center speaker best matching with RS6 fronts? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 01-17-2010, 07:48 PM - Thread Starter
ddnathan's Avatar
Could you let me know what is the best center speaker matching with Monitor Audio RS6 fronts?
I was not able to buy RSLCR as they are being replaced by RX series.
I would like to have one stop higher center compared to fronts as most of my time with speakers is for movies rather than music.
I have used Athena C1.2 and then now Elac cc61. They are good but I feel that the sound from those center speakers is somewhat suppressed.... not reaching out enough... Maybe this is the issue from my AV receiver as I am using old denon 2105.
One of my audiophile friends recommended Paradigm CC590. He told me that I cannot be satisfied even with RSLCR if I cannot be satisfied with the current center. Is it good for the combination?
Any other recommendation or thoughts?
Thank you in advance!
ddnathan is offline
post #2 of 5 Old 01-17-2010, 08:23 PM
RonaldoCombs's Avatar
Here's a thought: Your "audiophile" friend is wrong.
The best center is another RS6, an RS1 or an RSLCR which are available and on sale here: http://www.saturdayaudio.com/picture...sale.htm#RSLCR
Ron
RonaldoCombs is offline
post #3 of 5 Old 01-17-2010, 10:51 PM - Thread Starter
ddnathan's Avatar
Ron
Thank you, Ron!! What about GRLCR? They are selling open boxed GRLCR at a very cheap price. I know it is discontinued but I think it is higher grade than RSLCR.
I heard that you can put higher grade center (same brand) in the system if you spend most of the time watching movies. Will GRLCR also work for me?
Thank you.
ddnathan is offline
post #4 of 5 Old 01-17-2010, 11:03 PM
Thank you.
I dunno.
I have not heard the higher grade center theory but it doesn't seem ideal.
I used to have a MA Bronze LCR with Silver L/R and I didn't feel it was ideal, but not sure if it was a timbre match problem. a quality difference, or a placebo effect.
I'd ask this in the Monitor Audio thread.
Ron
post #5 of 5 Old 01-18-2010, 03:25 PM
Casual_Observer's Avatar
I'd look around for a matching RS LCR, even if you have to transport it from interstate, it would be your best bet.
Casual_Observer is offline
Reply Speakers
