tweeters up around 10" should be fine. You could angle them down just a little, which may not be noticeable visually. In any event, should be fine. In terms of the mounting of the center, yes, the shelf is not ideal, and this would be true with any speaker, not just 50C. If you mount it above, which should be good. It has quite excellent vertical dispersion, but angle angle it down if you can. All the Best, Sandy
post #3395 of 3415 Unread 07-30-2015, 12:20 PM
ktoolsie's Avatar
Thanks, Sandy. I wanted to ensure that the new XXLs wouldn't be out of place with the T7s. The size (and weight) of a XXL is roughly comparable to the T7s, and I'm hoping that using the same HFVR would allow either center channel speaker to blend seamlessly with the T7s.
My biggest issue is that my local Golden Ear dealer doesn't have any of the Supercenter speakers available for demo in their showroom, never mind my home-theater. They had pretty much the full range of Tritons on display, but none of the center channels. So right now I have no option but to purchase one of these speakers, without listening to either of my two options. It makes it very difficult to make the value judgement you mention, without a chance to compare the 2 speakers (XL vs XXL).
ktoolsie is offline
post #3396 of 3415 Unread 07-30-2015, 12:48 PM
mbroadus's Avatar
Quoted: 408 Post(s)
Liked: 116
Will do...thank you very much!!
mbroadus is offline
post #3397 of 3415 Unread 07-30-2015, 01:49 PM
rah50's Avatar
Amps for Triton 1?
Thanks Sandy:
One more question if I may?
Since I'm combining my 2 channel with the multi-channel, I think it's time to retire my VTL 225's and go solid state. Have you heard any of the Hypex Ncore based class D amps like the NAD M22 and have an opinion on how they would be with the Triton 1's? If not, anything else that you think is really special for the 1's?
Thanks again!
rah50 is offline
post #3398 of 3415 Unread 07-30-2015, 01:57 PM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
Hey Rah,
I am currently using 2 NAD M22 amps powering all 11 GoldenEar speakers, including my 1's. They are fantastic amps. I had Emotiva before hand and the synergy is much better with the NAD amps...to my ears.
Thanks Sandy:
Thanks again!
______________________
7.2.4 Home Theater Thread
Bigham16 is online now
post #3399 of 3415 Unread 07-30-2015, 02:06 PM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
Rah, just as Sandy has suggested, I am using 4 SuperSat 3's for my ceiling/height speakers. They are really great for their size and work perfect for Atmos. I didn't have room for the Invisa 7000s.
One tip, make sure you don't use them horizontally, use them vertically (as their intended ). I though by having them horizontal it would cover more area. Nope, complete opposite, they cover tons more area/space vertically. It was a game changer really...to my shock honestly.
Always fun to experiment.
Question for Sandy:
post #3400 of 3415 Unread 07-30-2015, 02:14 PM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
ktoolsie, I had the XL and traded it in for the XXL. Too me, much better than the XL (no offense Sandy )
If you can, go with the XXL.
post #3401 of 3415 Unread 07-30-2015, 10:03 PM
rah50's Avatar
Originally Posted by Bigham16 View Post
Hey Rah,
Good to hear Bigham16, maybe I'm on the right track. You must really have the M27, since they are 7 channels, no?
rah50 is offline
post #3402 of 3415 Unread 07-30-2015, 10:11 PM
rah50's Avatar
Thanks again Bigham16! I had to think a few minutes about what is horizontal vs vertical when mounted flat on the ceiling, lol!
I was actually thinking of using them horizontally, so they would look like an extension of the track lighting and have a better WAF. I will have to experiment though, as these will be sitting between beams which could effect the sound.
Greatly appreciated!
rah50 is offline
post #3403 of 3415 Unread 07-31-2015, 07:42 AM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
Yes, M27. Typed too fast.
Here are my M27's
post #3404 of 3415 Unread 07-31-2015, 07:58 AM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
After reading your post I thought pictures might help. I am more of a visual learner.
The first one is when I had them horizontal. I actually adjusted them more horizontal after I took this picture.
The second picture is the adjustment I made to more vertical. It really made a significant improvement for Atmos and Dolby Surround.
Vertical Placement:
Again, this worked in my room and might not work for others.
post #3405 of 3415 Unread 07-31-2015, 08:25 AM
mbroadus's Avatar
Quoted: 408 Post(s)
Liked: 116
@Bigham16 - Visual Learner too...looks fantastic. Love the VTI rack too.
What speaker mounts are those?
I'm currently measuring everything out for my SuperSat 50 install tomorrow.
Bigham16 likes this.
mbroadus is offline
post #3406 of 3415 Unread 07-31-2015, 08:35 AM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
Thank you!! I am using the Def Tech ProMount 80. I did try the Def Tech ProMount 90 but the 80's sit a little more flush with the wall than the 90's. I liked the look better.
I also us the 80's with my SuperSat 50's, side and back surrounds.
Might switch once I see GoldenEar's mounts. Maybe Sandy can give us a sneak peak
post #3407 of 3415 Unread 07-31-2015, 08:51 AM
mbroadus's Avatar
Quoted: 408 Post(s)
Liked: 116
Good to know, I'm using the ProMount 90s for my SuperSat 50...now you have me reconsidering. Suppose to receive the 90s from Amazon today. I actually need my speakers to come off the wall a bit since my TV is on a tilting mount that sticks out 4" from the wall. I would prefer the 80s for surrounds though.
mbroadus is offline
post #3408 of 3415 Unread 07-31-2015, 09:17 AM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
Yeah, there is not a massive difference between the 80 and 90 but the 80's worked in my install so I chose those. Either way they both work and both look great.
post #3409 of 3415 Unread 07-31-2015, 09:34 AM
rah50's Avatar
Very helpful and a very beautiful room! Thanks.
rah50 is offline
post #3410 of 3415 Unread 08-01-2015, 06:12 AM
mbroadus's Avatar
Quoted: 408 Post(s)
Liked: 116
Setting up for the PowerBridge and SuperSat 50 install. Moving the plasma up 5" and running all the wires behind the wall and installing the 50s on Def Tech ProMount 90 swivel mounts.
Trying to decide if I should use the swivel mounts or key hole when I place the center channel above the TV? The swivel mounts use an Allen wrench to tighten the swivel ball which would be difficult since it on the bottom of the mount with little clearance between the TV.
mbroadus is offline
post #3411 of 3415 Unread 08-01-2015, 12:12 PM
ktoolsie's Avatar
Thanks for the input. This is just the feedback I was looking for - from someone who was able to make a direct comparison between the two. I'll try and see if I can swing the XXL.
Are you using your XXL with a projector or a TV? If the former, did you mount above or below the screen?
ktoolsie is offline
post #3412 of 3415 Unread Yesterday, 05:50 AM
mbroadus's Avatar
Quoted: 408 Post(s)
Liked: 116
Pics of the new SuperSat 50s installed.
Bigham16 and bcms6 like this.
mbroadus is offline
post #3413 of 3415 Unread Yesterday, 11:31 AM
ajax-jp's Avatar
Looks good. Enjoy them. I know I enjoy mine.
ajax-jp is online now
post #3414 of 3415 Unread Yesterday, 06:59 PM
Ediddy's Avatar
Quoted: 27 Post(s)
Liked: 48
I recently upgraded and in my opinion there is a big step up between the two. Just my two cents
Ediddy is offline
post #3415 of 3415 Unread Today, 08:09 AM
Bigham16's Avatar
Quoted: 124 Post(s)
Liked: 70
Mine is in a dedicate room, with a projector, and below the screen.
Reply Speakers
