Tentative Setup, Seeking Input - AVS Forum | Home Theater Discussions And Reviews
Old 03-02-2010, 01:38 PM - Thread Starter
vexion's Avatar
Hey guys,
I'm brand new to the AV world, wholly uneducated, though I'm trying to take the plunge. I have about a ~$800 budget I want to spend for a living room setup, 14x12 room with hardwood floors, that will be used 90% for movies and games, 10% for music.
So far I'm leaning towards either the Energy Take Classic 5.1s, or the Energy Take Classic 5 Pack (5.0) with some sub, either way paired with a Pioneer VSX-1019AH-K receiver.
A few questions:
1) Which direction should I go, or a completely different one? Considering the constraint is staying under-budget.
2) If I went Option 2, what sub should I pair with the Takes?
3) Is this a good receiver?
4) Is this the wrong forum for receiver and sub advice?
5) If I wanted to, where would be the best place in this setup to pare down to save money?
Thanks in advance!
[EDIT: Or Newegg is offering the Take 5-Pack with the Yamaha RX-V365 Receiver for $300, which is a substantially cheaper receiver than the Pioneer. So there's another option.]
vexion is offline
Old 03-02-2010, 03:40 PM
mbyrnes's Avatar
Quoted: 93 Post(s)
Liked: 186
The 365 is really limited in HDMI inputs and low on power. I would look for a refurb unit from last year. Onkyo 606, Denon 1909, etc. The Pioneer would be fine. I would get the Energy speakers as they are very well regarded for the price. I don't know what you have in subwoofer money but do internet direct. HSU I believe has subs at all price ranges and would be a good place to start. SVS is another but may be out of your price range.
Xbox Live: TheRealMaxPower --- PSN: TheRealMaxPower (no PS4 currently) Panasonic TC-P65VT60    Vienna Acoustic Mozart Grands    Pioneer SC-72   Sony BDP-S790 Xbox One S Astro Mixamp 2013   Soundblaster X7 (Sparkos Op Amps) Schiit Modi Multibit/Magni   LTA MicroZOTL2 AKG K702 65th Anniversary   Fostex TH-X00 Ebony DT990 Pro 250 ohm  Massdrop/Sennheiser HD6XX and PC37X Audio Technica ATH-M50x Antlion ModMic
mbyrnes is offline
Old 03-02-2010, 05:43 PM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
$800 budget. Do the speakers have to be small like the Takes?
To pare down your pricing I assume you're paying roughly $500 for the Pioneer 1019?
Get the Yamaha 765 this weekend. The price has been lowered every weekend for the past few weeks to $399. It'll be on sale either Saturday or Sunday at Newegg.com
If you really want a Pioneer the VSX-919 can be had under $400.
http://www.amazon.com/exec/obidos/tg...X0DER&v=glance
You can also get the Denon AVR-1910 under $400 shipped from Electronics Expo.com.
http://www.electronics-expo.com/make...AVR1910/1.html
They have a 30% off sale if you use the promo code AUDIOSALE at checkout. It takes you to Amazon.com and before you hit the final checkout screen the price drops to $396 including shipping. The AVR-1610 can be had ~$300 with the discount which would help you with your budget.
http://www.electronics-expo.com/make...AVR1610/1.html
If you want the Takes then get them. The price used to be $150 but now its $229. You'll still need to add a subwoofer though. Best I could find and still stay under your budget is the BIC V1020. Under $160 shipped.
http://www.parts-express.com/pe/show...number=303-430
Another option is the Jamo S413 package which comes with the sub.
http://www.vanns.com/shop/servlet/it..._c=site_search
I have Jamo speakers but not this package, so I dont know the quality of this system. But I really like my Jamo E680/E660 towers.
Afro GT
afrogt is offline
Old 03-04-2010, 08:35 AM - Thread Starter
vexion's Avatar
Thanks for the input guys. I'll start shopping for cheaper receivers. Either way, it seems like this won't come together for a few months. So I'll be poking around for deals every week.
vexion is offline
