B&W 602s3 vs Paradigm Studio 20v5 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 01-30-2010, 07:38 PM - Thread Starter
parksar's Avatar
Thinking of changing my B&Ws (with the LCR 60 center (the big one, I think)) for three Studio 20 v5 speakers across the front.
I await your thoughts....
parksar is offline
post #2 of 7 Old 01-30-2010, 08:00 PM
osofast240sx's Avatar
what do your ears tell you? I would tell you Paradigms all the way but some members will be on my ass quick.
osofast240sx is offline
post #3 of 7 Old 01-30-2010, 08:11 PM
RonaldoCombs's Avatar
Seems like a lateral move to me, although I think you get real wood finish with the 'digms, if you notice a decent improvement go for it.
I think that if you listen to both B&W and Paradigm back to back you should know immediately what you prefer. I fall in the B&W camp, but barely, they are both great.
I'd add Dali, PSB, and Revel to the mix as speakers to audition.
Ron
RonaldoCombs is offline
post #4 of 7 Old 01-31-2010, 05:38 AM
DogEarz's Avatar
"I would tell you Paradigms all the way but some members will be on my ass quick." ;-)
And I would tell you, you really need to listen to them. I'm the proud owner of 602 S2's! For my earz, the difference between Paradigms & my 602's was that the Digms sounded like there was a blanket draped over them. At first I thought they sounded pretty good, but the longer I listened to them something just seemed a little off. It began very subtly but I eventually I realized what I was hearing. That's why you need to listen for yourself, you may prefer them over the 602's.
Dali & PSB are very good options. The dealer where I originally purchased my speakers has recently switched from B&W to these + Monitor Audio. They had an open house featuring their new lines so I went to hear for myself. If you like the B&W sound, you may very well like these.
If you have a dealer where you can audition, ask if you can bring in your 602's to audition side by side. Or, better yet, see if they would let you borrow a pair of the Studio's to try in your room.
Good luck, but mostly have fun!
DogEarz is offline
post #5 of 7 Old 01-31-2010, 07:22 AM
need a Q-tip thats a first "blanket draped over them" ok sure
post #6 of 7 Old 01-31-2010, 07:25 AM
the studio 20 are going to shine in the bass department. as for the 602's they are not as full as the 20's so your going to need a good sub.
post #7 of 7 Old 01-31-2010, 07:51 AM
DogEarz's Avatar
"need a Q-tip thats a first "blanket draped over them" ok sure"
Maybe I could use the Q-tip to lift the blanket off of them! Which was exactly my point; you obviously like the sound of Paradigms, me...not so much! And, since neither you or I are buying speakers, Parksar really needs to hear the difference for him/her self. As I said, he/she may, or may not like them.
"as for the 602's they are not as full as the 20's so your going to need a good sub"
Since it sounds like these are for HT, hopefully Parksar's already got a good sub. ...at least good enough to keep up with the 602's!!
DogEarz is offline
Reply Speakers
