Can you use Klipsch RS-10s as front and rears - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 01-11-2010, 05:13 PM - Thread Starter
tennyis's Avatar
A store near buy has the RS-10's on clearance right now.
Here's what I have (just not hooked up)
Yamaha 6240
Klipsch RC-52 Center
Polk PSW125 Sub
I was going to buy RF-82's for the front and then in another month or so when I get the money pick up RS-52 for the rear
However the local speaker shop has RS-10s on clearance and the salesmen is suggesting using them as fronts and rears to get my system up and running. He's willing to sell me all 4 for $279. The RF-82's are $699 each and the RS-52 is $399 so it's a huge costing. He said since I am going to be using it for movies only that it should work fine.
Thoughts?
tennyis is offline
post #2 of 4 Old 01-11-2010, 06:29 PM
mjg100's Avatar
Yamaha 6240
Polk PSW125 Sub
Thoughts?
You do not want to use RS-10's for your mains and center. The RS speakers spread out the sound field making it hard to pinpoint where it is coming from. That is not what you want for the front sound stage.
mjg100 is offline
post #3 of 4 Old 01-11-2010, 06:41 PM - Thread Starter
tennyis's Avatar
would they be ok as rears with the RF82s up front? trying to get everything I need, i'm anxious to get my system up and running!
tennyis is offline
post #4 of 4 Old 01-11-2010, 06:52 PM
Knucklehead90's Avatar
Quoted: 191 Post(s)
Liked: 231
They would be great for the side and/or rear speakers. As mjg100 said - they aren't made for imaging - they are made for dispersion of the sound field.
When all else fails - RTFM!
For Sale: Emo XSP-1 & Onkyo/Integra M-504
GO SEAHAWKS!!!
Knucklehead90 is offline
Reply Speakers
