Opinons on Sonance Vs. ? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 1 Old 05-12-2010, 10:16 AM - Thread Starter
Simple151's Avatar
I am setting up either a 5.2 or a 7.2 system in my bedroom (12.5' x 12.5' room with 12' ceiling) I will use it mostly for movies.
I am considering using
Sonace brand:
(2) Cinema select LCR, (1) Cinema LCR1,(1pr) Cinema select SUR and (1pr) Ellipse SUR
Klipsch brand:
(2) KL-6502-THX , (1) Center speaker KL-6504-THX, 1 pair of KS-7800-THX , and 1 pair of KS-7502-THX
the Klipsch setup is $500.00 more then the Sonance
I will be using a 200 - 300 watt amp most likely Adcom or Sunfire. I will be posting a tread about these in the correct forum.
I also need suggestions for matching subs, I was thinking either Sonance, Sunfire.
Please help me, I know in walls are far from the best but the room is all new construction, I will be using Sonance pillows to stop air flow along with Dynamat in the walls.
Thank you for your help.
Simple151 is offline
Reply Speakers
