Best in-ceiling surround speakers for less than $1000?? let the debate begin! - AVS Forum | Home Theater Discussions And Reviews
Old 01-27-2010, 02:18 AM - Thread Starter
twinturbo11's Avatar
Quoted: 70 Post(s)
With newer/better technology, there is a definitely a trend towards hiding surround speakers these days. It's a topic that's still not being discussed much at the forums tho. Side-mounted in-wall speakers are great, but most of us dont have 2 perfectly positions walls on each side; some have windows, others have "open air" (as in the room extends into another room), etc. It seems like the perfect solution is in-ceiling speakers, especially the new type that you can manually point towards the listener's area, and can also be made "virtually invisible".
Anyone using them (budget of about ~$1000 or less per pair)and can share their experiences?
I'm currently thinking of the definitive technology UIW RSS II or UIW RSS III or DI 5.5BPS in-ceiling speakers... Some of the B&W CCM series seem interesting as well, especially the ones that can be pointed at the listener.
Another question: is 7.1 setup useless if the surrounds are in-ceiling and might as well go for a 5.1 setup??
twinturbo11 is offline
Old 02-27-2010, 08:39 PM
jacksonian's Avatar
Sorry the debate never got off the ground. I have the older DefTech BP/A in-ceiling surrounds for my rear surrounds in a 5.1 setup. I've considered adding another in-ceiling pair for 7.1.
But I might just replace the BP/A's with these UIW RSS II versions since they have their own cabinet/enclosure now. I hadn't looked at the B&W's, but I'll check then out.
jacksonian is offline
Old 02-28-2010, 05:39 AM
inthepit's Avatar
Paradigm also makes some good in ceiling speakers.
inthepit is offline
