In-Ceiling Surround Question - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 03-03-2010, 05:01 PM - Thread Starter
Zeldain's Avatar
While I realize in-ceiling home theater is not the ideal way to go, it's the only option I have. This is a family room setup, not a dedicated theater.
The way the room is pre-wired, the surrounds are actually to the sides "above" the seating/viewing area, instead if behind it (there's a wall right behind the sofa.)
So my question is, what would be the best way to orient the surrounds?
I am planning on getting a set of in-ceiling speakers with the adjustable/angled setup to allow me to aim things at the seating area, and for the surronds, I wonder how I would best be served. Aiming them at the seating? Or at the back wall? Maybe at the side wall (the back and side walls are equidistant from the speakers)
And while I'm at it, any recommendations for speakers? Looking at the Jamo 610 series, the JBLs, maybe the Klipsch (though I don't really want to spend $1000 per speaker... I think it's unnecessary given the application.)
Thanks for any input!
Zeldain is offline
post #2 of 7 Old 03-04-2010, 10:50 AM
Micah008's Avatar
Episode has some speakers I am considering that would work for this... ES-500-ICSURR-6
They are in ceiling bi-pole/di-pole.
I haven't heard them, but I like the idea.
Micah008 is offline
post #3 of 7 Old 03-04-2010, 11:29 AM
inthepit's Avatar
Paradigm, NHT, and Monitor audio all make good in ceiling speakers. And all well below your price range. Who made your fronts?
inthepit is offline
post #4 of 7 Old 03-04-2010, 11:36 AM - Thread Starter
Zeldain's Avatar
They all have to be in-ceiling unfortunately.... fronts and surrounds as well. I still have my Paradigm PS-1000 sub which I am going to use.
I think the hardest thing is auditioning these things... so forgoing that, I'm just trying to make an intelligent choice based on a balance of quality and price.
Zeldain is offline
post #5 of 7 Old 03-04-2010, 12:08 PM
inthepit's Avatar
Consider in-wall as well if you haven't already. Just go find a Paradigm, B&W, and Speakercraft dealer that has an in ceiling demo and buy the ones you like most. I don't think you'll have any issues finding a good in-ceiling speaker with your budget.
inthepit is offline
post #6 of 7 Old 03-04-2010, 03:00 PM
jamulian's Avatar
I had to get the in ceiling for now also. I have Paradigm speakers and sub so I went with the Paradigm straight shooting (no angle and no dipole). I won't have them hooked up for a couple of weeks though.
jamulian is offline
post #7 of 7 Old 03-04-2010, 05:18 PM
Mark Paquette's Avatar
I have Paradigm SA-15R in ceiling speakers that I'm using as surrounds in a 5.1 setup. They are installed to the sides of the main listening position, firing straight down. Do they sound OK? Yes. Is it ideal? No, but like you, I had no other choice in this non-dedicated room.
Mark Paquette is offline
Reply Speakers
