No audio output jack on TV - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-05-2010, 02:37 PM - Thread Starter
techlectics's Avatar
My mother has a Magnavox 32MF338B LCD TV and she would like to connect cordless headphones so she can watch movies at night and not bother anyone. I looked at the manual and he only audio output I see is a coaxial digital output jack. Does anyone know it I's possible to connect the headphones?
techlectics is offline
post #2 of 10 Old 04-05-2010, 06:07 PM
rynberg's Avatar
Not without using a receiver. I'm stunned that a TV wouldn't even have a single analog audio out.
rynberg is offline
post #3 of 10 Old 04-05-2010, 06:13 PM
rick240's Avatar
Quoted: 28 Post(s)
Liked: 53
I just looked on CNET and they talk about a 3.5mm headphone jack
Does that not exist?
Edit: just looked at the manual and it definitely show only coax digital, odd.
rick240 is offline
post #4 of 10 Old 04-05-2010, 06:45 PM
ccaliban's Avatar
Not so odd these days, my LG47 has optical audio out only. Fortunately, my receivers have optical inputs.
Someone WHO KNOWS WHAT THEY ARE DOING might be able to wire a headphone jack and muting switch to the speaker leads for her.
ccaliban is offline
post #5 of 10 Old 04-05-2010, 07:46 PM
maxcooper's Avatar
Quoted: 13 Post(s)
I don't know if this is the cheapest solution, but it seems like it would work (optical to stereo analog converter):
http://www.amazon.com/StarTech-AA2SP...ef=pd_sim_e_10
-Max
maxcooper is offline
post #6 of 10 Old 04-05-2010, 08:11 PM
ccaliban's Avatar
It seems to be a line level device that would not drive headphones, she would still need an amp.
ccaliban is offline
post #7 of 10 Old 04-05-2010, 08:58 PM
maxcooper's Avatar
Quoted: 13 Post(s)
The OP wants to connect cordless headphones. Cordless headphones often accept line level inputs.
-Max
post #8 of 10 Old 04-05-2010, 11:52 PM
ccaliban's Avatar
I knew that, I think my brain was out of gear. I stand corrected, thanks.
ccaliban is offline
post #9 of 10 Old 04-07-2010, 12:29 PM
CloneX's Avatar
Many wireless headphones have digital inputs so if she doesn't yet have the headphones look for a pair with a digital input. Some possibilities:
Pioneer SE-DIR800C
http://www.pioneerelectronics.com/PU...E-DIR800C.Kuro
Sony MDR-DS3000:
http://www.sonystyle.com/webapp/wcs/...ab=featuresTab
Panasonic RP-WF6000-S:
http://www2.panasonic.com/consumer-e...00000000005702
Amphony 2500:
http://www.amphony.com/products/digi...headphones.htm
If you need to convert coax to optical:
http://www.ambery.com/dicostooptof.html
CloneX is offline
post #10 of 10 Old 04-07-2010, 04:02 PM
casey_sdsu's Avatar
Gefen makes an adapter that coverts coaxial audio to analog audio which you can use for your headphones.
http://www.gefen.com/kvm/dproduct.jsp?prod_id=5279
Hope that helps.
Casey Webster
Advanced Digital Homes
casey_sdsu is offline
Reply Speakers
