Infinity Cascade Tweeters - AVS Forum | Home Theater Discussions And Reviews
post #1 of 20 Old 06-19-2010, 08:48 PM - Thread Starter
fookoo_2010's Avatar
Quoted: 231 Post(s)
Liked: 80
I recently acquired a pair of 9's, a 3 C, and a 15. Two of the three tweeters blew out in one of the 9's and the 3 C. They are under warranty and will be fixed. Here I had thought that speakers were almost indestructible, especially Infinity's. Anyone else have a problem with blown Cascade tweeters? The 9's were bi-wired via a Panasonic SA-BX500 A/V Receiver. How delicate are these tweeters? The first thumbnail is an intact tweeter.
fookoo_2010 is offline
post #2 of 20 Old 06-19-2010, 08:55 PM
Paul Scarpelli's Avatar
Liked: 54
Tweeters are easy to blow. Just turn the volume up past 2 o'clock and see. If you turn the treble up AT ALL you are guaranteed to blow tweeters. I've always liked Infinity, and I sold them at retail over twenty years ago, but the Infinity Emit tweeter was absolutely the easiest tweeter to blow on the planet. If you listen like you have been, you'll continue to blow them. Sorry, I know it's a bummer.
Paul Scarpelli
aka TRIAD DUDE
I can tell people who are judgmental just by looking at them...
Paul Scarpelli is offline
post #3 of 20 Old 06-20-2010, 10:43 AM - Thread Starter
Quoted: 231 Post(s)
Liked: 80
I had one of the first EMIT's in the RS 4.5 and probably never got much past 12 o'clock. What would be a comparable rating in terms of db as this is how a lot of AVR's indicate volume or loudness?
post #4 of 20 Old 06-20-2010, 12:01 PM
Liked: 54
Gain structures in the preamp section, level of the recording, calibration of the attenuater (volume control), etc. are so random that there's no way to estimate. A hot recording could be driving the receiver into clipping at 11 o'clock, but you could play some New Age recordings at 4 o'clock and not use 50 watts. A Dream Theater CD, with oceans of cymbals and lots of synthesizer, would potentially damage a tweeter with prolonged high-volume listening. And a volume control at 12 o'clock on one receiver might have the same output as a volume control at 3 o'clock on another due to the gain structure.
The bottom line is, you'll know when you're playing it too loud. Some tweeters get a bit harsh when you're approaching their death, but others sound fine right up until when they fail. I've blown a dozen tweeters, blown up three car engines, broken three titanium bicycle frames, cracked a dozen Zildjian cymbals, and broken ten bones in my body. Some of us just break stuff.
Paul Scarpelli
aka TRIAD DUDE
post #5 of 20 Old 06-20-2010, 12:22 PM - Thread Starter
Quoted: 231 Post(s)
Liked: 80
I thought that you might reply like that. So I will have to treat the HT system audio like a stereo system and start the volume off low and then increase it. Thanks for your replies.
post #6 of 20 Old 06-20-2010, 12:33 PM
Looneybomber's Avatar
Liked: 25
Blown, or smashed due to someone pressing on them? Over powering a metal dome tweeter does not cause them to implode.
As opposed to starting with the volume at "11" and turning it down? Who does that?
YID DIY
Looneybomber is offline
post #7 of 20 Old 06-20-2010, 07:26 PM
Liked: 54
Nigel Tufnel.
Paul Scarpelli
aka TRIAD DUDE
post #8 of 20 Old 06-20-2010, 07:42 PM
inky blacks's Avatar
That design uses an unusually low crossover point to the tweeter, so the problem may be endemic to the model.
inky blacks is offline
post #9 of 20 Old 06-20-2010, 07:59 PM
Liked: 25
I think kids fingers are endemic to tweeter damage.
YID DIY
post #10 of 20 Old 06-20-2010, 08:45 PM
Liked: 54
That's clearly physical damage and not electrical damage. Pinching a tweeter doesn't usually do it a lot of good.
Paul Scarpelli
aka TRIAD DUDE
post #11 of 20 Old 06-20-2010, 09:16 PM
Knucklehead90's Avatar
Quoted: 385 Post(s)
Liked: 332
Agree - I've owned a pair of Interlude IL40s for about 9 years - they use the same tweeter as whats in the Cascades - and a 5.0 Beta setup using the same tweeter - and I now have the Cascade 5.1 setup. I've played all of them LOUD and they play loud very well - that damage was done by fingers not by over driving them.
As soon as HK gets a look at them they likely will be sent back in the same condition as sent.
Note that the 'grilles' on the Cascade model speakers isn't what you might think of when thinking about grilles. It is a thin fabric stretched over the face of the speaker and held in place by magnets which are adjusted to pull the cloth cover tight. This leaves a gap between the face and cloth that would trigger curiosity in owners of small fingers - fingers that would have no problem getting in there and doing the damage pictured. Looks like an investigation is in order.
Yamaha CX-A5000 - Acurus A100x3 & Outlaw 7075 - Salk Song Towers - Custom Selah Audio Center - Oppo 103 - Marantz TT42
***GO SEAHAWKS ***
Twas a woman who drove me to drink. I never had the decency to write and thank her ~ WC Fields
Knucklehead90 is online now
post #12 of 20 Old 06-20-2010, 11:40 PM - Thread Starter
Quoted: 231 Post(s)
Liked: 80
The damage to the tweeters was not the result of some kid pinching them because there are none around here and that is a repost of my picture and it is electrical damage because I never touched the tweeters with anything. The Cascade 9's and the 3 C performed fine for about four weeks with no problem. As to HK returning them un-repaired, you obviously don't understand the repair process. It is either taken to an authorized repair place or sent there - if you are really curious see the authorized Infinity repair sites on the Infinity website.
post #13 of 20 Old 06-21-2010, 06:15 AM
Liked: 25
And allow me to quote myself from earlier.
I've blown a few speaker drivers while playing with amps much too powerful (crown CE4000) and even caught one on fire. I repeat, hard domed tweeters do not implode when "blown". Someone/something poked them.
What Knuckle is saying is when HK sees that the tweeters are damaged physically, and of no fault to their design, they will not repair them under warranty. It's like hitting a deer in your car and claiming the smashed front end was due to a flaulty bumper.
YID DIY
post #14 of 20 Old 06-21-2010, 06:18 AM
Liked: 54
Why is the dust button physically crushed on the tweeter? It's directly connected to the voice coil, and once out of round, a voice coil will usually fail.
Paul Scarpelli
aka TRIAD DUDE
post #15 of 20 Old 06-21-2010, 06:53 AM
cdy2179's Avatar
Quoted: 731 Post(s)
Liked: 424
Damn Paul...maybe you should just stay in bed!
cdy2179 is offline
post #16 of 20 Old 06-21-2010, 08:07 AM
Quoted: 385 Post(s)
Liked: 332
And I know people who could break a crow bar in a sand box.
I've had a couple of tweeters blow on me too - and never seen physical damage. This was on a pair of JBL speakers (thanks to my son) with titanium dome tweeters. The tweeters looked just fine from the outside - electrically they were toast.
***GO SEAHAWKS ***
post #17 of 20 Old 08-20-2010, 07:59 AM - Thread Starter
Quoted: 231 Post(s)
Liked: 80
Pretty frustrating, the authorized repair shop says that getting a hold of the tweeters has been a problem, especially having to deal with India tech support.
post #18 of 20 Old 10-31-2010, 08:26 PM - Thread Starter
Quoted: 231 Post(s)
Liked: 80
After four months plus, two tweeters were finally replaced by Infinity through an authorized local repair shop. The tweeters apparently were out of stock until just recently. Then there was the repair tech's problem of how to actually get into the speaker to replace the blown tweeters. The front metal open plate housing the three drivers had to be broken out, literally, and then was replaced by a grey plastic housing - nothing simple like a couple of screws. The original housing was metal and the replacement housing is no longer magnetic and will not hold up the supplied drape/curtain. Hence, the use of black electrical tape. Not exactly a thrilling repair, courtesy of Infinity. In spite of this, I like the sound of the Cascade Nines in a home theater system.
post #19 of 20 Old 10-31-2010, 10:49 PM
Quoted: 385 Post(s)
Liked: 332
They are a very good sounding speaker --- I remain unimpressed with the 'grille' - they are more of an afterthought.
Hopefully I won't have any problems with my Cascades - but I do have over 4 years of warranty left. I use a pair of Three Vs in the bedroom in a 2 channel setup with a sub - and a pair of Fives for surrounds to accompany the 3 Interlude fronts.
Good luck with the rebuilt Nines.
***GO SEAHAWKS ***
post #20 of 20 Old 10-31-2010, 11:36 PM - Thread Starter
Quoted: 231 Post(s)
Liked: 80
As long as you don't over drive them into distortion, you should have no problem because that is what happened to me. I now sit amidst a 9.2 home theater system powered with a Denon 4311CI, a Cascade 3C Center speaker, 8 Cascade 9s, and 2 Cascade 15s. Now that is flying!!
Reply Speakers
