Choosing center for my Polks - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 04-20-2010, 10:51 AM - Thread Starter
arseniy82's Avatar
Hi guys,
Could someone tell me what would be a good center speaker for my Polk Audio RTi6 speakers? I thought about CS1 or CS10 or should I go with something else?
arseniy82 is offline
post #2 of 5 Old 04-20-2010, 11:03 AM
twin2's Avatar
Originally Posted by arseniy82 View Post
Hi guys,
You're probably going to want to go with the Polk CSi3 or CSi6 to be timbre matched.
twin2 is offline
post #3 of 5 Old 04-20-2010, 11:19 AM
vinipux77's Avatar
Originally Posted by twin2 View Post
You're probably going to want to go with the Polk CSi3 or CSi5 to be timbre matched.
.. corrected it for you.
Those were the RT centers from the same generation as RTi6. The current year CSi A4 and -6, while not completely timbre matched, will also work better than either CS1 or CS10.
edit: to answer the usual follow up question whether the larger center is "worth it".
I started with CSi3 and RTi6 years ago when they first came out, and replaced the center with CSi5 a year and a half or so ago. While the difference is less than the size alone would imply, I am not looking to go back. The potential of CSi5 and similar when properly placed and amplified, is HUGE.
vinipux77 is offline
post #4 of 5 Old 04-20-2010, 11:20 AM
afrogt's Avatar
Quoted: 1056 Post(s)
Liked: 757
You'd want either the Csi3 or CSi5 from the older Rti line of the CSiA4 of CSiA6 from the current RTiA line.
Polk CSi3
http://www.amazon.com/Polk-Audio-Cen.../dp/B0000E6S12
Afro GT
afrogt is offline
post #5 of 5 Old 04-20-2010, 12:25 PM - Thread Starter
arseniy82's Avatar
Thank you all for the answers. I think I will stick with CSi3 for now and see if I need larger center.
Reply Speakers
