PLEASE HELP. Need help angle mounting JBL L820's - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 03-11-2010, 03:57 PM - Thread Starter
beckerdane's Avatar
Purchased a pair of JBL L820's to use as rear surronds. I wanted to mount them at the top of my wall and angle them down towards the listening area. They come with brackets but they are only made to be mounted straight against the wall. I have looked at all types of different speaker mounts and can't find any that will work to attach to the speaker and allow me to angle it down short of drilling holes in the box. The speakers come with pre drilled mounting holes 8.5" apart and each speaker weighs almost 20lbs. Please any help would be very much appreciated. Thanks
beckerdane is offline
post #2 of 3 Old 03-11-2010, 06:47 PM
DonH50's Avatar
Quoted: 2105 Post(s)
Liked: 1667
There are swivel speaker mounts (used some at our church) but I don't recall the brand -- a Google search should turn up some at many places (Best Buy, etc.) Double-check the weight rating. You might also look for a TV swivel wall mount that you can use, or modify to use, with your JBLs.
HTH - Don
p.s. You could also screw some bolts/eye hooks into the speaker and matching hooks on the wall, using them and some cable/rope/ties/bungees/whatever to suspend the speakers. The vibration may mess up the imaging a bit if they are not tied down well, but you'll probably not notice on surrounds.
"After silence, that which best expresses the inexpressible, is music" - Aldous Huxley
DonH50 is online now
post #3 of 3 Old 04-01-2010, 01:03 PM
Mrkazador's Avatar
Quoted: 262 Post(s)
Liked: 390
Do something similar to this
http://www.avsforum.com/avs-vb/showthread.php?t=1229018
Mrkazador is offline
Reply Speakers
