5.1 system advice - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 03-01-2010, 11:03 AM - Thread Starter
Agentbolt's Avatar
Quoted: 51 Post(s)
Liked: 40
Hooking up speakers into an Onkyo TX-SR604 and a Sony KDS-60A2000. Room size is 14x15x8 (small-ish apartment). Looking for a verrry low budget 5.1 system. The two I'm aware of are the Dayton HTP-1
http://www.parts-express.com/pe/show...number=300-692 (8 inch is the only one currently in stock)
And the Polk RM6750
http://www.amazon.com/Polk-Audio-Cha.../dp/B0002WTK4S
So two questions: Would there be any noticeable difference between the two speaker sets?
And are there any alternatives for a full 5.1 system. My absolute max budget is like 275 bucks shipped, and more like 200 would be preferable. I'd assume piecing one together out of satellites and a sub would be out of the question with my budget.
I'm fine with used/refurbished/ebay. Any advice is appreciated. Thanks!
Agentbolt is offline
post #2 of 4 Old 03-01-2010, 11:22 AM
marlin29311's Avatar
The Polk system is an amazing system for the price and it really can't be beat. Another recommendation would be the Energy Take 5.0 system which is about $200, but I personally loved the RM6750 when I was using it.
Sharp AQUOS 46" LED (LC46LE700)
Pioneer VSX-9130 TXH-K
Paradigm Cinema Phantom
Xbox 360 Elite (GT: Redfox29311)
LG BD270 Bluray
All the Monoprice wires you can find
marlin29311 is offline
post #3 of 4 Old 03-01-2010, 11:31 AM
cdy2179's Avatar
Quoted: 742 Post(s)
Liked: 431
I doubt anyone here has heard both systems so it's a toss up... unless someone heard both systems no one here can really give you an honest answer beyond saying brand "x" is good.
Go and see if you can find the Polk system at Best Buy or something... and compare it to other similar priced systems and see what your ears think!
cdy2179 is offline
post #4 of 4 Old 03-01-2010, 07:09 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
I personally have the RM6750's and I love them for my room 13.75' x 14.5'
I have tested them against the Klipsch HD300 & HD500, Boston Acoustics MCS100, Polk RM705.
Out of the ones I sound tested the Polks sounded the best. I went with RM6750's because they sounded the same as the RM705's and were have the price.
Energy Takes 5.0 are $230 and then you need to buy a subwoofer for around $125
The RM6750 5.1 set is the best value sounding system
crazyrob425 is offline
Reply Speakers
