Polk CS1 Question - AVS Forum | Home Theater Discussions And Reviews
Old 05-16-2010, 12:22 PM - Thread Starter
superxero044's Avatar
So I'm a complete newbie to Home Audio. I just about 2 weeks ago got my first receiver. Its a Pioneer VSX-820. I only got my fronts for now but am working toward 5.1
I bought Monitor 40's off newegg for the fronts, and was planning on buying a Sub next, and I had heard that BIC Acoustech H100 is pretty good and was saving up for that. But newegg has the Polk CS1 on sale for 70$ which seems like a pretty good deal. I had heard that its good to match your center with your fronts. Is that really that big of a deal? And if I end up upgrading my fronts eventually will that be bad?
superxero044 is offline
Old 05-16-2010, 12:34 PM
krakhen's Avatar
The CS1 is the exact match for the monitor 40's up to the monitor 60's. I have these speakers for my 3.1 setup right now.
The CS2 is sometimes used also although the drivers are a little bigger. The advice I've been given and read everywhere is to try to match the front speakers.
If you do change later, the advice will surely be to match the center again.
__________
Krakhen
krakhen is offline
Old 05-16-2010, 01:08 PM - Thread Starter
so that seems like a pretty good deal, but if I jump on it i'll prolly be sitting on a 3.0 system for a while b/c I can't really spend much more for a while. Will that sound really weird?
Old 05-16-2010, 01:31 PM
afrogt's Avatar
Quoted: 1053 Post(s)
Liked: 755
A 3.0 system will sound very good since speakers are all matched. You won't get the low end bass you want though.
How long is a while? How long would you have to go without a sub?
Afro GT
afrogt is offline
Old 05-16-2010, 01:52 PM - Thread Starter
prolly like 2 months
Old 05-16-2010, 02:42 PM
coolsax's Avatar
I think 2 months would not be too long.. new egg is always putting the CS1 on sale so if you miss it now to get a sub, it will come back.
coolsax is offline
Old 05-16-2010, 02:52 PM - Thread Starter
for 70 bucks? that seems pretty good.
I ended up buying it. Looks like I'll be eating a lot more mac and cheese and ramen, but I'll have a better stereo
Old 05-16-2010, 07:57 PM
madwi's Avatar
at least you have your priorities in order lol
madwi is offline
Old 05-16-2010, 09:06 PM
AzN_plyR's Avatar
Fronts + Subwoofer + Phantom Center > 3.0 system IMO
AzN_plyR is offline
Old 05-16-2010, 09:16 PM - Thread Starter
yeah but the thing is i'm prolly gonna invest a lot more in a sub than i did on the center. i couldn't have bought a sub right now anyways.
Old 05-16-2010, 09:35 PM
EndersShadow's Avatar
Quoted: 448 Post(s)
Liked: 815
You normally want the center to be from the same manufacture and line as the fronts otherwise you could notice a very annoying difference in tone. Also you want to make sure you really invest in a good sub. I have the PSW125 and its not worth the money I spent. I highly suggest dropping 500ish on your sub as it will make your other speakers sound better since you can focus them on mid and highs (40Hz+ frequencies)
I would purchase the center first since its going to be much cheaper than a sub and then spend a very decent amount on your sub. I am running Monitor 40's and a CS1 in my bedroom and dont have a sub connected and while I dont have a huge amount of bass I dont need it. Save up and buy one really good subwoofer one time. Otherwise you will be stuck upgrading which will cost you twice as much. I highly suggest checking this thread out for what you can purchase within given price ranges.
My Setup | FS: Nothing right now
Quote: There exists, for everyone, a sentence - a series of words - that has the power to destroy you. Another sentence exists, another series of words, that could heal you. If you're lucky you will get the 2nd, but you can be certain of getting the 1st. - Philip K. Dick
EndersShadow is online now
Old 05-16-2010, 10:32 PM
KrazedOmega's Avatar
Not to thread jack here, but does anyone know of a Canadian website or a U.S. site that has the CS1 and will ship to Canada? I've been looking for a CS1 and all I can seem to find is the one on Newegg.com.
KrazedOmega is offline
Old 05-17-2010, 08:38 PM
dimetera413's Avatar
Try ebay. The CS1 is discontinued but newegg just sells the leftovers. The CS10 is the newer version. A CS2 is the same as the CS1 with bigger drivers so if you can find one of those i would jump on it, i used to have one and for 100 bucks it was a great deal.
dimetera413 is offline
Old 05-17-2010, 08:39 PM - Thread Starter
yeah not to change the subject completely but I've been looking around for surrounds (although it'll be a while before i can get them. form my room it will be tough to place surrounds. can you put them to your left and right and have a similar affect? my couch is against a wall.
Old 05-17-2010, 08:41 PM
Yeah, it won't be ideal but alot of people do that for the same reason you are: no room. Should be fine.
Old 05-17-2010, 08:58 PM - Thread Starter
And I think i'm gonna go w/ monitor 30's unless people have different recommendation. I would prolly get 40's but they're HUGE for surrounds
Old 05-17-2010, 09:11 PM
30s are fine.
Old 05-17-2010, 09:14 PM - Thread Starter
any recommendations if I wanted to go smaller than 30s for a similar price?
Old 05-17-2010, 09:39 PM
Well from Polk I think that's the smallest Monitor series speaker they make. Don't go too small, granted surrounds play minimal sound but the 30s are really good surrounds, especially for around 100 a pair from newegg.
Old 05-17-2010, 09:42 PM - Thread Starter
cool.
I just have no idea what i'm going to set them on when I get them. I already had to sacrifice my end table to put my receiver on.
Old 05-17-2010, 09:45 PM
You could get some cheap 20 dollar wall mounts.
Old 05-18-2010, 12:13 AM
afrogt's Avatar
Liked: 755
you could get the smaller RM 6751 satellite speaker but it won't have the fullness of the Monitor 30. The sat only has 3.5" driver vs a 5.25" driver in the Monitor 30.
http://www.amazon.com/Polk-Audio-RM6...4163118&sr=8-2
Afro GT
afrogt is offline
Old 05-18-2010, 05:52 AM
Quoted: 448 Post(s)
Liked: 815
The Monitor 30's have built in keyhole mounts so you could just mount them straight to the wall with no bracket.
Old 05-18-2010, 03:52 PM - Thread Starter
That involve screwing something into the wall tho? I live in an apartment
Old 05-18-2010, 04:08 PM
Quoted: 448 Post(s)
Liked: 815
All you need is to put a nail into the wall similar to hanging a picture frame. Most apartments allow you to do that provided you putty it over when you move out. I have done worse in apartments before lol...
Old 05-18-2010, 05:05 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
Its perfectly ok to put a screw into the wall at an apartment complex. I use a Drywall anchor if you can't find a stud.
Then just put some putty over the hole and you are golden, They will be repainting the place after you go
crazyrob425 is offline
Old 05-18-2010, 05:23 PM - Thread Starter
Cool. The places I lived at in college would take from your deposit for anything. (and then not fix it). I am getting more and more excited for when I complete this setup. CS1 Is coming on thursday
Old 05-20-2010, 12:30 PM - Thread Starter
sorry for the bump but now that I have my center channel, I have a 3.0 system - the monitor 40's and CS1. Should I set the center channel to small or large?
Old 05-20-2010, 02:34 PM
Quoted: 448 Post(s)
Liked: 815
If you have a sub set everything to small. If you dont have a sub set everyting to large.
Old 05-20-2010, 03:12 PM - Thread Starter
Yeah I don't have a sub yet. Just wasn't sure about the center channel. Seems to sound better on large. Thanks
