Speaker recommendation for Yamaha RX-V567 - AVS Forum | Home Theater Discussions And Reviews
post #1 of 3 Old 06-04-2010, 11:57 AM - Thread Starter
sapontejr's Avatar
Hi,
I am looking to replace my 5 speakers. I currently own the Yamaha RX-V567 receiver and the Acoustech BIC H-100 front firing subwoofer. Does anyone have a recommendation for 5 speakers? I am not looking to spend more than $300.
Also, since my receiver is 7.1 is it possible to set up speaker 6 and speaker 7 in a separate "zone" so i can put them outside on my patio? I didn't see anything in the manual for this. It's not a necessity but would be nice.
Thanks for your support and forgive me for being a newbie to audio!
Steve
sapontejr is offline
post #2 of 3 Old 06-04-2010, 12:13 PM
afrogt's Avatar
Quoted: 1438 Post(s)
Liked: 983
That receiver does not have Zone 2 fuctionality. Sorry.
As far as 5 speakers for $300 that is pretty tough but this might work for you.
Jamo E660 towers $129
http://www.wwstereo.com/website/ecom...product=E660DA
Jamo C400 center $$79
http://www.vanns.com/shop/servlet/it..._c=site_search
Jamo C401 bookshelf speakers $79
That's all under $300 shipped. If you dont want towers you can get the C403 bookshelf instead. Its the big brother to the C401.
http://www.wwstereo.com/website/ecom...product=C403DA
The E660 pair is only $10 more though and you dont need to buy speaker stands.
Afro GT
afrogt is online now
post #3 of 3 Old 06-04-2010, 02:10 PM - Thread Starter
sapontejr's Avatar
Thanks Afrogt. I will take a look at those speakers!
Reply Speakers
