Mythos STS speaker cabinet rattling - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-20-2010, 06:27 PM - Thread Starter
jpenndcl's Avatar
I recently purchased a pair of STS and when I got them home I put the granite base on and hooked them up. I turned the base volume to 1am like the owner's manual suggested and played Billy Idol's Prodigal Blues. I walked around the back of the speaker while they were playing and heard a little rattling and squeaking noise coming from the speaker. I think the squeaking was coming from the base and tightened the screws, which seemed to help. The rattling however continued and seemed to come from the side of the tower (inside) and up near the cap of the tower. Has anyone had anything like this happen to them?
jpenndcl is offline
post #2 of 10 Old 04-20-2010, 09:30 PM
Snowmanick's Avatar
Quoted: 315 Post(s)
Liked: 441
"near the cap of the tower"? Do you mean the top of the speaker? I haven't noticed any rattling from my STS's, and the top where the MTM is seems to actually be the most acoustically inert surface on the tower. Have you tried emailing DefTech support?
Snowmanick is offline
post #3 of 10 Old 04-21-2010, 06:11 AM - Thread Starter
jpenndcl's Avatar
Yes, the top of the speaker. It is a buzzing/rattling noise when the base fires. It sounds internal to me or like the top of the speaker is rattling where it meets the side. Also, I heard a little rattle/buzz coming from the middle of the side of the speaker that seemed to go away when I pushed in on both sides of the speaker. Anyone have this issue or know what might be causing it?
jpenndcl is offline
post #4 of 10 Old 04-21-2010, 08:19 AM
Snowmanick's Avatar
Quoted: 315 Post(s)
Liked: 441
Try taking the grill off and listening again. I have heard a couple stories of the grill pins rattling.
post #5 of 10 Old 05-15-2010, 06:29 PM
FSUguy's Avatar
One of my buddies had a similar problem with his ST's, but he also heard a humming, which Def Tech the replaced the speaker.
FSUguy is offline
post #6 of 10 Old 07-12-2010, 08:00 PM
barry1me's Avatar
I notice I have a slight rattle/Buzz at the top of my STSs. I will be calling Deffinitive tomorrow. Did you get your speakers fixed?
barry1me is offline
post #7 of 10 Old 07-12-2010, 08:38 PM
Snowmanick's Avatar
Quoted: 315 Post(s)
Liked: 441
Also verify all the screws are tightened. Vibration/transport may cause them to back out a touch. And there are a lot of screws.
post #8 of 10 Old 07-12-2010, 08:45 PM
Espo77's Avatar
Quoted: 183 Post(s)
Liked: 85
FWIW, that song is LOADED with tons of very deep bass. Knowing this, I would have been a little more cautious at first and perhaps turned the bass down. This recording is capable of doing damage to a speaker. I hope your speaker is okay...did you keep the box and packaging?
Espo77's living room equipment: RECEIVER: Yamaha RX-A3030- SPEAKERS: Boston Acoustics M350, M25 center, surrounds, and front heights-
BLU-RAY: Oppo BDP103D- SUBWOOFER: HSU VTF-15H MK2- dedicated circuits for A/V- TV: Vizio P55C-1
Auralex Acoustics LENRD - Auralex Acoustics Roominator
Espo77 is offline
post #9 of 10 Old 08-06-2010, 10:13 AM - Thread Starter
jpenndcl's Avatar
I set them to the factory recommended settings was pretty careful turning them on because it was the first time they had been used and I am sure they have a break in period (like a new car). I did keep the packaging and ended up sending it back. Received a new set and they did not rattle.
jpenndcl is offline
post #10 of 10 Old 08-06-2010, 02:48 PM
yosh7's Avatar
Quoted: 137 Post(s)
Liked: 161
First, as a previous poster mentioned, try without the grills on. This was a problem with the ST's in the past. If its the grills, that should be an easy fix under warranty. If it still rattles with grills off, then take back to dealer to be replaced! Most all def tech dealers are excellent to work with, especially because problems like this are not frequent. I had a problem with my st binding post when I brought it home. I called the dealer and had a replacement within a few days. Also, the best person to speak with at def tech customer support is Chet. I have spoken with someone live every time I have called. Def Tech has great customer service.
The bottom line- you have awesome speakers that should be able to be played loud with tons of bass with 0 defects. If there is a problem, don't live with it - get it fixed or replaced. Good luck!
yosh7 is offline
Reply Speakers
