GoldenEar Technologies Anticipation Thread - Page 138 - AVS Forum | Home Theater Discussions And Reviews
 384Likes
post #4111 of 4117 Old 09-14-2016, 07:20 AM
grendelrt's Avatar
Quoted: 93 Post(s)
Liked: 51
Originally Posted by murphy2112 View Post
I don't have HTRs, but my 7.1.4 setup has my 4 overhead speakers installed exactly 45-degrees from the main listening position. I could be wrong, but I think Dolby gives a range of 30-60 degrees for these speakers in this format. Also, since it's 7.1.4, I'm using Top Front and Top Rear, not Top Middle, for the arrangement. This setup would also agree with DTS:X format of Front Height and Rear Height.
Are you looking at doing 2 ceiling speakers or 4?
4 for tf and tr. I figure the Dolby specs are based on the speakers pointing straight down and not at a 30 degree angle like the Htr7000, so that's why I am curious as to how people accounted for it =)
Sent from my SM-G920V using Tapatalk
grendelrt is offline
post #4112 of 4117 Old 09-14-2016, 01:02 PM
Tim Glover's Avatar
Quoted: 55 Post(s)
Liked: 33
I use a Matantz SR7010 for my 11-channel Atmos setup and T1s in front. Love the sound. I came from Harman Kardon and then Pioneer before that.
thank you for that...Thats one I have on my list to demo. That and the new 7011. As well as some Pioneer Elites.
murphy2112 likes this.
Tim Glover is offline
post #4113 of 4117 Old 09-14-2016, 02:23 PM
Carbo's Avatar
Quoted: 94 Post(s)
Liked: 51
Originally Posted by Tim Glover View Post
Thanks! Cool..I owned the 57 as well. It lasted the longest (maybe 5 years ? before giving it to my brother)...
Yeah I am looking at the 7s for rears. Ruling nothing out there. Mcintosh doesnt make a surround receiver and theyre AV Processor is $15,000. Cant and won't do that!
I just want a high quality receiver that will effectively and cleanly drive the XXL and rears. Thx for the Elite confirmation.
I'm running a Anthem 520. Very nice sound.
Tim Glover likes this.
Carbo is offline
post #4114 of 4117 Old 09-14-2016, 02:30 PM
murphy2112's Avatar
Quoted: 553 Post(s)
Liked: 305
Well, I started with my 4 ceiling speakers pointed straight down, but because the speakers I chose can also be pointed up to 30 degrees in any direction, I tried both options and found that pointing them towards the main listening position resulted in a better overall experience for Atmos.
Sandy has made the point in the past about toe-in for main speakers and I think it applies to ceilings as well: toe-in can actually widen the sweet spot as opposed to straight. If you are sitting directly in front (or under) a speaker, the toe-in from the opposite side speaker is actually pointed more your way than if it were pointed flat.
I would still go as close to 45-degrees for those 4 ceiling speakers as you can, and I think you'll still be in good shape and well within the Dolby ranges.
murphy2112 is offline
post #4115 of 4117 Old 09-14-2016, 02:35 PM
grendelrt's Avatar
Quoted: 93 Post(s)
Liked: 51
Cool thanks for the reply, this is great info. I am thinking 2 HTR7000 in front, 2 Invisa 650 in the back. I have a second row of seating and feel like if I run 650s in the back that row will get some ambiance, but I am most concerned with the first row.
post #4116 of 4117 Old 09-16-2016, 09:49 PM
Tim Glover's Avatar
Quoted: 55 Post(s)
Liked: 33
Well I purchased a Pioneer Elite SC-99...with that model being discontinued I was able to get a SCREAMING deal from the Magnolia AV in Dallas, Tx. Gobs of power and processing and since owing Elites in the past, I feel like I know what I am getting.
So when it arrives, I'll add it to the McIntosh setup and use the bypass mode. Will have fantastic 2 channel glory and surround sound too
post #4117 of 4117 Old Today, 06:04 PM
ronin22's Avatar
Quoted: 32 Post(s)
Hi Sandy
I'm sure your very busy with CEDIA but was curious if you have any plans to have an exhibit during the New York audio show at the park lane this November? Many thanks
ronin22 is online now
Reply Speakers
