Polk Lsi vs Definitive Technology Mythos ST - AVS Forum | Home Theater Discussions And Reviews
post #1 of 7 Old 04-21-2010, 12:29 PM - Thread Starter
Adam@ECT's Avatar
I have read a few of the threads on here and would like some more opinions on these fine speakers.
I currently own the Polk Lsi 15, Lsi C and Lsi FX's with a PSW110 for my sub. The system is currently being powered by an Onkyo TX-SR805, which powers them pretty sufficently for my small condo.
Here is what I am considering doing and the question that I would lioke some advice on. I have the opportunity through my work to get a hold of the DefTech Mythos ST's for an unbelievable deal. I love my Lsi's, but the M-ST's are so much small and less power hungry. Would I be happier with the M-ST's and my current receiver or would I be happier buying a decent power amp or upgrading my sub and wiring the fronts in through the sub?
Thanks for the advice on my first thread.
Adam@ECT is offline
post #2 of 7 Old 04-21-2010, 03:30 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
totally different sounds, depending on what you like, make sure hear them first before you buy because the 2 are at the opposit ends of the spectrum. If i were you, i get a super sub if you like what you have now.
datranz is offline
post #3 of 7 Old 04-21-2010, 04:48 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Stick with what you have and put the money to a much better higher end subwoofer
crazyrob425 is offline
post #4 of 7 Old 04-21-2010, 07:42 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
If you really do love your Lsi speakers you should stick with them.
If you are really kinda thinking they are bright maybe even harsh sounding when you apply a little volume then find the Def Techs locally and audition them for a few hours to see if you prefer that sound.
Charlie
chashint is offline
post #5 of 7 Old 04-21-2010, 07:49 PM
dobieck1's Avatar
Liked: 27
I owned the ST for a short time, and they are quite impressive. I would at least give em a listen. I powered em with the 805 as well.
Here to help and learn. Thanks AVS.
XBL: HoosierInOhio
dobieck1 is offline
post #6 of 7 Old 04-21-2010, 08:29 PM
datranz's Avatar
Quoted: 57 Post(s)
Liked: 40
those lsi are anything but bright, warm if i may say so. Polks' other lines are exremely bright.
datranz is offline
post #7 of 7 Old 04-22-2010, 10:11 PM - Thread Starter
Adam@ECT's Avatar
Thank you for all the thoughts. A new sub is exactly what I have been thinking that I am in need of. Only reason I have the PSW110 is because I got it for $50 and for my condo is more than enough bass. Neighbors already hate me enough.
Adam@ECT is offline
Reply Speakers
