official danley sound labs thread - Page 7 - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #181 of 392 Old 06-25-2014, 08:38 AM
SeaNile's Avatar
Quoted: 437 Post(s)
Liked: 172
Originally Posted by klipsch View Post
I have two QSC RMX amps right now ... got a 2450 used ($300) to power the L and R SH50s and had a 1450 that I am using for the C SH50
I modified the fans on both (about 5 minutes of work) and the amps seem to deliver more than enough
I am figuring that no one will ever need more than 2 watts sustained at 13-15 feet back with the 100 db sensitivity of these bad boys ... so how much headroom is required for dynamics and such?
I thought the 3000W amp that was recommended is a bit overkill, especially at $3850. Time is on my side so I can shop around for amps and the pre/pro.
SeaNile is offline
post #182 of 392 Old 10-24-2014, 12:20 AM
Liked: 1
Hi any Danley owners here in the UK?
bonzo75 is offline
post #183 of 392 Old 01-03-2015, 02:35 AM
Kain's Avatar
Quoted: 1475 Post(s)
Liked: 424
Do you have the option for active/powered versions for all Danley speakers (including subwoofers)?
Kain is offline
post #184 of 392 Old 01-03-2015, 03:21 AM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
All Danley designs can be made with built in amps.
chrapladm is offline
post #185 of 392 Old 01-14-2015, 07:06 PM
blazar's Avatar
Quoted: 731 Post(s)
Liked: 533
I am considering the Danley Sm-96 is a possible floor standing "center" channel for my home theater setup. I have Avantgarde Trio horns for main speakers and I think it is very likely that another horn speaker for the center would be a close match.
The SM-96 is exactly the right size for the space that I have under my screen while also having sufficient SPL and sensitivity to compete with my main speakers.
Any thoughts on this or another Danley that might be a better choice? Or really any other center horn speaker suggestions? I have looked at klipsch and JBL to some degree. I haven't heard any of these in my own home.
Blazar!
blazar is offline
post #186 of 392 Old 01-14-2015, 08:54 PM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
I would use the next model up but directivity depends on your rooms seating. I would suggest a SH64 but if your placing the SH below you may need more area so maybe a SH69.
post #187 of 392 Old 01-14-2015, 09:21 PM
Bexar's Avatar
Anyone selling some Danley's?
Bexar is offline
post #188 of 392 Old 01-15-2015, 06:03 AM
AudioJosh's Avatar
Quoted: 282 Post(s)
Liked: 255
I will chime in only because I am a fellow horn lover, have heard the Duo's a couple times (not the Trios) and own SM-60Fs for my HT system.
Somewhere I saw a link where you could simulate the pattern control that you wanted. Were you looking to use the center 90 wide and 60 tall, or flipped? I'd likely go 90 wide as that pattern would suit more rooms and minimize floor and ceiling (more ceiling if you are placing on floor) bounce. If you find the link you might want to play around as a narrower pattern might not be a bad thing in your room to minimize side wall reflections.
Can it keep up with Avantgarde speakers? Yes, most definitely. They won't dig as deep as your system as a whole, but at least as deep as the Trio without subs as the large horn IIRC has a cutoff somewhere around 100+hz.
I would have opted for the SH50s if my room were bigger, but the SM60Fs fit my space and room size better. Looks like you have the same space constraint.
What are you running your Trios on, amplification wise?
I have no idea if the Trios and the Synergies would match well synergy wise, I'd guess that it would be close enough for HT content. Everytime I heard the Duo's we were running them on SET amps and I've never run the SM60s on SETs. You could always use a bit of EQ to match tonality if necessary.
I've heard of a few folks who sold big Avantgarde speakers to buy the SH50s after hearing them, so I don't think you will be disappointed in their performance. The constant directivity of a Synergy together with the superb coherency of of the design makes it a perfect center channel.
JoshK on most other audio forums
Quantity only when quality is ensured.
AudioJosh is offline
post #189 of 392 Old 01-15-2015, 09:27 AM
mcallister's Avatar
Quoted: 108 Post(s)
Liked: 39
I may consider selling my custom zebra wood finished all active 7 channel setup.
I bought these from a fellow AVS member over a year ago for a dedicated theater room that never panne out. Prior to these I had 3 GR Research LS9 line arrays, and Salk HT-3 and the Danleys are my favorite spaker I've had in my room to date.
They consist of 3 active SH100B, and 4 active SH100s. Just get a processor with XLR outs and your ready to go.
Let me know if anyone is interested? If not no big deal as I really don't want to get rid of them but other obligations are putting my dedicated room in hold for the foreseeable future,
mcallister is offline
post #190 of 392 Old 01-15-2015, 09:44 AM
Point Source
beastaudio's Avatar
Quoted: 4030 Post(s)
Liked: 3351
HMmmm sh100's you say? Holler at me a price, I might want to try all 4
beastaudio is offline
post #191 of 392 Old 01-15-2015, 09:49 AM
mcallister's Avatar
Quoted: 108 Post(s)
Liked: 39
Unfortunately I would be looking to sell this as a package deal if I do sell.
post #192 of 392 Old 01-15-2015, 05:26 PM
blazar's Avatar
Quoted: 731 Post(s)
Liked: 533
I only have room to place the speaker horizontally. will this orientation provide the wider dispersion? All my side walls are treated well so i dont think reflections are a concern.
Running my avantgarde trios on a pass labs xa 30.8 which works excellent. I really dont want to bother with sets and whatnot.
The SM96 (molded model) is the speaker that will actually fit best. The SH96 will be too large and wont fit under the screen.
Applying EQ to the center is not a problem and generally audyssey does a decent job with that via the AVR.
blazar is offline
post #193 of 392 Old 01-26-2015, 02:12 PM
AudioJosh's Avatar
Quoted: 282 Post(s)
Liked: 255
I think you will be very happy with the SM96 as a center.
I just got my 3rd SM60F and 2 SH-minis. I originally only ordered 2 SM60F. I dealt with Integrity Communications Group in Halton Hills, ON both times. If anyone is in Canada and interested in DSL's offerings, these guys are super awesome guys and really a pleasure to deal with.
I haven't gotten the system all set up yet, but I am slightly surprised that SH-minis aren't looked at more often for surround options. They really seem to fit the bill for hi-end surrounds for "big" systems and aren't terribly large.
post #194 of 392 Old 01-26-2015, 03:04 PM
A9X-308's Avatar
Quoted: 1506 Post(s)
Liked: 1142
Oh. My. God. Don't you just know that all surrounds should be Quadripoles, Quintipoles or more? Find a random shape and shove a driver on each face and be prepared for surround perfection.
AudioJosh likes this.
A9X-308 is offline
post #195 of 392 Old 01-27-2015, 02:35 AM
mcallister's Avatar
Quoted: 108 Post(s)
Liked: 39
I'd love to get four SH-mini to use for ceiling mounted atmos speakers. I've never see them in person, from the pics and the odd shape of the cabinet it seems they wouldn't work? Any thoughts on ceiling mounting these? (My ceilings are only 8 feet)
post #196 of 392 Old 01-27-2015, 06:05 AM
AudioJosh's Avatar
Quoted: 282 Post(s)
Liked: 255
I wouldn't be the best to help you out there. I am only just moving from 2.1 to 5.2. You might ask Ivan Beaver what he thinks.
post #197 of 392 Old 01-28-2015, 03:25 PM
forin's Avatar
I used to have 2 micros for surrounds in my 5.2 system. They sounded great and got plenty loud! According to Danley's measurements on their website the micros seem to have a much smoother FR than the mini, if that matters to you. I would imagine they would mount to a ceiling easier than the mini's as well. Either way you cant go wrong with the Danley's, man I really miss my old system.
Forin
forin is online now
post #198 of 392 Old 02-04-2015, 01:00 AM
Liked: 1
Hi, anyone on this thread from the UK or Western Europe? I am interested in listening to a Danleys set up, if anyone is on, please let me know and would like to drop by for a quick listen
bonzo75 is offline
post #199 of 392 Old 03-21-2015, 09:46 PM
blazar's Avatar
Quoted: 731 Post(s)
Liked: 533
I did order the SM96 and it is a speaker that is basically built upon ordering (from what I've been told). I should be able to provide some insight into how well it blends with my other horn main speakers. I also need to figure out how much "floor bounce" I am going to get since this thing has to be placed on the floor. I can angle it up about 10 degrees as well which should reduce some floor reflection. There will be a rug across a significant portion of the floor between the speakers and the seating.
If I angle a bit higher, perhaps 30 degrees, it might look odd but there would even be less floor reflection to worry about and it would still be hitting the main listening position within its 60 degree vertical directivity angle.
Blazar!
blazar is offline
post #200 of 392 Old 03-21-2015, 10:12 PM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
Dont know where your seating distance is but since it will be on the floor are you going to treat the ceiling reflection point for the center?
Figure it will most likely be a different point than your L/R. Seems like 90 x 60 would be perfect for a center of wall placement but since this is on floor things are different. As always just curious.
post #201 of 392 Old 03-22-2015, 04:01 PM
Point Source
beastaudio's Avatar
Liked: 3351
On another note, Ivan is back again talking about the new horn that is basically the refined 60f. Hey Ivan, got anything more to share here?
post #202 of 392 Old 03-30-2015, 08:47 PM
darrellh44's Avatar
Quoted: 749 Post(s)
Liked: 248
I requested a price quote on a pair of SM60Fs thru a local distributor. I also asked him to inquire about the rumored HT version of the SM60F. He said they "could not confirm that one is in the works but did confirm that it will not be released in 2015 as the lines are set for the year". I'm still trying to decide if I should go for the current SM60Fs or wait. I'm afraid the resale value on the current SM60Fs may go down quite a bit when the new ones come out.
darrellh44 is online now
post #203 of 392 Old 03-30-2015, 10:39 PM
chrapladm's Avatar
Quoted: 931 Post(s)
Liked: 348
Resale might go down in a HT forum but not anywhere else.
post #204 of 392 Old 03-31-2015, 06:17 AM
AudioJosh's Avatar
Quoted: 282 Post(s)
Liked: 255
In my case, I am using an AT screen and putting the SM60Fs behind, so if it is mostly aesthetic changes, I don't really care much. Don't get stuck in analysis paralysis. DSL speakers are amazing. If the new ones are even more amazing that is cool too, but I'll still be happy with mine.
post #205 of 392 Old 03-31-2015, 07:41 AM
Point Source
beastaudio's Avatar
Liked: 3351
Agree with Chrap, resale should be just fine, just post them on a pro-sound board.
Actually, I am not aware of any aesthetic changes to the HT version, they are just refining the crossover, shooting for more extension down low, and overall just shooting for a more "HT" friendly type application from what I have gathered so far. If the price-point is similar to the current sm60f, I will likely order three to play around with against the sh50's to really see the differences head to head.
post #206 of 392 Old 03-31-2015, 09:04 AM
Quoted: 995 Post(s)
Liked: 522
If they're changing the crossover but keeping the drive units and horn the same, which I'd expect giving the cost of a new horn mold, then chances are they'd offer the new xover as an upgrade...
"In many cases there aren’t two sides unless one side is 'reality' and the other is 'nonsense.'" - Phil Plait
Serious Audio Blog
DS-21 is offline
post #207 of 392 Old 03-31-2015, 09:25 AM
Point Source
beastaudio's Avatar
Liked: 3351
I never popped the hood on my 60f's, but if they are anything like the 50's, There are crossover components randomly strewn all over behind the horn, there really is no "Board" like in traditional speakers...Well sort of I guess:
post #208 of 392 Old 03-31-2015, 09:56 AM
Frohlich's Avatar
Quoted: 1180 Post(s)
Liked: 1128
^^^^Wow, that looks like me and my golf buddies had a bunch of spare parts, a few too many beers and just threw together a Frankenstein speaker....but as you know first hand, they sound terrific from all accounts.
Frohlich is online now
post #209 of 392 Old 03-31-2015, 02:50 PM
darrellh44's Avatar
Quoted: 749 Post(s)
Liked: 248
It makes sense the changes in the new SM60Fs may be mostly in the Xovers. I read on another forum that the caps in the current version are somewhat compromised musically in order for them to handle the large signals in their intended pro applications.
post #210 of 392 Old 03-31-2015, 02:51 PM
Quoted: 995 Post(s)
Liked: 522
Am I right in counting 12 inductors? (10 air core 2 cored)?
To me, that looks like one board (the green PCB) that can be popped out and replaced.
Serious Audio Blog
DS-21 is offline
Reply Speakers
Danley Sound Labs , Danley Sound Labs Dts 10 , D H Labs
