Getting a 2.1 system looking for speakers under $150 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 03-12-2010, 02:54 PM - Thread Starter
Darkhunter139's Avatar
I am looking for some speakers to build a 2.1 system with. I am going to be starting out with just a receiver and 2 speakers but will get a sub eventually.
I was looking at the Polk R150's which are $99 for a pair. Are they any good or can I do better for that price?
http://www.amazon.com/Polk-Audio-Two...8430839&sr=1-1
Darkhunter139 is offline
post #2 of 5 Old 03-12-2010, 02:58 PM
Fihsak's Avatar
They are OK. You can get better polk deals on ebay. they have an outlet
Example:
http://cgi.ebay.com/PAIR-TSi200-BLAC...item35a79b867e
I am sure others will chime in with better options.
Fihsak is offline
post #3 of 5 Old 03-12-2010, 03:02 PM - Thread Starter
Would the TSI100s or Polk Monitor 30s be better then the R150s? They are like $130
post #4 of 5 Old 03-12-2010, 04:27 PM
cornhulio's Avatar
Might as well get this Jamo 5.1 set for $200 shipped http://www.vanns.com/shop/servlet/it..._c=site_search
Polk SL2000WC $3 DIY mod. Smaller the uf, the less harsh your SL2000 is.
1. SRS: .47 uf/250v mylar cap top SL2000, 1.0 2nd, 1.0 3rd, .47 bottom
2. 2.3: 1.0 middle
3. 1C: 1.0 top
4. 2B: 1.0
cornhulio is offline
post #5 of 5 Old 03-12-2010, 04:42 PM - Thread Starter
Well my brother is actually getting these and he does not want 5.1
I think I am going to go with the Monitor 30s on newegg for $90 after coupon code.
Reply Speakers
