official danley sound labs thread - AVS Forum | Home Theater Discussions And Reviews
 48Likes
post #1 of 392 Old 01-17-2010, 05:20 PM - Thread Starter
steve morgan's Avatar
Quoted: 29 Post(s)
ok i think it is high time for an official tom danley sound labs thread . there is great interest in danleys products but it is very hard to find it all . for such an inovative desighn the only reason it gets ignored is the pro audio side and looks . its time to move on and give an officail thread for there products. the few people that have there product post some pics and thoughts . i would love some photos of a front wall of sh50 in someones home theater . anyone?
ellisr63 likes this.
steve morgan is offline
post #2 of 392 Old 01-17-2010, 06:53 PM
Kemet's Avatar
Also they do cost quite a bit, about $4k for a single?
Then there is the box size to deal with with a width of 28" makes 84" behind the screen on speakers alone, but I am sure they sound absolutely awesome in a high end large home theater with recommended amplification of 800-1600W you need a quality pro-amp to get the best out of them, or just go with their Class D active version.
Kemet is offline
post #3 of 392 Old 01-17-2010, 09:12 PM - Thread Starter
Quoted: 29 Post(s)
i dont disagree on price but thats becuase it rich for my blood. remeber there are alot of high end owners on the forum and 4,000 is probably on the low side for some not me
they do have new products comming out . one of the reasons i would like to get an official thread. try and keep all of it together .
post #4 of 392 Old 01-17-2010, 09:53 PM
Kemet's Avatar
True, it is too rich for my blood as well
With the SM60 that is supposed to be out in the first half of 2010 it should get interesting as it is smaller and less expensive than the SH50.
Kemet is offline
post #5 of 392 Old 01-18-2010, 08:13 AM - Thread Starter
Quoted: 29 Post(s)
i hope they do a good job on them as well it should really stur the pot.
post #6 of 392 Old 01-18-2010, 10:30 AM
Russell Burrows's Avatar
Quoted: 16 Post(s)
Well from what I can see they did do a good job in the DT/10 and its kit form for 950 dollars aprox. is a very good price.
However I am still wondering what the phone level actually is in the Danley fireworks audio?
Also whats the actual p.s.i. pressure level inside a dts/10 box versus a regular vented box p.s.i. in box measurement?
And congrats to Danley on a very well made subwoofer box but it leaves me wondering if its an extension of the levitating cork slices and high frequency whistle experiment?
Let me finish with a bravo! Danley! good job! on a new idea thats sure to turn heads with its extremely well done design and efficiency and last but not least the sound quality of a good subwoofer.
DIY beats store purchased.
Russell Burrows is offline
post #7 of 392 Old 01-18-2010, 12:40 PM
WilsonL's Avatar
SM60: prototype fiberglass version.
WilsonL is offline
post #8 of 392 Old 01-18-2010, 12:55 PM - Thread Starter
Quoted: 29 Post(s)
Would also appreciate knowing what the SM60 dimensions are.
The Pro version is 20.75"x20.75" x 16.5" deep. There will likely be a "home" version, that may be a bit taller and extend lower. Once we get the pro versions into production we will look at a more home friendly version
i am thinking the home versions will have different openings because in a home you need a wider off axis because most people sit 10-20 feet away . so if the beam is to narrow it wont sound to good imaging wise . tom will probably answer this but as usual it will be over my head
post #9 of 392 Old 03-13-2011, 01:55 PM
04FLHRCI's Avatar
This thread needs some traffic!!!
Anyone have the Danley SH-50/TH-50 combo?
Just sold my JTR Triple 8's, and my initial direction was to move to the JBL 4645C. I'm now having second thoughts, and believe I need to investigate the SH-50.
Where are the DSL owners???
Larry
04FLHRCI is offline
post #10 of 392 Old 03-13-2011, 03:44 PM
Ivan Beaver's Avatar
Quoted: 16 Post(s)
Liked: 59
That is a very common misconception. Yes you need that amount of power to be able to "get the most" out of them, but how many people are running their system at 130dB+???
Not many-at least in the home market. Because of the high sensitivity, you can get quite a bit of sound with normal amps. A standard 100watt amp will give you 120dB or more (depends on how you look at the SPL responses). That is usually more than enough for the full range part of the signal.
Yes subs will typically be hotter, so you would be looking at the range of 130dB+ in the sub range to keep up with a single channel with 100 watts and a SH50 on it.
Just keeping it in perspective.
It is surprising even in the pro market the number of people who make that mistake. So if it was rated at 100 watts (and had a max SPL rating 10dB less to go with it) would people feel better knowing they could push it "to it's max" with a normal amp? Maybe. But I would rather have a loudspeaker that is just "loafing along" and never gets pushed, than one that is constantly pushed to its max.
PS-there are some new ideas we are working on that may offer more options to the home market-but they are probably a couple of months away. No details than can be talked about yet-we have a lot of testing to do first.
Danley Sound Labs
Physics-not fads
Ivan Beaver is offline
post #11 of 392 Old 03-13-2011, 03:51 PM
carlm9's Avatar
Ivan,
I used to have a DTS-10 but had to sell it because of a recent move. The DTS-10 would not fit in my room. Any plans for a "Mini DTS-10"? I loved how deep and clean it played. My room is 13x17x15(tall). Do you have any sub that would give me something close to what I am missing? Thanks
Jason
carlm9 is offline
post #12 of 392 Old 03-14-2011, 05:12 PM
04FLHRCI's Avatar
DSL Team,
Are you aware of any SH-50 units in the KC Metro area I may audition?
Good heavens, this would be a lot of green sight unseen.
Larry
04FLHRCI is offline
post #13 of 392 Old 03-14-2011, 08:16 PM
forin's Avatar
Quoted: 13 Post(s)
Liked: 24
04FLHRCI,
After building my dts-10s and loving it I wanted to audition a few of their speakers. I contacted DSL about finding a dealer in the Cleveland area. They were able to get me in touch with one and he was able to scrounge up an sh-100, micro and sh96(??) for an audition. I think he mentioned that DSL has a number of speakers out at dealers for audition purposes. Give DSL a call and see if any dealers are within driving distance. My experience with both DSL and the dealer have been great.
Forin
forin is offline
post #14 of 392 Old 04-01-2011, 01:40 PM
04FLHRCI's Avatar
Came across a SH-96 image today:
source = http://www.cybertheater.com/danley-s...infocomm-2008/
04FLHRCI is offline
post #15 of 392 Old 04-03-2011, 09:34 PM
04FLHRCI's Avatar
fyi - there are 3 SH-95s listed in the classifieds.
04FLHRCI is offline
post #16 of 392 Old 04-30-2011, 08:30 PM
04FLHRCI's Avatar
Good Evening Everyone,
Finding time to enjoy the Danley gear is going to be challenging for a while; I have a couple remodeling jobs around the house which must be completed first.
I have carved out a couple dedicated 2 channel sessions, and watched a couple movies.
I'll continue to note my 'personal' experiences over the coming days to post my observations. I don't have the wealth of experience to draw upon as several of our members here, so I will likely rely upon generic emotional expression where I lack true audiophile objectivity.
After 4 hours of music and 2 movies, I find I'm unable to properly discribe the SH50 experience. I realize how this may seem, but I'm struggling with an appropriate method of describing the 'experience'.
It's unlike any I've had before, JTR, B&W, Wilson, Polk, ML, Paradigm... I have fond memories of all, but this is something special.
I have waited 2 years to own a pair of SH50, and every penny I pinched along the way was worth it!
Would like to spend more time wrapping my head around explaining these gems, but the wife and I are off to watch the latest Harry Potter BD...
Larry
04FLHRCI is offline
post #17 of 392 Old 05-01-2011, 02:30 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
04FLHRCI,
What made you go with the SH50's over the SM60f's?
Moto
MX48 is offline
post #18 of 392 Old 05-01-2011, 07:26 AM
04FLHRCI's Avatar
I'm a sucker for statement/flagship products within a company's product portfolio.
I assume the DSL team has the choice to utilize whichever model the prefer for their personal systems, and the SH50 is what Tom and Michael use at home.
All kidding aside; I run mains as full + LFE, and the SH50 digs deeper (HPF @50Hz).
Larry
Originally Posted by MX48 View Post
04FLHRCI,
Moto
04FLHRCI is offline
post #19 of 392 Old 05-01-2011, 09:41 AM
Quoted: 16 Post(s)
Liked: 59
I assume the DSL team has the choice to utilize whichever model the prefer for their personal systems, and the SH50 is what Tom, Ivan and Michael use at home.
Larry
Actually I don't have SH50's in my room-for several reasons . I use speakers I designed/built 20yrs ago. Mike and Tom do have SH50's.
I do have the origional DTS20 prototype that I built as my sub however.
Danley Sound Labs
Physics-not fads
post #20 of 392 Old 05-01-2011, 11:28 AM
HFGuy's Avatar
Quoted: 202 Post(s)
Liked: 179
How important are the HPF filters for home use ? I doubt anyone is going to be driving these things with enough low frequency content to damage them.
HFGuy is online now
post #21 of 392 Old 05-01-2011, 11:42 AM
04FLHRCI's Avatar
You are likely correct, I merely mentioned as the packaging contents recommends a HPF be used. I have no HPF in place now, and I start getting 'the' look at anything beyond -20 from reference driven via Face Audio F1200TS in stereo
04FLHRCI is offline
post #22 of 392 Old 05-01-2011, 11:44 AM
04FLHRCI's Avatar
Sorry Ivan, my bad, I have corrected my post...
04FLHRCI is offline
post #23 of 392 Old 05-01-2011, 01:11 PM
Quoted: 16 Post(s)
Liked: 59
I highly doubt you would ever "need" the highpass filters for home useage.
The purpose of the highpass filters to to provide a measure of protection against over exccursion of the woofers when driven to loud to hard.
Consider that the woofers are EACH rated at 700 watt continous (1400 program), the chances of damage in the home are VERY slim.
It would be REALLY REALLY loud before that would even start to be an issue-at least under any sort of normal circumstances.
Danley Sound Labs
Physics-not fads
post #24 of 392 Old 05-02-2011, 04:00 AM
MX48's Avatar
Quoted: 69 Post(s)
Liked: 40
Larry
Thanks Larry
Moto
MX48 is offline
post #25 of 392 Old 06-17-2011, 12:58 AM
chrapladm's Avatar
Quoted: 936 Post(s)
Liked: 350
04FLHRCI,
Moto
I dont know how I missed this thread but wondered the same thing. Does the SH50 just have alot more slam than the 60f?
chrapladm is offline
post #26 of 392 Old 06-17-2011, 06:03 AM
04FLHRCI's Avatar
Outside of their respective cut-sheets, I don't know how the two products compare in a listening environment.
My reasoning was purely based upon expected in-room FR; I like crossing my subs over @~100Hz, and prefer mains that can go an octave lower.
I believe I'm done chasing main channels now; I've either owned, or had extensive sessions with many salon products (folks in KC may be familiar with Audio Port - I've tried most of everything they support) like Martin Logan LS3, B&W 8xx series, Wilson CUB, Thiel (don't remember model), Infinity (legacy products like Kappa/Beta series stuff), AV123 RS850 (not bad units, Bosso continues to utilize a hot-rodded pair)and others.
04FLHRCI is offline
post #27 of 392 Old 06-22-2011, 01:57 PM
chrapladm's Avatar
Quoted: 936 Post(s)
Liked: 350
I posted this in the DTS10 kit thread and wanted to post here also. Is Scott still working at DSL?
I asked him a bunch of questions and never got a response yet.
post #28 of 392 Old 06-22-2011, 11:05 PM
chrapladm's Avatar
Quoted: 936 Post(s)
Liked: 350
Ok according to Ivan I have the correct email so I will just have to wait.
Out of these "Budget," DSL speakers can anyone tell me their opinion on each of them:
SH100
SH100B
SH95
SM60M
SM96
These were more along the lines of my budget. And considering I would need three of them I just figured I would look to hear others opinions. DO all these have the unique synergy sound?
post #29 of 392 Old 06-23-2011, 02:40 AM
flyng_fool's Avatar
Quoted: 182 Post(s)
Liked: 165
Yes, they will all have that synergy horn sound. The biggest differences I think are the radiation pattern that each horn has. Since each room is unique, I would defer to one of the Danley guys to tell you which ones would work the best for you.
Processor: Emotiva UMC-200
Blu Ray: Panasonic DMP-BD655
flyng_fool is offline
post #30 of 392 Old 06-23-2011, 05:54 AM
chrapladm's Avatar
Quoted: 936 Post(s)
Liked: 350
Well atleast they all have the unique sound. I will just have to wait for Ivan or others to help on the opinions of the other models. Radiation pattern I figure wouldn't need to be to big a worry as long as they can cover my small HT room. And being used for much bigger areas I think I should be fine.
Reply Speakers
Danley Sound Labs , Danley Sound Labs Dts 10 , D H Labs
