Anyone still running Infinity Speakers like me? - Page 11 - AVS Forum | Home Theater Discussions And Reviews
 65Likes
post #301 of 326 Old 02-23-2017, 04:28 PM
GamerCorps's Avatar
Originally Posted by Ka7niq View Post
That is not as good as the Quadrapole, I 'm afraid. The sound will hit the wall, then ping pong back and forth, and that will ruin the omnidirectional pattern. You will not be able to run them as loud as a pair of Quadrapole's.
Are those quadrapoles the QPS-1's?
GamerCorps is offline
post #302 of 326 Old 02-23-2017, 05:31 PM
Ka7niq's Avatar
Quoted: 27 Post(s)
Liked: 29
Yes, they are what I use.
Ka7niq is offline
post #303 of 326 Old 02-25-2017, 06:15 AM
GLBright's Avatar
Quoted: 68 Post(s)
Liked: 87
After discontinuing the Q-pole Infinity went with this design through several different models. It's a mono/di/bi-pole design and probably superior to the RS model mentioned.
Name:	beta surround.jpg
HT: Onkyo TX-SR702,Infinity IL60s/IL36c,LG PF1500,Draper92"screen,SonyBDP-S570,Dish622
Stereo1 Denon PMA-630 amp,TechnicsSL-1300TT,ToshibaSD-4960 player,Infinity Overture 3s
Stereo 2 OnkyoTX-8222,Pioneer PL-3000 TT,YamahaDV-S586 player,Large Advents (1972)
GLBright is online now
post #304 of 326 Old 02-25-2017, 07:13 AM
Ka7niq's Avatar
Quoted: 27 Post(s)
Liked: 29
I used to own the entire Infinity Prelude PFR system, and the Quadrapole surrounds are the only thing left from that old system.
The foam on the old Prelude PFR's degraded, and so I took them to a well known and respected speaker repair shop here in Tampa that literally Butchered them.
The small midrange drivers of the Prelude PFR's had a narrow foam surround, from the factory. When I got them back, the replacement foam covered 1/2 of the cone of the drivers
To say they sounded like Crap is an understatement.
Over the years, I have had many surround speakers come through here of every configuration. Dipoles suck IMHO, Unless you happen to be sitting right where they have the well known dipole null.
LOL, I even tried Klipsch surrounds, with the 2 horns firing at 45 degrees to each other, with a cone in the middle. They sucked too, because you could easily locate the cone driver
I like the Quadrapole because they are small, efficient, and play loudly w/o being localized.
They are "good enough" for my use, but remember I am much more of a music listener then I am a home theater guy.
49Merc likes this.
Ka7niq is offline
post #305 of 326 Old 02-25-2017, 10:59 PM
49Merc's Avatar
Quoted: 352 Post(s)
Liked: 73
Your comments are the reason I never purchased specialized surrounds.
LG OLED 55EG9100 HDTV, DirecTV HD DVR Genie HR44, DirecTV AM21 OTA Receiver, Sony BDPS6500 Blu-Ray, Bose Soundtouch 130 HTC (Sound Bar), Panamax MR5100 Power Manager, Harmony Ultimate One Remote, Monoprice AV Cables
LG OLED 55EG9100 Calibrated by Best Buy Geek Squad
49Merc is offline
post #306 of 326 Old 02-25-2017, 11:42 PM
Quoted: 955 Post(s)
Liked: 633
Hmm, I've been reading some reviews of the QPS-1s, they seem to be pretty mixed, some love them, some hate them. I do wonder about how well the Bose-esque full-range paper cones in those would blend with the CMMDs in my front stage.
I'm going to hold off on doing new surrounds for a while (the Modulus sats I've been using for years are still fine for the moment) and make getting my 2-channel room for the Intermezzos the priority. The IL40s and IL36C in the HT room are impressing me more every day. They really shine with Blu-Rays more-so than TV for whatever reason, I'm wondering if they're just exposing faults in TV audio that I hadn't heard before. The audio on Blu-Ray discs just sounds so much fuller and richer (and it's not a codec thing as far as I can tell, everything is hooked up via optical right now since my receiver doesn't do HDMI, so it's all compressed).
I'm sorry to hear about your bad experience with the shop in Tampa, I'm hoping that's not indicative of their normal level of service. They're my plan for repair in case the midrange drivers in the Intermezzos experience the magnet failure that can occur in the Intermezzo and Prelude MTS line.
TuteTibiImperes is online now
post #307 of 326 Old 02-26-2017, 06:11 AM
GLBright's Avatar
Quoted: 68 Post(s)
Liked: 87
There's one of the very few reviews of the Intermezzo 4.1t here. Also excerpts from a speech by Floyd Toole. Great read, as were all issues of The Audio Critic.
http://www.biline.ca/audio_critic/ma...ritic_28_r.pdf
TuteTibiImperes likes this.
post #308 of 326 Old 02-26-2017, 01:26 PM
gene c353's Avatar
Quoted: 150 Post(s)
Liked: 110
I'm still running my IL40's Fronts, IL30s rear and IL36 center, my IL120 finally died and replaced it with two Klipsch 12's. Bought my IL set back in 1999. Few Q's for you all:
Q) Im thinking about mounting my IL36c(yeah shes heavy) above my 140" screen, she can fit in the wall, thoughts? This is for a two row 8 seat theater approx 20x18.
Q) Should I entertain upgrading my IL40's? Mainly used for movies and not music as much.
and finally:
Q) I would like move to 7.2 which speakers would pair well with the IL's if I dont upgrade, find some IL10's to mount on the wall? or ?
One speaker that seems to get lost in the schuffle that can be used as surrounds with the Alpha, Beta, Entra and IL lines is the OWS-1. 6 1/2" CMMD woofer and 3/4" version of the CMMD tweeter. lite, 4 1/2" deep and reportedly plays to 80hz (but 100hz is more likely). In white and ebony. Tonal quality should match all the line closely enough and usually sell for around $70 (+/- $25).
https://www.crutchfield.com/S-TCnu5I...-speakers.html
GLBright and 49Merc like this.
gene c353 is offline
post #309 of 326 Old 02-27-2017, 10:41 AM
49Merc's Avatar
Quoted: 352 Post(s)
Liked: 73
https://www.crutchfield.com/p_108OWS...c=4&tp=191&s=0
I had one for awhile. Your link seems not to work.
49Merc is offline
post #310 of 326 Old 02-27-2017, 11:58 AM
Quoted: 955 Post(s)
Liked: 633
Anyone have any leads on where someone could buy a complete RABOS kit?
post #311 of 326 Old 02-27-2017, 02:04 PM
gene c353's Avatar
Quoted: 150 Post(s)
Liked: 110
Lets try this one .
post #312 of 326 Old 03-15-2017, 10:38 PM
Liked: 2
Happy this thread is back from the dead
So this is partly a rate my system/look what I just found thread haha!
Found a full set of Cherry Cascade speakers (sans sub) from a seller in redondo who (while very nice) didn't seem to know what they had....I won't pain you with what I paid for them but here's the setup as it stands now:
Cascade 9's/3C/5 surrounds on the floor stands
SVS SB2000
Marantz SR5010
Deion DP-300F+ Grado Reference2
Panasonic TC-60PU54
PS4/Roku Premier+
I must say, especially when listening to something like Chris Issak's "Wicked Game" the transparency is obscene
GLBright likes this.
A: Marantz SR5010/Denon DP-300F+ Grado Reference2/Infinity Cascade 9+3C+5/SVS SB2000
V: Panasonic TC-60PU54/Sony PS4/Roku Premier+
Daniel Moore is offline
post #313 of 326 Old 03-15-2017, 10:47 PM
Liked: 2
SVS SB2000
Marantz SR5010
Panasonic TC-60PU54
PS4/Roku Premier+
Denon*
post #314 of 326 Old Yesterday, 05:48 AM
Quoted: 955 Post(s)
Liked: 633
SVS SB2000
Marantz SR5010
Panasonic TC-60PU54
PS4/Roku Premier+
Cool setup, I haven't ever had a chance to see the Cascades in person, but they look very pretty from photos.
post #315 of 326 Old Yesterday, 05:55 PM
GLBright's Avatar
Quoted: 68 Post(s)
Liked: 87
Neither have I. But somehow I have a feeling that the Cascade line, with its mid-century modern styling, didn't sell well. And was the beginning of the end for Infinity's better quality speakers. The Reference line is all there has been since the Cascades were withdrawn.
49Merc likes this.
post #316 of 326 Old Yesterday, 06:40 PM
gene c353's Avatar
Quoted: 150 Post(s)
Liked: 110
SVS SB2000
Marantz SR5010
Panasonic TC-60PU54
PS4/Roku Premier+
Have you heard the live version of Wicked Game from The Best Of Soundstage bluray? It's wicked! (worst pun I've ever used )
I'd love to hear me some Infinity Cascades .
49Merc likes this.
post #317 of 326 Old Yesterday, 06:58 PM
Quoted: 955 Post(s)
Liked: 633
I wonder how much of that was due to the demise of Circuit City, IIRC they were the biggest B&M retailer for Infinity speakers (I don't recall ever seeing them at Best Buy, I believe they only carried the JBL line).
TweeterAV was in a death spiral around that same time, and that may have also had something to do with it.
It would be nice if Samsung helps Harman invest back into the Infinity brand.
post #318 of 326 Old Yesterday, 09:08 PM
Liked: 2
It's funny you sat this specifically because I live in a Mid-Century modern ranch house in So-Cal that I've done up as such. I'll post some photo's tomorrow.
Squirrel! likes this.
post #319 of 326 Old Yesterday, 09:11 PM
Liked: 2
I can't say that I have, but I'm genuinely thinking of dusting off my C555ES in the closet and shopping for some SACD's again.
post #320 of 326 Old Yesterday, 09:16 PM
Liked: 2
I bought my first set of Infinity Speakers from CC (RS2's) and I remember the fire sales at Tweeter when they were going under.
I agree with your assessment of CC being the largest B&M retailer for Infinity, and they haven't done anything to move the needle since the TSS/Primus lines debuted 10 years ago in the general consumer space. When I was 12 (in 1996) my parents got a new Grand Caravan ES (with dual sliders!) that had the Infinity Acoustic 10 system. It was mind-blowing for my 12yr old self and I've had a soft spot for Infinity ever since. Here's hoping Samsung can find the value in the name. After all fellow Korean company Kia still does.......if thats worth anything.....
post #321 of 326 Old Yesterday, 10:14 PM
Quoted: 955 Post(s)
Liked: 633
I believe Hyundai uses Infinity systems as well. Apparently a lot of the value Samsung saw in Harman was in their OEM partnerships in the automotive sector, so if they want to keep being able to sell Infinity car audio systems as something premium, they'll need to keep the brand relevant, after all, who'd pay extra for a premium audio system from Jensen, Altec-Lansing, Mirage, or any number of other brands that have either disappeared or fallen greatly in stature?
GLBright and Daniel Moore like this.
post #322 of 326 Old Today, 09:51 AM
49Merc's Avatar
Quoted: 352 Post(s)
Liked: 73
In it's demise CC was selling only consumer grade speakers.
49Merc is offline
post #323 of 326 Old Today, 10:10 AM
Ka7niq's Avatar
Quoted: 27 Post(s)
Liked: 29
If it were my company, I would retain only the very best engineers from Infinity, and put Infinity out of it's misery.
It is over for them, and it has been over for awhile.
RIP Infinity
49Merc likes this.
Ka7niq is offline
post #324 of 326 Old Today, 10:39 AM
49Merc's Avatar
Quoted: 352 Post(s)
Liked: 73
RIP Infinity
I agree.
49Merc is offline
post #325 of 326 Old Today, 10:43 AM
Quoted: 955 Post(s)
Liked: 633
RIP Infinity
The way I see it Harman should do something like this:
JBL - Pro Audio, Cinema, Mastering, Installed Sound, and HT focused home audio, with JBL Synthesis being the premium HT focused brand. Make it all about high efficiency, horns, compression drivers, big woofers, the stuff JBL does best.
Infinity - More of a balanced music/HT brand, pay more attention to cabinets/enclosures than JBL, make them pretty so they look at home in a nice living room. Have a range from entry-level mass market speakers to mid-premium, maybe have the top end where the Revel Concerta or Performa line is now. Make Infinity the direct competitor to Polk, DefTech, Paradigm, etc.
Revel - Cost is no object ultimate speakers at the top, maybe some overlap with Infinity at the bottom.
post #326 of 326 Old Today, 10:49 AM
Ka7niq's Avatar
Quoted: 27 Post(s)
Liked: 29
I agree.
General Motors got rid of both Pontiac and Oldsmobubble, as well as Saturn.
The few of us who remember the heyday of Infinity, are nearing nursing home age, and guess what ?
Most nursing homes will not let us take our IL 60's, much less a full blown IRS System.
Go ahead, ask your Grandkids if they ever heard of Infinity ?
Then, ask if they have heard of JBL
Samsung needs to put Infinity out of it's misery, and concentrate on JBL and Revel.
49Merc likes this.
Ka7niq is offline
Reply Speakers
Infinity , Infinity Alpha 50 Floorstanding Speaker , Infinity Beta 40 Loudspeakers , Infinity Center Channel Speaker , Infinity Entra One Speaker 2 Way , infinity interlude speaker , Infinity Ows 1 , Infinity Primus P363 Three Way Dual Infinity Floor Standing Speaker , Infinity Primus Pc351 Center Speaker , Infinity Primus Two Way Pc251 Speaker
