GoldenEar Technologies Anticipation Thread - Page 90 - AVS Forum
 74Likes
post #2671 of 2694 Old 10-19-2014, 10:56 AM
Audiguy3's Avatar
Quoted: 42 Post(s)
Liked: 34
Here is a very informative interview by Scott Wilkinson of Sandy on Scotts podcast Home Theater Geeks that was done this week. It is about an hour long and worth the time spent.
http://twit.tv/show/home-theater-geeks/228
rustolemite and Bigham16 like this.
Reggie
Family Room:70" Sharp Elite/Marantz AV8801/MM8801/GoldenEar:Triton Ones (superseding Triton 2s), SuperCenter XL center channel, and SuperSat 60 surrounds/Oppo BDP-105/Directv Genie/ HP Notebook
Basement: 60" Sony SXRD KDS-60A2000/Marantz AV8003/Marantz MM8003/PSB Stratus Gold Front,Center,Left, Surrounds
Audiguy3 is offline
post #2672 of 2694 Old 10-19-2014, 11:31 AM
d_m1010's Avatar
Quoted: 28 Post(s)
Liked: 153
Originally Posted by ronin22 View Post
Thanks. Has it made a difference in home theater as well?
I use the 1s in 2 channel only. I have a Focal Jm Lab Electra complement for my HT system. The 1s wreck the Electras too btw.
d_m1010 is online now
post #2673 of 2694 Old 10-19-2014, 02:40 PM
rustolemite's Avatar
Quoted: 12 Post(s)
Originally Posted by Audiguy3 View Post
Yes the difference was dramatic. At my local shop (Audio Alternative) Rick set up both and the mid range and bass was dramatically better. But you have to have the ability to place the XL as it will not mount on a wall and if you put it on a shelf you need about 16" of depth.
As to your present problem one does have to set up the volume level to match or at least be a couple of db louder than the L/Rs. I used a Radio Shack sound meter to match my speaker levels with my Marantz AV8801. Right now I have not done the ones with Audyssey setup . Have you tried that?
Yes I have and I actually use the Dialogue Lift and have the volume up on the Center vs the L/R just not that clear. My tv is on a stand thats 12 inches off the ground and my center is in front level with the bottom of the tv and firing upwards. It's just not as clear as I was expecting. It's like my Axiom surrounds they are small compared to the other brands I have tried but they beat them all which is why I still use them, big not always better.
Which is why I think its funny that some of the complaints about the Tritons is "looks". I have never given that a second thought when buying speakers.
Mitsubishi WD-92840
Yamaha CX-A5000 + Emotiva XPA-5
Paradigm 100's v5 + CC-690 + Axiom QS8's
HSU VTF-3 MK4 Subwoofer
Oppo BDP-103 + Sony BDP-CX960
http://www.invelos.com/dvdcollection.aspx/Rustolamite
rustolemite is offline
post #2674 of 2694 Old 10-19-2014, 06:52 PM
sonic debauchery's Avatar
Liked: 36
During the show, Sandy mentioned setting the Tritons up with the lfe.
I did that with my T2's, but found the bass too boomy, even with the dial at zero on the dial? My T2's are 18 inches from the back wall and 10 inches from the side wall as the room dictates. I have the T2's approximately 7 feet apart toed-in to equilateral triangle to the MLP.
I am running the second lfe out to a PoweSoundAudio XS30.
Using an Onkyo 818 with Audyssey xt32. The lfe crossover at 80hz. I have the dial on the PSA XS30 at 75 db. Audyssey not engaged.
This seems unusual and I am not sure what I am doing wrong???
I am wondering if I should set the lfe crossover to say 120hz for example and then use the dials on both the T2's and PSA XS30 to regulate the bass to the low, low frequency???
sonic debauchery is offline
post #2675 of 2694 Old 10-20-2014, 06:23 AM
dscottj's Avatar
Quoted: 20 Post(s)
Make sure you have your sub set to "yes" and not "plus" (or anything else). Every receiver does this somewhat differently, but you basically want the receiver to use the sub line-outs for LFE content only. With Pioneers, using the "plus" setting will have the bass sent to the LFE *and* the wire, resulting in "boomy" bass with speakers like the tritons.
dscottj is online now
post #2676 of 2694 Old 10-20-2014, 07:05 AM
Liked: 36
Thanks for your reply.
While trying to fall asleep last night, i think i figured out what i need to do.
Since Onkyo has their "Large" setting as ...FULL RANGE...
i think if i set the front crossover to 80hz it will run the Tritons in a way where i can control the attentuator on the back of the Tritons for bass management.
It will essentially set them to "small", but the LFE should be more manageable?
I will try this and see what happens???
post #2677 of 2694 Old 10-20-2014, 09:12 AM
Quoted: 12 Post(s)
Have questions about connections as well
Would connect the One's with standard speaker cable directly to amp then set AVR to Small with a 60 to 80hz settings, using the Sub out to my HSU for all LFE?
Mitsubishi WD-92840
post #2678 of 2694 Old 10-20-2014, 12:27 PM
dscottj's Avatar
Quoted: 20 Post(s)
It'll depend on your tastes, I guess. As I understand it, the only reason GE recommends connecting the LFE to a pair of tritons is a quirk of the way at least some electronics manufacturers design their systems. For whatever reason, they roll off the LFE signal when it's sent down the wire, regardless of the speaker setting.
Using "Yes + Large" means all the LFE on movies and multi-channel music will end up at the tritons, while regular music will arrive normally without being hashed up by the receiver and be handled by the triton's own (sophisticated, expensive) electronics.
But what you're describing should work.
post #2679 of 2694 Old 10-20-2014, 01:18 PM
Steve609's Avatar
Sonic,
We have 4 Triton 2's (Front and Rear) (we are currently replacing the front pair with Triton One's) a SuperCenter XL, and a ForceField 5 Sub
We are using a NAD T787 receiver, and in our situation we found our system sounds best:
Triton 2's (front and rear) Set to Large
Subwoofer - YES
SuperCenter XL - Set to Small crossover at 50hz
LFE to the 4 Triton 2's and the FF 5 with the rear dial on the speakers set to 8:30
Turn all the AUDYSSEY stuff off including dynamic EQ and dynamic volume it made our system sound boomy
This is what Sandy is now suggesting for a setup like ours and once again he's spot on!
Hope this helps,
Steve609
Steve609 is offline
post #2680 of 2694 Old 10-20-2014, 01:49 PM
Quoted: 12 Post(s)
Will try the One's without my Sub just to see how they compare, but just don't see them being able to replace my HSU Sub.
Mitsubishi WD-92840
post #2681 of 2694 Old 10-20-2014, 04:24 PM
Liked: 36
Originally Posted by Steve609 View Post
Sonic,
Subwoofer - YES
Hope this helps,
Steve609
Thanks Steve 609
I will take your suggestions. I have all of the audyssey off now. Just have not hooked up the LFE yet. Will do tomorrow.
post #2682 of 2694 Old 10-20-2014, 04:48 PM
AVS Club Gold
thduke's Avatar
Sonic,
Subwoofer - YES
Hope this helps,
Steve609
My setup is about the same T1's as fronts T2's side surround and Supersats as rear surround, XL center and 1 FF5 hooked up with LFE sounds great and no boom.
GoldenEar Triton One's 2
GoldenEar Triton Two's 2
GoldenEar Super Center XL 1
GoldenEar SuperSat 3 2
GoldenEar ForceField 5 1
OPPO 105, Emotiva XPA-5, Emotiva XPA-2
thduke is online now
post #2683 of 2694 Old 10-20-2014, 04:56 PM
goldenear tech's Avatar
Quoted: 24 Post(s)
Liked: 34
Enclosures for Invisas
Originally Posted by dan webster View Post
Is anyone using any of the GE in ceiling speakers? I am thinking about getting 4 for my atmos overhead speakers. My concern is there will be too much sound transfer above the speakers to my living room above my basement theater. I have been researching dynabox in ceiling enclosures but am not sure if they would help or hurt the speakers performance.
Hi, You can put the Invisas in enclosures like the Dynamats. We suggest about 1.25-1.50 cubic feet. All the Best, Sandy
goldenear tech is offline
post #2684 of 2694 Old 10-20-2014, 05:00 PM
Quoted: 24 Post(s)
Liked: 34
Center Channels for Triton Sevens
Originally Posted by calypsoe36 View Post
Hi All,
I'm in the market for a new 5.0 HT setup to pair with my Epik Empire. I stumbled across several positive reviews and recommendations for the GoldenEar lineup. A local shop has the Triton 7's and SuperSats available for demos so I'm hoping to check them out.
Apologies if this has been discussed, but are the SuperSat 3's a decent pairing with the 7's? Would the SuperSat 3 be a capable center or would it be overpowered by the towers? The satellites are compelling based on price and size compared to the SuperCenters.
Hi, Although you can certainly use SuperSat 3C as a center channel with the Sevens, most listeners would probably opt for the SuperSat 50 or SuperCenter X. All the Best, Sandy
post #2685 of 2694 Old 10-20-2014, 05:03 PM
Quoted: 24 Post(s)
Liked: 34
Tritons for Your System with MegaSub
Originally Posted by aaks38 View Post
Am contemplating going the GE route for my HT setup. Currently i have 4 15s in an infinite baffle setup, powered with 1000wrms. So my issue is that im trying to determine which front towers to get that will complement the subs. I cant imagine the 1 or 2 will rival the bass output of my IB setup so i am trying to figure out could i save some cash and get by say with the triton 7, as i dont really need the added bass output of the 1 or 2s however i see there are different midrange drivers between the 1, 2 and 7 for HT usage, is it really worth paying extra for the 1 or 2s or do the 7s seem to be the ideal tower for HT setups.
Thanks for the help
Hi, Wow, 4 15" drivers with 1000watts driving them. I suspect that you like to listen loud. I would suggest Triton Ones set to large, and use your sub on the LFE channel. All the Best, Sandy
post #2686 of 2694 Old 10-20-2014, 05:06 PM
Steve609's Avatar
Once we turned all the AUDYSSEY stuff off including "dynamic EQ and dynamic volume" we no longer have boomy bass.
Can't wait to hear how it sounds with the One's.
Steve609 is offline
post #2687 of 2694 Old 10-20-2014, 05:09 PM
Quoted: 24 Post(s)
Liked: 34
Center Channel on Shelf or Mantle
I had the 60 and it was mounted below the TV and above the mantle. I had trouble with dialog on movies and tv. No amount of tweaking could help.
Here is a picture of when I had it just sitting on the mantle which gave me the best sound rather than mounting it on the wall but the problem was it fell off when I was listening at too high of a volume:
I gave it to my daughter in California and on her set up the speaker was stunning. I think the mantle interfered with the sound as my daughters set up is on a flat wall with no mantle or TV above it.
Hi, Generally, if you are putting a center channel, or any speaker for that matter, on a shelf or mantle, you should move it so the front of the speaker is even with the front edge of the shelf. If it is further back, so the shelf projects, you will get diffraction coloration, which colors the sound. All the Best, Sandy
post #2688 of 2694 Old 10-20-2014, 05:15 PM
Quoted: 24 Post(s)
Liked: 34
AVR Settings with Triton Ones
Hi, The Hsu subs are good. If you are using one with the Triton Ones, I would suggest Triton Ones Large, and just use the Hsu on LFE. You can also run LFE into everything and Triton Ones large, sub Yes, 3 way LFE split. Set the bass level on the Triton Ones on 2 channel music, then LFE to taste. All the Best, Sandy
post #2689 of 2694 Old 10-21-2014, 09:30 AM
Quoted: 12 Post(s)
Thank you very much for the response. Think I will have to use the "Triton Ones Large, and just use the Hsu on LFE" just do too location and of speakers and current cabling. Can't wait to get my set.
Mitsubishi WD-92840
post #2690 of 2694 Old 10-21-2014, 11:54 AM
cgott42's Avatar
Quoted: 52 Post(s)
I have 2 Questions re: setup.
My equip and room size: I have Triton 2’s as the fronts, SCXL as the center, and a single SS50C as the rear. A HTPC feeding a Denon 2809ci receiver via HDMI cable, which sends the LFE via an RCA cable from the pre-out sub to a buttkicker amp – which is connected to a SVS 20-39CS sub via speaker cables. My HT dimensions are approx. 14x24x 6.5’ high
Q1a&b – I’m looking to buy surrounds – One option is Aon2’s on a wall mounted shelf at the listening height. Another thought was Triton7’s – however being that they are floor standing (a) would I be better off with the Aon2’s on the wallor the triton 7's (also take into account the room size and the fact that they're "only" being used as surrounds– when suggesting) ? (b) Also how much of a difference would there be between the Aon2’s vs. Aon 3’s when used as surrounds?
Q2a&b-I read that Sandy suggested sending the LFE to the Trition2s – however as mentioned above I have a single speaker cable coming to my current sub – (a) how would this feed both Tritons + the SVS sub? (b) how would I convert the speaker cable to the RCA style input on the Triton’s LFE?
Thx!
cgott42 is online now
post #2691 of 2694 Old 10-21-2014, 12:23 PM
Liked: 36
Thanks Steve 609
Discovered that the amp is not working in my right T2. Contacted my dealer, and they are looking into a replacement.
On the left speaker the bass is still boomy and i have all Audyssey off. No doublebass and dial at absolute zero. I am wondering if i need to recalibrate the bass with all LFE hooked up. (Tritons X2 and PSA XS30), perhaps the gain is too high for 3 subs. Currently at -2.5?
post #2692 of 2694 Old 10-21-2014, 04:09 PM
Quoted: 12 Post(s)
Since I don't have my One's yet I was playing around with my current setup and using the settings that Goldenear recommends for the One's set to Large and my HSU for LFE, well my AVR doesn't have an actual LFE out just Sub Out (I guess same thing) but when I switch my Paradigms to Large it pretty much stops sending the low frequencies to the Sub its almost like turing the Sub off. Will I have the same effect when using the One's or can I leave them on Small with a 80hz setting and everything below that goes to the Sub.
Mitsubishi WD-92840
post #2693 of 2694 Old 10-21-2014, 04:13 PM
dscottj's Avatar
Quoted: 20 Post(s)
That's what I'd expect from two channel music, since there's no .1 spec in redbook. Since it's your system and you can set it up however you like, I wouldn't sweat it so much. None of this is set in stone.
post #2694 of 2694 Old Yesterday, 10:00 PM
nitro28's Avatar
Got a great deal today
I've been reading about the golden ears for the last month or so and today I listened to then at our local shop. They were as good as everyone had said. This shop also bought all of the demos that they used at the CES show so I got the Triton 2s and the XL center for a steal. Can't wait to get my theater done so I can get these set up. I still want to run bi-pole/di-pole surrounds with these 3. There shouldn't be a problem using a different brand like Axiom for the surrounds, right?
d_m1010 likes this.
nitro28 is online now
Reply Speakers
User Tag List
