undecided and need help - AVS Forum | Home Theater Discussions And Reviews
post #1 of 4 Old 06-01-2010, 02:13 PM - Thread Starter
bballgms's Avatar
my room is 12x12 and i am going to be using the speakers for tv,music,movies,games in that order of importance. i was looking to get a htib, but i have sided against that. i my budget is around 400 including reciver. i know that it is hard to do 5.1 for that budget so i am looking to spend 400 for reciever,sub, and main speakers in the front. since i have some speakers i could use in the meanwhile for the rear. what systems do you guys suggest?
one person has suggested so far the jamo s413. any other sugestions. thank you for ur input in advance.
bballgms is offline
post #2 of 4 Old 06-01-2010, 03:17 PM
crazyrob425's Avatar
Quoted: 443 Post(s)
Liked: 337
With your extremely limited budget the the Jamo S413 with either the Pioneer VSX-520, or Sony STR-DH510
$400 is just enough for most budget entry 5.1 speaker sets and you want a reciever as well
crazyrob425 is offline
post #3 of 4 Old 06-01-2010, 07:16 PM - Thread Starter
bballgms's Avatar
i understand that 400 is barely going to get me a 5.1 system, what system do u recomend for a 2.1 and a reciever with that price that has the option later on for me to upgrade?
bballgms is offline
post #4 of 4 Old 06-01-2010, 08:18 PM
stevensctt's Avatar
Quoted: 23 Post(s)
Liked: 37
Unless you look at HTIB, you're probably going to have increase your budget to $500, leaving room to upgrade.
Still tough to do, but taking a quick look at a $500 budget for a 2.1, all new stuff, buying right now, all from eBay:
Receiver 5.1 with HDMI, some with Auto EQs, ~$175 shipped
Onkyo TRSR307
Sherwood RD6513
Yamaha RXV365
SONY STR DH500
Speakers, Bookshelf, pair
Infinity Primus P152 $160 shipped
Subwoofer
BIC AMERICA V1020 10 ~$175 shipped (not familiar with BIC subwoofers but they seem to be recommended often)
If you look at strictly used, don't need HDMI, you can do better.
Here is a good deal on pair of speakers I ran across:
http://cgi.ebay.com/Ascend-Acoustics...item3f003b791e
stevensctt is offline
Reply Speakers
