Music System setup for around $1000 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 29 Old 02-06-2010, 01:28 PM - Thread Starter
youcbe's Avatar
I listened to Bose 901 setup the other day and was very impressed. But like many others here, I think Bose are way over priced for the quality you get out of them. Can I get the same quality in a different package and price? I am looking for something around $1000 for the entire setup (speakers, receiver and player). I am looking for tiny/small speakers. The set up is primarily for listening to music but might play a movie once in a while (Blu Ray capability is not a must but HDMI input will be nice). It will be setup in a 16' x 16' room. I am planning on mounting the speakers on the walls. I have outlets setup in the walls for upto 8 speakers (4 corners and 4 centers). Hope I am not asking for too much. Would really appreciate the help.
youcbe is offline
post #2 of 29 Old 02-06-2010, 02:27 PM
clemsonpablo's Avatar
why do you want small speakers? I mean, it sounds like just about any standard box set would do you fine if you're going to go small, and if it doesn't say Bose on the box, you will probably be paying substantially less.
clemsonpablo is offline
post #3 of 29 Old 02-07-2010, 07:34 AM - Thread Starter
youcbe's Avatar
Ok, what would you recommend instead? Any particular models you have in mind? I am open to options.
youcbe is offline
post #4 of 29 Old 02-07-2010, 07:47 AM
tdogroeder's Avatar
Quoted: 41 Post(s)
Liked: 81
Energy Take 5 speakers without sub from newegg for $200 + shipping, these are able to mount on a wall. http://www.newegg.com/Product/Produc...rgy-_-82269004
You can get a $200-$300 refurbed receiver from accessories4less on the cheap. http://www.accessories4less.com/make....page=4b6ed36c
ED sub for $350 + shipping. http://www.edesignaudio.com/product_...roducts_id=407
Sony bluray player for $114 from amazon. http://www.amazon.com/Sony-BDP-S360-...5554658&sr=8-1
John 14:6 & John 3:16
Yamaha RXV765 & Emotiva LPA-1
Ascend Sierra-2s(LCR), RSS300, Polk R15, SVS PB12 plus
Panasonic S65, Sony S5100, PS4, PS3, XBOX 360
tdogroeder is offline
post #5 of 29 Old 02-07-2010, 07:59 AM
Blazer1's Avatar
Pass on the Bose, you can do much better for less $$$.
I would be looking into a nice 2.1 system, two bookshelves and a sub woofer.
I am not going to recommend speakers as I am not qualified but I will offer some advice I learned from my first system purchase.
1.) If the choice is quantity or quality, choose quality! (With your budget get a couple of really nice speakers instead of 5 or 7 decent speakers.)
2.) The speakers are where you should spend your money, don't get to caught up in super duper powerful receivers with all the latest gadgets.
3.) The quality of your sound system will increase in direct proportion to the amount of time you spend researching here. Don't get in to big of a hurry!
4.) If you want to buy a system and being happy with it for the next 10 or 15 years NEVER return to this forum again! You will inevitably read a thread about how your new speakers sound terrible compared to X,Y, and Z speaker brands.
Blazer1 is offline
post #6 of 29 Old 02-07-2010, 10:24 PM - Thread Starter
youcbe's Avatar
I see that Energy Take 5.1 system has been discountinued. It seems like it has impressed a lot of people, I wonder why they discontinued it. I am glad you could get the same speakers in a different package. Thanks for the specific recommendations.
youcbe is offline
post #7 of 29 Old 02-07-2010, 10:32 PM - Thread Starter
youcbe's Avatar
Thanks for the advice. I do see your point about quality vs quantity. But it seems like you could get a nice but not neccessarily earth shattering 5.1 system for around $1000. Do you mean to say a better quality 2.1 system that costs the same would beat the kind of 5.1 system that tdogroeder has suggested above?
youcbe is offline
post #8 of 29 Old 02-07-2010, 10:47 PM
RonaldoCombs's Avatar
Energy RC-10s from Vanns, or Infinity P362s along with a decent sub and receiver and you are in business! Both of these will outperorm tiny satellites - what is the appeal of multiple small speakers?
Energy Micro or Mini series kill Bose even more than the Takes, not as good as the above mentioned speakers, but if you are determined to go 5.1 tiny they're very good choices.
Ron
RonaldoCombs is offline
post #9 of 29 Old 02-07-2010, 10:49 PM - Thread Starter
youcbe's Avatar
Could anyone comment on Aperion Intimus 4 type speakers, towers and subs? I know its well above my budget I mentioned here but I could take a big leap if it would make a significant difference. Also any other comparable quality system recommendations would be appreciated as well.
youcbe is offline
post #10 of 29 Old 02-07-2010, 11:04 PM
Since you were very impressed by Bose I am guessing you don't have a ton of experience with different speakers?
I strongly recommend going out and listening to a bunch so that you can figure out what you like. Speakers are like the music that comes out of them, kinda hard to know what you will like by reading about them, but that gets easier once you have a baseline to compare against.
Start with these - some them will be out of your stated price range but it's a worthy exercise:
PSB, Boston Acoustics, Energy, Infinity, Paradigm, KEF, Dali, B&W, Revel. All of these are good, some of them are amazing.
Bring your own music, stuff you are familiar with and a variety inclucing both male & female vocals, electronic and acoustic instruments, and listen through 70-90 watt per channel receivers. If you are at a high end store don't let them play through their fancy electronics, they've already stacked the deck with good room acoustics.
Ron
post #11 of 29 Old 02-08-2010, 06:19 AM
Geek From NJ's Avatar
Onkyo 607 is a nice receiver on the cheap!
Geek From NJ is offline
post #12 of 29 Old 02-08-2010, 10:11 AM - Thread Starter
youcbe's Avatar
You are right. But I know Bose' should not cost as much for the sound they produce.
Thanks for your advice on checking out the speakers for myself. I should do that and I am going to.
I see that RC Minis are comprable to Aperion 4Bs in size and price. Any idea how they compare?
RC Mini>>
Aperion 4B>>
youcbe is offline
post #13 of 29 Old 02-08-2010, 10:41 AM
Blazer1's Avatar
The main reason to put "quality over quantity" is that many , many people buy what they can afford at the time and later wish to up-grade. If you spend more on a a 2.1 system then you do not have to worry about selling the cheaper 5.1 system you purchased.
Surround sound is a gimmick(I will get blasted for that comment), spend your money on a quality 2.0 or 2.1 system and up-grade to a 5.1 or even a 7.1 when you have the funds. While saving for the surround speakers you will have to endure listening to some really nice speakers.
Blazer1 is offline
post #14 of 29 Old 02-09-2010, 09:13 AM - Thread Starter
youcbe's Avatar
... spend your money on a quality 2.0 or 2.1 system and up-grade to a 5.1 or even a 7.1 when you have the funds. While saving for the surround speakers you will have to endure listening to some really nice speakers.
I totally buy this argument.
youcbe is offline
post #15 of 29 Old 02-09-2010, 09:14 AM - Thread Starter
youcbe's Avatar
Thanks for all the help so far. My biggest issue now is to find stores that specialize in home theater systems to check out some speakers in person. There is a Best Buy near by but other than that I couldn't find any other place. I live in Atlanta, GA. Any recommendations?
youcbe is offline
post #16 of 29 Old 02-09-2010, 10:30 AM
rick240's Avatar
Quoted: 18 Post(s)
Liked: 52
Surround sound is the ONLY way to completely experience a movie - and 5.1 SACD sound fabulous
But I absolutely agree with this - more than once i have been exploring an upgrade less than 2 months after making a purchase
rick240 is offline
post #17 of 29 Old 02-09-2010, 10:46 AM
Dit4Dat's Avatar
Getting a whole package a once can be a pretty easy thing to do. Just wire it up throw in a movie and duck your head while the bullets fly around. Nothing wrong with that.
But... If you want to educate yourself as to what makes a good sound system and/or speakers there really is no substitute for getting out there and auditioning a bunch of stuff. You'll find a lot will be 'meh' to you. But... then one day one place the magic will happen. Ahh. So this is what makes those people crazy about audio. After that you can have a little funeral for your old self and we will welcome a new audiophile to the fold.
Dit4Dat is offline
post #18 of 29 Old 02-09-2010, 11:04 AM
Blazer1's Avatar
Okay, maybe I was a bit dramatic, surround sound makes a huge difference in movies. I have a 5.1 system myself but I do think the need to purchase a 5.1 or God forbid a 7.1 system has prohibited some people from enjoying some really nice speakers.
Blazer1 is offline
post #19 of 29 Old 02-11-2010, 05:07 PM - Thread Starter
youcbe's Avatar
Thanks everyone. Appreciate all the valuable information.
youcbe is offline
post #20 of 29 Old 02-12-2010, 12:41 AM
Lurkerage's Avatar
I also agree with spending more on just a nice pair to start with and add the rest as funds become available. I have wasted too much money getting a bunch of stuff I could afford now instead of focusing on a more meaningful upgrade that would keep me happy for more time.
If you want to get something you know you won't change out for at least a few years then go the 2.0 or 2.1 route and get the best you can with the money you have now instead of wasting it on a 5.1 setup that is gonna sound good for a while but then make you think what if I had these instead later on.
I recently invested in some monitor audio rx6's that set me back quite a bit, but I know I will be happy with them for years. The main front speakers are by far the most important if you love music as you will be using stereo mode if you ever listen to music(well most people prefer stereo for music). For movies having a nice center is important, but not necessary right away, I have done fine using virtual surround on my receiver until I could get the center for my deftech pm1000's, and now I wish I would have saved a little longer from the start and gotten the towers I really wanted instead.
Well anyways that's just how I feel about it but it really is going to come down to whether you just want a whole system now, or are willing to go the slower path with better speakers
Lurkerage is offline
post #21 of 29 Old 02-12-2010, 08:19 PM
mphfrom77's Avatar
Quoted: 476 Post(s)
Liked: 344
Here's two links to forums where I have links to prices and where to find them.
I think these Energy speakers would be a nice 5.0 setup- 2 pairs for rears and fronts being CB-5 speakers and one center channel CC-5. I provide president's day sale links for those two on the Energy owner's thread near the bottom of page 585 post 17534 -http://www.avsforum.com/avs-vb/showt...30450&page=585. That would come out to $345 for a 5.0 system.
I also like the potential of this setup, but I would have to do more research, concerning if the speakers would work well together. I posted on this thread on page 1 post 7 http://www.avsforum.com/avs-vb/showthread.php?t=1225880.
If you used the same subwoofer for both systems, the BIC f12, there would be about a $200-$230 difference it seems. The CB-5/CC-5 system would be, by far, a smaller on wall speaker system, but from what I understand possibly a very good one.
mphfrom77 is offline
post #22 of 29 Old 02-12-2010, 11:20 PM
ProjectEF's Avatar
Quoted: 17 Post(s)
Just to throw more options into the mix. SVS has some surround packages that would make a great starter system with that budget. Their 5.1 SBS-01 package with a PB10-NSD sub is only $1055 (pre order price) or with PB12-NSD at $1199 (pre order price) http://www.svsound.com/products-sys-sbs_black.cfm
Also check out the Jamo C607 towers and a good sub for just a 2.1 system.
ProjectEF is offline
post #23 of 29 Old 02-14-2010, 05:56 PM - Thread Starter
youcbe's Avatar
Thanks for the new posts guys.
In addition to the thoughtful recommendations you guys have given me here, I have been doing some reading, going through various threads and reviews of speakers. While reading a review, I had an epiphany and totally saw why it makes so much more sense to get a pair of phenominal speakers (like some of you have recommended here) instead of going for a 7.1 setup. This way I could even do away with the Sub since the high end speakers can take care of the lows, In fact its propbably better that way since I'll be using the system to listen to music much more than to watch movies. Of course I have the option to add speakers as I go and have a 7.1 set up when I am a rich man
I narrowed down to two models, Swan D2.1 SE and Ascend Sierra 1. Both have phenominal reviews and I am torn between the two.
I would really appreciate any advice on the kind of electronics (amps, preamps, receivers, players) I need to drive these speakers from the perspective of music listening.
youcbe is offline
post #24 of 29 Old 02-17-2010, 09:40 PM - Thread Starter
youcbe's Avatar
I have not received any responses in the last few day. May be this thread's purpose has been achieved? Anyway with that assumption I have created a new threat at http://www.avsforum.com/avs-vb/showthread.php?t=1228097 . Any advice will be greatly appreciated.
youcbe is offline
post #25 of 29 Old 02-26-2010, 06:45 AM - Thread Starter
youcbe's Avatar
Alright guys, here is what I ended up purchasing...
Oppo BDP 80
Pioneer VSX 9040 TXH
Swan D2.1 SE for R & L
Energy Take 5.0 for Sorround and Center
I still need to get a sub. I am thinking of HSU STF 1.
As you can see I had to change my budget, as in doubling it.
The system is worth every penny and much more...
youcbe is offline
post #26 of 29 Old 02-26-2010, 08:00 AM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
Oppo BDP 80
Nice system. You did well! Those Swans go pretty low on their own. A sub will get that last few notes you are missing.
I would recommend getting the matching center channel for your speakers down the road. Having a matching front 3 is really important. The side and back speakers not so much. I don't know what would match your speakers from Swan. There is a thread here for Swan speakers.
As for the sub I would save and get something spectacular. $700 is usually a good level for great bass. You can get good bass for less (like the sub you are looking at). The VTF-3 would be a much better performer for not a whole lot more. I would really read up on subs to get a better understanding of what they do and how they do it. You don't want bloated bass which many poorly designed subs give you.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
post #27 of 29 Old 03-12-2010, 01:02 AM - Thread Starter
youcbe's Avatar
Thanks. I have decided to strike a balance between STF 1 and VTF 3. I am getting the HSU STF 2. Hopefull that will be good enough for my 16 x 16 x 10 room.
I am guessing the Swan D1.1 Center will be a good match. But that upgrade will have to wait for now.
youcbe is offline
post #28 of 29 Old 03-12-2010, 07:25 AM
Quoted: 73 Post(s)
Liked: 112
The STF-2 is a great sub and plenty for that room
rnatalli is offline
post #29 of 29 Old 03-12-2010, 09:19 PM - Thread Starter
youcbe's Avatar
Great to know that
youcbe is offline
Reply Speakers
