Rhyme Acoustics NuScale 216 bookshelf - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 05-25-2010, 09:26 AM - Thread Starter
mycrownvic02's Avatar
Has anyone tried these drivers around here? They look nice.. $645.00
specs
NuScale 216 6.5" 2-way speaker pair - Cherry
* Fully assembled
* 2-way bookshelf speaker
* Tweeter: NeoCd3.0 3" ribbon
* Woofer: FW168SE 6.5" aluminum cone long throw
* Crossover: 18dB HP and LP
* Frequency Response: 45Hz to 40,000Hz +/- 3dB
* Impedance: 8 ohm
* Sensitivity: 83.7dB /W/M
* Rated Power: 80W (*IEC268-5)
* Dimensions: 386mm x 213mm x 288mm (15.2" x 8.4" x 11.3")
* Net Weight: 10.2kg (22.5 lbs) each
link
http://www.madisound.com/catalog/pro...oducts_id=8819
mycrownvic02 is offline
post #2 of 4 Old 05-25-2010, 02:07 PM
grasshoppers's Avatar
Quoted: 859 Post(s)
Liked: 555
Haven't tried them, but that is one nice looking Speaker!
Seems to have a pretty flat freq response too.
Anthem MRX-300-Outlaw Audio M2200
Rythmik F12 subs
Paradigm Signature S6,C1,S1
Harman Kardon DMC1000 (music)
Assassin HTPC (movies)
grasshoppers is online now
post #3 of 4 Old 05-25-2010, 09:02 PM - Thread Starter
up
post #4 of 4 Old 06-19-2010, 05:49 PM
pjpoes's Avatar
These are indeed a great deal. The drivers are all fountek drivers of excellent quality. They aren't very efficient, but you can't totally compare that to readily available speakers, as the efficiency is somewhat of a more honest spec. Still, its not an efficient speaker and that will limit it's use somewhat. The speaker simply will not play as loud as more sensitive or efficient designs can. These would work great in a smaller system, just don't expect them to reach realistic levels. I'd also avoid pairing them with low wattage amps.
pjpoes is offline
Reply Speakers
