Noob Here: Did I make the right choice? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 10 Old 04-26-2010, 12:42 PM - Thread Starter
KingQuad's Avatar
I recently purchased my first HDTV and Blu-Ray and for the sound I really wasn't to keen on the 5.1 Surround cause I don't really have anywhere to put the speakers so i would have to buy the speaker stands and run wire etc.. So I Researched mostly on this great site and found a Great deal it seemed on a Pair of Energy CF30's Floorstanders and also found a good deal on a Denon 1610 receiver so I bought them. Probably to add a Sub in the near future
So Did I make the Right choice? it seems i could of gotten a decent 5.1 from Jamo, Polk or among others for quite a bit cheaper..
Also will adding a Center speaker make a difference in between the Floor-standers?
Keep in Mind I'm a Super Noob with this Audio stuff
Thanx in Advance
KingQuad is offline
post #2 of 10 Old 04-26-2010, 12:46 PM - Thread Starter
KingQuad's Avatar
I wanted to add a photo so you guys can see how much room I don't have
KingQuad is offline
post #3 of 10 Old 04-26-2010, 12:47 PM
Looneybomber's Avatar
Liked: 25
You will get a couple different oppinions, but mine is you made a good choice.
I find it's better to have nice quality L/R's and a sub, than lower quality 5.1. Later, when you get more money and feel an upgrade is necessary, you can add in the center and surrounds. I'm a fan of 2.1 and 5.1/7.1, but don't feel 3.1 is worth it.
YID DIY
Looneybomber is offline
post #4 of 10 Old 04-26-2010, 01:03 PM
rdeyoung's Avatar
Quoted: 101 Post(s)
Liked: 116
So you would say that a 3.1 system is not better then a 2.1 for movies?
Lighting Artist for Walt Disney Animation Studios
Pioneer Elite VSX-92TXH AVR || Klipsch RF-7ii, RC-64ii, RS-62ii || SVS SB13U || Samsung UNC558000 3DTV || PS3 || XBone || X360
rdeyoung is offline
post #5 of 10 Old 04-26-2010, 01:15 PM
Liked: 25
Correct. You will even see some people running 4.1/6.1 using a phantom center, i.e. no center, just the L/R's
YID DIY
post #6 of 10 Old 04-26-2010, 01:21 PM - Thread Starter
KingQuad's Avatar
Thanx for your response Looney.. So it would not be worth it to put a center in my setup correct?
KingQuad is offline
post #7 of 10 Old 04-26-2010, 02:17 PM
Liked: 25
That's up to you. I don't feel it is, but if you do it, you may love 3.1 and think I'm an Id10t for not liking it.
YID DIY
post #8 of 10 Old 04-26-2010, 03:42 PM
maxcooper's Avatar
Quoted: 13 Post(s)
If people will be sitting to the left and right, a center speaker will help keep the dialog in the middle. This is especially true if any of the seating positions are substantially closer to one of the L or R speakers, since the person in that seat will hear all the dialog coming from the the speaker they are closest to. I'm not really sure why, but this seems to matter more for some speakers than for others. I suggest you wait until you have the system setup and then try sitting in each of the positions you care about. Some tweaking of the speaker position or toe-in, and the seating positions may help. But you might find that you just need a center.
Another issue that I noticed as I recently sold my 5.1 system and am temporarily running 2.1 until I get a new 5.1 system, is that the dialog sounds "doubled" when sitting off center. I'm pretty sure it is the sound from both speakers arriving at slightly different times. But it's noticeable. Calling it "doubled" probably makes it sound a lot worse than it really is -- it is just a minor effect and the dialog is still clear and easy to understand. But if you have to listen at low volume level, I think that adding a good center could improve clarity for off-center listening positions. (Adding a "bad" / low quality center could also make it worse, however.)
I'd still probably buy a sub before I bought a center, though.
-Max
maxcooper is offline
post #9 of 10 Old 04-26-2010, 10:04 PM
chashint's Avatar
Quoted: 18 Post(s)
Liked: 54
Looks like plenty of room to me.
I think it will be well worth the "trouble" to add surround speakers.
It would be a hard choice but if I had to choose between having a center channel or surround speakers I would choose the surrounds.
Charlie
chashint is offline
post #10 of 10 Old 04-27-2010, 11:52 AM - Thread Starter
KingQuad's Avatar
Is the Denon AVR-1610 That I bought have enough power for these Energy cf30's?
Also does it have enough power if I wanted to upgrade to a full 5.1?
Does it make sense when I do upgrade to the 5.1 I should use these speakers for the Fronts?
Thank You
KingQuad is offline
Reply Speakers
