Old Bose 201 series III worth salvaging for use in rear? - AVS Forum | Home Theater Discussions And Reviews
post #1 of 5 Old 06-09-2010, 05:06 PM - Thread Starter
Tsantsa's Avatar
I have some old bose 201 series III speakers that I don't use. I currently use 2 old HTiB surround speakers for my surrounds. I am wondering if I should just go ahead and use the bose as the rears? The problem is that the tweets on the bose crackle a bit. Would it be worth salvaging (replacing) the malfunctioning parts to replace those tiny things I have running in the rears now?
Also, I'm running a Denon 1610 with some Jamo 6ohm's in the front/center. The bose are 8ohm (and I'm sure the rears are too, not listed), will this throw off the receiver at all? Or is that ok. I plan to get the matching Jamo's for the rear, but money has been tight of late. I can get tweets for about $10-$15 each on ebay. (anyone have a better source?)
Tsantsa is offline
post #2 of 5 Old 06-09-2010, 05:22 PM
Paul Scarpelli's Avatar
Liked: 54
A pair of those (in good working order) should do a nice job for surround. Oddly enough, a pair of Bose 901s aimed into the rear corners can do a spectacular job for surround channels in a 5.1 system. I can't believe I actually admitted that in print...
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #3 of 5 Old 06-09-2010, 05:28 PM - Thread Starter
Tsantsa's Avatar
SOMEONE TAKE A SCREENSHOT QUICK!!!! lol
Thanks. I was thinking that with the design of the cabinet, they could work as a sort of bipole surround.
Tsantsa is offline
post #4 of 5 Old 06-09-2010, 05:33 PM
Liked: 54
You are correct, sort of. They scatter a mildly diffuse soundfield; very spacious...although some would say specious.
Paul Scarpelli
aka TRIAD DUDE
post #5 of 5 Old 06-09-2010, 07:24 PM - Thread Starter
Tsantsa's Avatar
Hm. I have them connected in the rear and running some mp3's in matrix mode to get constant sound from the rears. They seem not to have blown the tweeters...I could have sworn they did. They sound far and away better than those crappy surround speaks!
Tsantsa is offline
Reply Speakers
