3.1 Setup - High End Monitors/ Center - F113 Pairing - 48" Width Max - AVS Forum | Home Theater Discussions And Reviews
post #1 of 9 Old 02-06-2010, 04:18 PM - Thread Starter
chefwong's Avatar
Budget - 3-4K max. New or used (audiogon).
Any recommendations based on the following specs
Max width where all 3 will sit horizontal. 48" long.
Sub TBD but I have my eyes on a very good deal (F113).
Usage will be primarily HT / everyday television dialogue.
DOES not have to be a single box encompassong LCR in one box.
Ideal can be 3 high quality monitors.
I don't have space to the left/right .
Thus all 3 will be sitting horizontal on my media console
Totally audio noob but I'm forgoing the whole surround concept of my bunk sounding YSP-510 in favor of better drivers for a better LCR frontend audio setup.
chefwong is offline
post #2 of 9 Old 02-06-2010, 04:30 PM
ickysmits's Avatar
ickysmits is offline
post #3 of 9 Old 02-06-2010, 06:57 PM
gchanjam's Avatar
If I were in your situation, I would look at 3 Triad Silver/Gold MiniMonitors. Relatively low profile and terrific when used with a good sub which you already have.
gchanjam is offline
post #4 of 9 Old 02-06-2010, 07:11 PM - Thread Starter
chefwong's Avatar
Have not looked at the Triad, but sofar....looking at the Paradign CC-490 and may compromise with stereo (dual centers) due to the layout of the drivers.
chefwong is offline
post #5 of 9 Old 02-07-2010, 08:48 AM
Kal Rubinson's Avatar
Quoted: 681 Post(s)
Liked: 461
How far away are you sitting? If much more than 4 feet away, I see no reason to have a center channel speaker.
Kal Rubinson
"Music in the Round"
Kal Rubinson is offline
post #6 of 9 Old 02-07-2010, 08:51 AM - Thread Starter
chefwong's Avatar
Around 7-8 feet This is in a rec room.
I put a Yamah YSP-5100 on my console and just hated the sound output of it. Diaglouge is nowhere as nice as even 2 high end monitors....
So I decided to swap them out and redo the setup. My only issue is the 48" width horizontal setup.
chefwong is offline
post #7 of 9 Old 02-10-2010, 05:41 PM
thecutter's Avatar
Quoted: 142 Post(s)
Liked: 48
Kal,
I plan on placing monitors arond my 52" TV. I will be sitting 12 ft away. Should I forgo a center channel and get only 2 fronts and a sub. I don't want surround speakers.
thecutter is offline
post #8 of 9 Old 02-10-2010, 05:47 PM
paulsax's Avatar
given all this I would suggest two quality bookshelves and your sub. lots of really nice small speakers for that budget. I agree with Kal on the center. If you do want a center just get three of the same bookshelf units.
paulsax is offline
post #9 of 9 Old 02-10-2010, 05:47 PM
batpig's Avatar
Quoted: 3575 Post(s)
Liked: 3420
I agree with Kal -- if you are just going to have the L/R speakers flanking the TV (e.g. about 4 feet apart), and you aren't even going to have surrounds, there is no point in a center channel. 12 feet away from speakers 4.5ft apart definitely fits this generalization.
The good news is that concentrating on a 2.1 setup will expand your effective budget considerably
batpig's "Denon-to-English Dictionary"
Setup Guide and FAQ
http://batpigworld.com/
Become a fan "batpigworld.com" on Facebook!
batpig is offline
Reply Speakers
