GoldenEar Technologies Anticipation Thread - Page 137 - AVS Forum | Home Theater Discussions And Reviews
 373Likes
post #4081 of 4086 Old 08-19-2016, 03:53 PM
murphy2112's Avatar
Quoted: 523 Post(s)
Liked: 296
Originally Posted by Carbo View Post
Hello,
Also I've been thinking about getting a Anthem MRX 520, Yamaha 1050 or Marants 5011, anyone using the Anthem? or try these units with the GoldenEars and how they Match?
Thank in advance,
I have a Marantz SR7010 and love the way it sounds with my GE setup.
murphy2112 is offline
post #4082 of 4086 Old 08-19-2016, 04:00 PM
Carbo's Avatar
Quoted: 91 Post(s)
Liked: 49
Originally Posted by murphy2112 View Post
What were the crossover results? If they are all close to one another, you could just average them out. How loud do you like to listen and how large is your room? If small and low volume, go with the lower crossover. If large and loud, go with the higher crossover.
But for the center and SuperSats, I wouldn't go below 80Hz and 100Hz, respectively.
And I would run the 7s as small because you have a subwoofer.
The room is large and open. The results were for the SS3's were from 100 to 150
For the 7's it was 40 and for the center it gave me 60.
I didn't think any were correct(except the SS3's I figured were close).
I was going to run the front three at 80 and was trying to see what most people ran the SS3's at. I was guessing 100, 120 or 150.
Carbo is offline
post #4083 of 4086 Old 08-20-2016, 05:59 AM
murphy2112's Avatar
Quoted: 523 Post(s)
Liked: 296
Sounds about right using 80 for the front three. Also, XO setting recommendations are on the GE website I think. You should be good to run the SS3s at 120.
post #4084 of 4086 Old Today, 09:11 AM
nitro28's Avatar
Quoted: 123 Post(s)
Liked: 38
So I am contemplating a few changes with my theater speakers. Right now I have
Triton 2's
SuperCenter XL
4 Invisa MPX
4 Definitive Atmos speakers
2 18" SI HST-18 Subs
The system sounds good but I do feel like the center channel is a little hard to hear dialogue on in some cases. The room is fully acoustically treated so I don't think it's that. I still haven't run Audyssey because I am not sure what I think of it or whether it will really help or not. So I am trying to decide if it will be a noticeable difference moving up to the SuperCenter XXL for dialogue etc?? The LCR run off of an Emotiva 3 channel amp so the power is there.
I am also trying to decide if I should move up to the Triton 1's at some point. Is there a big difference in the sound vs. my Triton 2s? or is it mainly improvement in the low end which I already have more than enough with my 2 18" SI HST subs?
The center is the biggest concern right now. Thanks.
James
My theater build 2015 (Circle N theater)
http://www.avsforum.com/forum/19-ded...ter-build.html
nitro28 is offline
post #4085 of 4086 Old Today, 11:11 AM
murphy2112's Avatar
Quoted: 523 Post(s)
Liked: 296
Triton 2's
SuperCenter XL
4 Invisa MPX
I would check the levels for the center and consider boosting a bit. If you hear distortion or think you are overdriving it, a better center might be needed.
I have a SuperCenter 60C and have noticed the need to adjust the center levels up due to differences in what I believe are differing source material levels. A better center will be better, but no guarantee that it will be louder, unless voicing has changed (has it?).
I say "voicing," because I believe that's one of the biggest differences between the T2s and T1s. I had the original T2s and now have T1s, and the sound is quite different in the midrange, in my opinion, between the two. The T2s are a bit softer and sweeter, while the T1s are more direct. I almost keep the T2s, but then eventually felt better overall about the T1s, considering that the T1s are also still sweet, but can also be more serious for the more critical stuff.
So I would see if you could listen to both and then decide. But also check those center levels.
post #4086 of 4086 Old Today, 06:12 PM
mmiles's Avatar
Quoted: 260 Post(s)
Liked: 95
The T2+ is the star of the show and best value in n the Triton series in my very humble opinion.
Mike Miles
mmiles is online now
Reply Speakers
